Converting Array and String
May 14, 2012 9:59 PM
Hello, everyone.
I'm given an Array, it is not in format {abc:1, qwe:'ghj'}. The array looks like this:
new Array(["SMTH", 1, 2, 3], ["ANTH", 0, 0, 0, [4, 5, 6]], ["ZZZ", 8])
As you can see, it has only square brackets, and even in other square brackets.
The task is:
1) Convert this Array to String, because server only saves strings. Save it.
2) Load saved String and convert it to Array.
So, a usual task for the game.
Please, tell me, in what Language they may be converted, what should I do.
1) I've tried to convert (1) Array to String, so that square brackets remain, even in another [], but AS3 removes them. Well, I wrote my own function. Now the result (1) looks exactly like you saw above in bold letters.
2) But another problem exists: how to convert that string to Array back...
Array.match() says there is no array, seems like it doesn't notice square brackets at all.
I've tried split, IndexOf and others, but got stuck in those [[]]
Simple myString as Array also doesn't work.
I suppose, I'm doing it all wrong. So i've tried converting Array to JSON. It turned out to be too much odd symbols, it was saved, but i have an limitation of symbols count, so JSON is not the answer.
    May 15, 2012 1:34 AM   in reply to XELAD111
    there is probably a cleaner way to do thisn using recursion but this will do what you ask for i think
    you could find solutions buy doign a google search for serialize
    package
              import flash.display.Sprite;
              public class Main5 extends Sprite
                        public function Main5()
                                  var array:Array = new Array(["SMTH", 1, 2, 3], ["ANTH", 0, 0, 0, [4, 5, 6]], ["ZZZ", 8]);
                                  trace("array: " + array);
                                  var string:String = convertToString(array);
                                  trace("string: " + string);
                                  var array2:Array = convertToArray(string);
                                  trace("array2: " + array2);
                        private function convertToString(array:Array):String
                                  var output:String = "";
                                  for (var i:int = 0; i < array.length; i++)
                                            var level1Items:Array = array[i] as Array;
                                            for (var j:int = 0; j < level1Items.length; j++)
                                                      var level1Item:* = level1Items[j];
                                                      if (level1Item is Array)
        for (var k:int = 0; k < level1Item.length; k++)
        output += level1Item[k];
        if (k < level1Item.length -1)
        output += ","
                                                      else
        output += level1Item;
        if (j < level1Items.length - 1)
        output += "|";
                                            if (i < array.length - 1)
                                                      output += "&";
                                  return output;
                        private function convertToArray(string:String):Array
                                  var output:Array = new Array();
                                  var level1Items:Array = string.split("&");
                                  for (var i:int = 0; i < level1Items.length; i++)
                                            output[i] = new Array();
                                            var level1Item:String = level1Items[i];
                                            var level2Items:Array = level1Item.split("|");
                                            for (var j:int = 0; j < level2Items.length; j++)
                                                      var level2Item:String = level2Items[j];
                                                      if (level2Item.indexOf(",") > -1)
        output[i][j] = new Array();
        var level3Items:Array = level2Item.split(",");
        for (var k:int = 0; k < level3Items.length; k++)
        output[i][j][k] = level3Items[k];
                                                      else
        output[i][j] = level2Item;
                                  return output;
    May 22, 2012 1:42 AM   in reply to XELAD111
    before converting the string to an array you could replace all the instances of &amp; with & using String.replace()
    May 22, 2012 10:17 AM   in reply to XELAD111
    You can convert each character to the ascii value using:
    arrayAscii[i] = c.charCodeAt(i);  //where c is a String, i the character place in the string
    And get back:
    String.fromCharCode(temp);
    May 28, 2012 4:29 AM   in reply to XELAD111
    Why not just use JSON?
    var jsonArray:String = JSON.stringify(array);
    var revivedArray:Array = JSON.parse(jsonArray) as Array;
    trace(revivedArray[1][4][2]); // traces "6"
    Kenneth Kawamoto
    http://www.materiaprima.co.uk/
    May 28, 2012 7:42 AM   in reply to XELAD111
    With
    String.fromCharCode(temp)    //where temp is a number
    you can recover the character from the ASCII code
    May 29, 2012 8:13 AM   in reply to XELAD111
    Almost all characters aren´t A-Z, a-z, 0-9,-_, be modified by HTML, mentioned as a solution convert to numbers, so is that I have solved your same problem on several projects, obviously using a character that mark separation between characters.
