I would like to create a simple fast forward and rewind button. I am getting sporadic results with the rewind button. I would like the playhead to skip 3 seconds (72 frames) at a time when the user hits the fast forward or rewind button. They should be able to hit either buttons repeatedly. If playhead is under 3 seconds then it will go to the first frame.
Here's the code:
var FrameNumRewind:Number = this.currentFrame;
FrameNumRewind = 0
stage.addEventListener(MouseEvent.MOUSE_DOWN, page_watch);
function page_watch(event:MouseEvent):void
if (event.target == bnt_Fast)
var FrameNumFast:Number = this.currentFrame;
this.gotoAndPlay(FrameNumFast +=72);
if (event.target == bnt_Rewind)
//Will take the frame head to the first frame if less than 73 frames.
if(FrameNumRewind <=73)
SoundMixer.stopAll();
this.gotoAndPlay("1");}
else
this.gotoAndPlay(FrameNumRewind-=72);
What am I doing wrong? Is there a better way to do this?
I would appreaciate any help or any references.
You do not need to be using the two "Frame..." variables. You can use the currentFrame property instead. When you use specify this.gotoAndPlay("1"); you do not use quotation marks because the argument is a numeric value, not a string. You should assign the listeners to the buttons instead of the stage. Let each have its own event handler function. When you press down on the button assign an ENTER_FRAME listener to call a function for changing the frames, and when you release it, remove that ENTER_FRAME listener.
Ned,
Thanks for your response. But I am a bit confused by your response. Below is my interpretation of your response. There are still errors though but I don't know how to solve them. I only tested this for the fast foward button.
bnt_Fast.addEventListener(MouseEvent.MOUSE_DOWN, fastForwarda);
function fastForwarda (event:MouseEvent):void
stage.addEventListener(Event.ENTER_FRAME, ff72);
function ff72 (event:Event):void
this.gotoAndPlay(this.currentFrame +=72);
bnt_Fast.addEventListener(MouseEvent.MOUSE_UP, fastForwardb);
function fastForwardb (event:MouseEvent):void
stage.removeEventListener(Event.ENTER_FRAME, ff72);
One thing you should take care of is that you should not nest named functions within other functions. Pull that ff72 function out by itself.
The currentFrame property is a read-only property, but you are trying to change its value using code in this line...
So change that line to be
gotoAndPlay(currentFrame+72);
noticing that I took the "this." references out as well. They are more often unnecessary in AS3 scenarios.
Thanks Ned, it worked!
I also added a feature that will prevent the playhead from going to another scene if the current frame is <= 72 ( the number of frames it rewinds).
Here's the code for anyone's reference.
//Fastforward button code.
function fastForwarda(event:MouseEvent):void
function ff72(event:Event):void
if (watchSound_RayJayShort.play())
function fastForwardb(event:MouseEvent):void
//Rewind button code.
bnt_Rewind.addEventListener(MouseEvent.MOUSE_DOWN, rewinda);
function rewinda(event:MouseEvent):void
stage.addEventListener(Event.ENTER_FRAME, r72);
function r72(event:Event):void
if (currentFrame <=72)
gotoAndPlay(1);
else
gotoAndPlay(currentFrame-72);
bnt_Rewind.addEventListener(MouseEvent.MOUSE_UP, rewindb);
function rewindb(event:MouseEvent):void
stage.removeEventListener(Event.ENTER_FRAME, r72);
