I want to 'imprint' a shape with text. The result being that the words in that shape will show whatever background color the shape is placed upon.
Can someone please show me how to do this?
I asked this question a while ago but reading it back cannot uderstand it for the life of me!
many thanks,
Josh
You guys don't know no english well enought o knw not what somebody want to say you and can't undersstand no good english either what so wrong with you ! Huh!
the want an opcaity mask. The Op wrote it correctly bu it one of thise things that looks like it is worded oddly even though it is not all that way.
1. Set the text on top of the shape
2. select the sahpe and the text using a selection tool (not the type tool)
3. go to the transparency panel and select from the flyout menu Make Opcaity Mask (it might not look right att first)
4. Uncheck Clip if it is checked and make sure inverted is unchecked as well
5. Place the masked art over a shape(s) fill with a color fill(s).
You can resize the filled paths so the do not extend beyond the masked shape.
You are a funny guy Wade. True, my English sucks but at least I press that spell checker button so my ridiculous words are at least spelled correctly, I guess you and me should write the messages together to make posting perfect. ![]()
By the way, if the background objects don't overlap, what you showed, alternatively can be made with making a black text on a wide box and putting everything in front with lighten color blending mode.
Jacob think about what you just suggested and look aat your posted art?
Why would you make a clipping mask to fill type with a color when you can just fill it with any color just by selecting a swatch or color from the mixer.
It kind of doesn't make sense!
The Op wanted to place a shape the had text in it so that any color place behid it would fill or show through, if you read the the original posting carefully.
You end up wioth no shapeand if you put a color behind it the clipping maksk the type doesn't change color Unless you change the blending mode or give a trans parency.
Wade,
Josh is obviously looking for a solution that goes beyond merely colouring some Type.
Otherwise, someone would surely have suggested to just change its fill colour.
There is no limit to the use of a Clipping Mask in terms of colours, gradients, whatever, and the image just showed one simple case that fits the words, with only the back ground.
Now the image is extended to also show the shape in between. The term background implies that it extends beyond the shape so it is quite possible to select the Type (which is on top of the shape) and the background (that is under the shape) and create the Clipping Mask which will be on top, as shown in the lower part of the image.
Creating an Opacity Mask also works and is more fun to watch in the process.
But just selecting the Type and the background and Alt/Option+O+M+M (Object>Clipping Mask>Make) is a bit simpler after all.
Haha . . .
Anyway, Josh, it's very simple. We all get kinda noisy here some times, trying to innovate the best method, but I'm suggesting a quick destructive pathfinder operation.
By desctructive I mean it won't be a dynamic effect you can necessarily modify after you've committed to it. Compensate for this by making a copy of things before using the Pathfinder Panel.
Do this:
You're left with a knocked-out shape. Simpleasy.
Hey Tromboniator,
The image I am working on is below.
At the moment the letters you can see are just normal text in white. I want the letters to actually become part of the 'shape path' so that when I put the logo over say a grey background, both the letter and the gap between the shapes will show the background through them
Hope this makes more senses..
Josh
Josh,
If you want to have the full background, extending outside the shape parts shown as two separate parts, one with a solid colour and one with a gradient, you may just leave the gap between them as a gap that shows the background and let the live Type run across them and over the gap, and then:
A1) Copy the background in fornt of itself (Ctrl/Cmd+C+F), btoh the original and the copy being behind the shapes,
A2) Select the Type and the copy background and Object>Clipping Mask>Make (Alt/Option+O+M+M), leaving the original background (in the background).
which will create a mask with the right background appearance in front of the shapes, and is applicable for any appearance of the background, or if you have a background with a solid colour, you may:
B1) Just select the Type and change its Fill colour to that of the background.
