Pio Emilio Diaz
Error installing CS6
May 15, 2012 8:48 PM
I have tried in different computers, different installers and I keep getting the following errors.
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DF027, DW006 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 11 error(s), 0 warning(s)
----------- Payload: {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 -----------
ERROR: DW006: Apple Package failed to install successfully.
----------- Payload: {CC006FD6-00EF-46FC-ACA0-7A28EFF44D20} Adobe Media Encoder CS6 6.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirQFnk2Ji6/Assets1/Adobe Media Encoder CS6.app/Contents/Frameworks/CIT/Plug-ins/CustomLanguageModel/CustomLa nguageModel.bundle/Contents/MacOS/CustomLanguageModel" to "/Applications/Adobe Media Encoder CS6/Adobe Media Encoder CS6.app/Contents/Frameworks/CIT/Plug-ins/CustomLanguageModel/CustomLa nguageModel.bundle/Contents/MacOS/CustomLanguageModel" (Seq 981)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 981)
----------- Payload: {E1C48031-9366-427F-AC04-535CEDAAD995} Acrobat X Pro  10.0.0.0 -----------
----------- Payload: {6040E054-500A-427A-9DA2-349F0FEB19D1} Adobe Illustrator CS6 Core_AdobeIllustrator16en_USLanguagePack 16.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirD9w1UHYR/Assets1/Application/Cool Extras.localized/en_US/Templates/Film/Banner.ait" to "/Applications/Adobe Illustrator CS6/Cool Extras.localized/en_US/Templates/Film/Banner.ait" (Seq 67)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 67)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Illustrator CS6 Core_AdobeIllustrator16en_USLanguagePack: Install failed
ERROR: DW050:  - Adobe Illustrator CS6 Core: Failed due to Language Pack installation failure
ERROR: DW050:  - Acrobat Professional: Install failed
ERROR: DW050:  - Adobe Media Encoder CS6: Install failed
ERROR: DW050:  - Acrobat X Pro : Install failed
  • Sharad Saxena
    Apr 30, 2010
    May 17, 2012 4:58 AM   in reply to Pio Emilio Diaz
    Try if any of the following steps helps in resolving the problem -
    1) Run any OSX updates available
    2) Reboot the machine and quit any other application
    3) Download a fresh copy of installer and run it locally from your machine (not from an external drive)
    4) Run from a different admin account
    Please update if it solves your problem or share the complete log if you encounter any error.
    May 17, 2012 5:43 AM   in reply to Pio Emilio Diaz
    Can you enable the root user account and then install the software.
    support.apple.com/kb/ht1528
    May 29, 2012 4:43 AM   in reply to Pio Emilio Diaz
    I've the same problem.I've tried every possible trick (root user, adobe cleanup app, etc...) but the install procedure always fails during the installation of Illustrator.
    Should I have to order the physical DVD ? Is there any alternative solutions ?
    Thank you for the answer.
    May 29, 2012 4:47 AM   in reply to Caciotti
    Its hard to say until we don't see the log file or error summary.
    Your issue or error may vary from what is discussed here, Please provide us complete details and then only we will help you.
    May 29, 2012 9:23 AM   in reply to Manish-Sharma
    Here is the log file. The system is Mac Os X 10.7.4. I obtain the same error trying to install the whole suite or Illustrator by itself.
    Thank you very much for your support.
    Exit Code: 6
    Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DF027, DW063 ... WARNING: DS012 ...
    - 0 fatal error(s), 4 error(s), 4 warning(s)
    ----------- Payload: {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6 4.0.0.0 -----------
    WARNING: DS012: LocalizeFile: Localized string not found for locale 'it_IT' try fetching for en_US(Seq 21)
    WARNING: DS012: LocalizeFile: Localized string not found for locale 'it_IT' try fetching for en_US(Seq 22)
    ----------- Payload: {C7B1C1B3-368D-4C32-A818-83F1554EB398} AdobeColorCommonSetRGB CS6 4.0.0.0 -----------
    WARNING: DS012: LocalizeFile: Localized string not found for locale 'it_IT' try fetching for en_US(Seq 11)
    WARNING: DS012: LocalizeFile: Localized string not found for locale 'it_IT' try fetching for en_US(Seq 12)
    ----------- Payload: {AAF0D225-F129-40F2-916E-12E28DBD19ED} Adobe Illustrator CS6 Core 16.0.0.0 -----------
    ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirlawb0R4a/Assets1/Application/Adobe Illustrator.app/Contents/Frameworks/AdobeLinguistic.framework/Version s/3/AdobeLinguistic" to "/Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/AdobeLinguistic.framework/Version s/3/AdobeLinguistic" (Seq 1825)
    ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 1825)
    ERROR: DW050:  - Adobe Illustrator CS6 Core_AdobeIllustrator16it_ITLanguagePack: Install failed
    Jun 4, 2012 1:57 AM   in reply to Caciotti
    Reading carefully other threads, I've discovered that the installer I've downloaded from the license portal was fake.
    I've ordered the DVD supports and, voilà, using them it works. Please, fix the on-line file !
    Thank you for the support.
    Feb 13, 2013 10:14 AM   in reply to Caciotti
    I used a Adobe Installer DVD but have the same error message.
