tapping
Combine Several PDF Documents Programmatically
Mar 16, 2007 1:30 PM
I need to combine several pdf documents programmatically within Dreamweaver/Coldfusion. Will Acrobat's SDK software Developer kit allow you to do this outside Acrobat? Is SDK just for writing Javascript within Acrobat?
If I can't use SDK to write Javascript within Dreamweaver , then how else could I combine pdf files into one pdf within Dreamweaver?
    Mar 16, 2007 1:59 PM   in reply to tapping
    I'm a little confused about what you are trying to do. Are you 1) Trying to combine multiple PDF documents into 1 PDF document using coldfusion or 2) Use some sort of interface in dreamweaver to manually combine the PDF's?
    If the answer is #1 - check out CFX_PDF we use it a lot and it gives you a pretty easy interface for combining multiple PDFs into 1 PDF file
    If the answer is #2 - sorry, I don't have much experience in dreamweaver. Maybe someone else on the forum has some ideas.
    Mar 16, 2007 8:46 PM   in reply to tapping
    see this thread:
    http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=1 &catid=7&threadid=1114635&highlight_key=y&keyword1=iText
    Mar 20, 2007 7:54 AM   in reply to Newsgroup_User
    tapping wrote:
    > newPDF=createObject("java","java.io.FileOutputStream").init(finalOutP utFile);
    what's in finalOutPutFile?
    Mar 20, 2007 6:49 PM   in reply to Newsgroup_User
    tapping wrote:
    > newPDF=createObject("java","java.io.FileOutputStream").init(expandPat h(finalOut
    > PutFile));
    this bit is different from what you showed earlier, does it work now that you
    have an absolute path to the output file?
    May 29, 2012 6:56 AM   in reply to Newsgroup_User
    is CFX_PDF the best for cf devs?
    May 29, 2012 7:28 AM   in reply to nikos101
    This is an old thread.  Since it was written, the cfpdf tag has been added to ColdFusion.  That's what I would use.
    May 29, 2012 11:11 PM   in reply to nikos101
    Why go digging up threads that are more than 5 years old? You might as well ask your grandma.
    May 30, 2012 10:03 AM   in reply to BKBK
    ahahahah
