For loops in functions?
May 25, 2012 11:06 AM
I am using the following code in a program:
It is a simple conditional statement
in which a button moves to a certain group of frames when clicked depending on its current frame. This is the code I'm using.
var group1:Array=["b1","b2","b3"];
var group2:Array=["b12","b22","b32"]
mainbutton.addEventListener(MouseEvent.CLICK, buttonflash)
function buttonFlash (e:MouseEvent)
     for (var gr1:uint=0; gr1<group1.length; group1++)
    {if
       (e.target.currentLabel == group1[gr1])
       {e.target.gotoAndStop(e.target.currentLabel +     "2")}
    else
       {e.target.gotoAndStop(e.target.currentLabel.slice(0,2))}
However, when I include the for loop in the function, it causes the function to run the number
of times of the variable. In testing, I switched out the else statement with a trace string and the string showed up in the output window three times.
When I place the for loop outside of the function, the output compiler says the variable is undefined. Any ideas as to what I'm doing wrong to have the loop run once?
    May 25, 2012 11:58 AM   in reply to witherton
        {if
           {e.target.gotoAndStop(e.target.currentLabel +     "2");
           break;
        else
    May 25, 2012 12:45 PM   in reply to witherton
    Could you explain why you are trying to increment group1 instead of gr1?  group1 is not a numeric variable, so incrementing it by 1 is not going to get you very far and should be causing you errors.
    for (var gr1:uint=0; gr1<group1.length; group1++ )
    May 25, 2012 12:55 PM   in reply to witherton
    var isInGroup:Boolean=false;
         for (var gr1:int=0; gr1<group1.length; gr1++)  //Thank you Ned
        {if
          isInGroup=true;
           break;
        if (!isInGroup)
          isInGroup=false;
