StevePenn
File name extension removal
May 28, 2012 2:25 AM
Tags: #file #indesign #cs6 #name #scripts #file_extensions
Hi. Have just upgraded to CS6 and have an issue with a script we use in production. The script exports a .ps file to a location but we are having to remove the .indd extension each time we use it (eg filename.indd.ps becomes filename.ps). The previous version of indesign we were able to save the file without it's .indd extension and when it was opened the extension stayed hidden. CS6 can save without the extension but when the file is open the extension is visible again. Any ideas? cheers
    May 28, 2012 4:51 AM   in reply to StevePenn
    Hi Steve,
    Can you please try the below JS code.
    I am not tested the below code in CS6 just tested only CS5.5
    var myDoc = app.activeDocument;
    var myPath = myDoc.filePath;
    var myNEWName = (myDoc.name.replace(".indd",".ps"));
    var myDc = new File(myPath+"/"+myNEWName);
    myDoc.save(myDc);
    myDoc.saveACopy(myDc);
    thx
    csm_phil
    May 28, 2012 11:28 AM   in reply to StevePenn
    hi,
    well some code could have been nice ...
    For general, you can use this handler which starts "system events"
    Input alias & new suffix -> returns new filename
    Code:
    set thisWillBeTheNewFileName to my setFileName(choose file, "ps") --example usage
    on setFileName(myAlias, myNewSuffix)
        tell application "System Events"
            set {myName, myExtension} to {name, name extension} of disk item (myAlias as text)
            if myExtension is not "" then
                set {tid, AppleScript's text item delimiters} to {AppleScript's text item delimiters, myExtension}
                set myName to text 1 thru -2 of (text item 1 of myName)
            end if
            set newName to myName & "." & myNewSuffix
        end tell
        return newName
        set AppleScript's text item delimiters to tid
    end setFileName
    May 28, 2012 7:10 PM   in reply to -hans-
    Firing up System Events seems like overkill (and it's quite slow to launch), especially as you're using text item delimiters anyway. You could just use:
    on changeExtension(oldPath, ext)
              set saveTID to AppleScript's text item delimiters
              set AppleScript's text item delimiters to {":"}
              set justName to text item -1 of oldPath
              if justName contains "." then
                        set AppleScript's text item delimiters to {"."}
                        set newPath to text 1 thru text item -2 of oldPath
              else
                        set newPath to oldPath
              end if
              set AppleScript's text item delimiters to saveTID
              return newPath & "." & ext
    end changeExtension
    Of course if you're happy to use some outside help, my ASObjC Runner is quicker and easier than System Events:
    tell application "ASObjC Runner" to set newPath to file path from oldPath replacing extension ext
    May 28, 2012 7:27 PM   in reply to StevePenn
    I suspect the problem is that InDesign has hijacked the text class. It's just a matter of miving the relevant bit of code outside the 'tell app "InDesign"' block.
    May 28, 2012 11:16 PM   in reply to Shane Stanley
    of course you're right assuming a text path is send to the handler, System Events will handle text path or alias. As the poster couldn't show any source code it seemed safer ;-)
    Have a nice day
    May 28, 2012 11:35 PM   in reply to -hans-
    That's a good point, but a simple "as string" will solve it in the first example.
    The second example, using ASObjC Runner, will actually accept an alias, file, HFS path or even POSIX path.
    May 29, 2012 1:17 AM   in reply to Shane Stanley
    Of course! you're right ;-)
    I just took the system events handler from my pocket-library ...
    ASObjC Runner:
    Thx for programming
