onraglad
Premiere elements trial download problems
May 29, 2012 8:58 PM
I seem to have downloaded adobe premiere elements 10 but I can't extract it?  I keep getting this "invalid checksum" pop-up.
    May 30, 2012 5:47 AM   in reply to onraglad
    An invalid checksum indicates that the file might have gotten corrupt during download. This typically happens on very slow or unreliable connections.
    You could try downloading again and see if it works.
    What computer/OS are you using?
    You could also have a look at http://forums.adobe.com/thread/1006208. It has some more details why this error can occur and how to work around it.
    May 30, 2012 11:14 PM   in reply to onraglad
    If the download is completed in the Adobe Download Assistant you can temporarily turn off the feature to verify the checksum.  The following steps will allow you to temporarily disable this feature:
    1. Open the Disk Utility located in Applications/Utilities
    2. Go under the Disk Utility menu and select preferences
    3. Deselect the option to verify checksums
    4. Try mounting your DMG file
    I would recommend turning this feature back on though after the installation is complete.  Also if you notice this happening on additional files it can indicate a problem with your Internet connection.
