brakouskas
Can you change a Folio's orientation after it has been published?
May 29, 2012 12:43 PM
Tags: #update #folio #magazine #folio_builder #horizontal-only #dual-orientation #single-orientation #multi-issue_app
I see how to change from single to dual orientation when creating a new Folio. Is there a way to change from dual orientation to Horizontal-only after a Folio has been published?
If not, and I need to re-create the Folio:
1. Can I give it the same name, publication date, and product id?
2. Will it replace the already approved Folio in the multi-issue App?
3. Will it need to get approved by Apple again?
  • Bob Bringhurst
    May 29, 2007
    May 29, 2012 1:56 PM   in reply to brakouskas
    No, you can't change the orientation setting for a folio. Unpublish (if it's published) and delete the folio. Then create the new folio and publish it using the same name, publication date, etc. It will replace the already approved folio in the multi-issue app. It doesn't need to be approved by Apple again. If you set up your folder structure properly, it shouldn't take more than a few minutes.
  • Bob Bringhurst
    May 29, 2007
    May 29, 2012 2:33 PM   in reply to brakouskas
    That shouldn't happen in the Content Viewer. If you used the same metadata in the new folio that you used in the deleted folio, only the new folio should appear. If it's happening in the Content Viewer, it will likely happen in your viewer as well.
