Jarrant1
CSS files are not updating...Help!
May 24, 2012 10:38 PM
I can not get my CSS file to update. My chages are not reflected. The editor shows the new CSS in file manager but the file link shows the old version without changes. This is very frustrating!
    May 24, 2012 10:55 PM   in reply to Jarrant1
    The obvious answer is to refresh, refresh, refresh, but I am guessing you have done this already. Then purge your history and restart and refresh and so on. But you have probably done this also.
    Sometimes I find the best way is in fact to use the direct url to your CSS to check it is actually the correct one ie. http://yoursite.com/css/styles.css
    If your in Firefox using Firebug to inspect elements is also a great way to see what your stylesheets are doing.
    Last but not least change the file name of your css and ensure you relink. That means a fresh url not being cached by your ISP.
    That is the only advice I can give ebough though it is all the base solutions to check.
    May 30, 2012 10:15 AM   in reply to Jarrant1
    There was a hot-patch a couple days ago that seems to have fixed the problem. There are several threads about it in different places. As of yesterday I stopped seeing this problem.
  • Liam Dilley
    Feb 28, 2012
    May 30, 2012 12:51 PM   in reply to AlanGilbertson
    Considering a client spent 2 hours putting images that showed to be different on FTP too but not other website and one CSS for me yesterday just not actually rendering on the site, and that I heard from another partner stil with the problems.... Does not seem to have fixed it properly yet.
    May 31, 2012 1:35 AM   in reply to Jarrant1
    Hey,
    Can you please send me a PM with the files you are changing and are not viewing properly through the front-end of the site? If you could include a screenshot with the changes you have just made (how the file should look) and the method you used to edit the file (via FTP or the Admin Console or the new File Manager) it would be great.
    The hotpatch Alan mentioned above was targeting a different issue - templates or pages sometimes reverted to a previous version. That was a completely different issue (even though the manifestation might be similar to this one) and we have received confirmations it has been fixed.
