davo56
settings for SD DVD output
May 29, 2012 9:06 AM
Hi
Is there any advantage in editing in 1080 x 50 if final product will be on SD DVD?
Norman
    May 29, 2012 9:16 AM   in reply to davo56
    I edit AVCHD and let Premiere Pro "down-rez" to DV AVI to create a DVD
    You should always edit in the "native" format for the best quality... then export to the format needed for your destination
    May 29, 2012 9:30 AM   in reply to davo56
    The disadvantage of doing so is that the media needs to be scaled.  That's best avoided whenever possible.
    If you will never need an HD version, I say shoot in SD.
    May 29, 2012 11:42 AM   in reply to davo56
    what sequence setting to use in premiere.
    Not sure about that.  I always take care to have all footage match specs (or at least frame rates).
    May 29, 2012 11:46 AM   in reply to davo56
    I would set it to 1080 25.
    Best setting for export is mpeg2-dvd high qualty, you can tweak the settings a bit.
    If you are on CS5.5 do not use DL it messes with the fields; export from Premiere.
    With CS6 you can use DL and set it to auto.
