Null Text Field, how to prompt to fill in another text field
May 30, 2012 1:38 AM
I would like to be able to prompt the user to fill in either one of two text fields, If for example they fill in text field A, then no prompt would pop up, but if they didn't fill in text field A then a prompt would pop up asking them to fill in text field B.
    May 30, 2012 7:21 AM   in reply to sp215
    One way would be to place a JavaScript in the exit event of TextFieldA:
    if (this.rawValue === null) {
         xfa.host.messageBox("Please complete Text Field B", "Attention", 0, 0);
    However this will only fire when the user exits TextFieldA. You may need additional script if it is likely that the user does not even enter this text field.
    Niall
    May 30, 2012 7:27 AM   in reply to sp215
    Yes, you would use the same script in the same object, but you would just need to decide when this would be fired.
    For example, you might add the script to the prePrint event or the preSubmit event and see does this match the functionality you are looking for.
    Does that help?
    Niall
