The "Defringe All Edges" function has gone missing and some new controls have taken its place.
Here's a side by side comparison of some palm fronds against a bright sky with the new controls on their defaults... Camera Raw 6.7 on the left with Defringe All Edges set, and Camera Raw 7.1 RC on the right. There's more color fringing in the new conversion, since the Defringe All Edges doesn't cover up the Bayer artifacts.
In experimenting, I found I can turn the "Green Amount" slider up off zero and move the color range of the "Greens" defringing over into the Cyan-ish area, which mitigates this.
Is it the intention that with the use of these two color range controls we should be able to produce results as good as with the older code and the Defringe All Edges feature enabled? I'm not saying the newer version isn't as good or better - I'm just trying to understand the intent.
I'm certainly going to need to do some careful comparitive testing to determine the best defaults.
-Noel
As far as I can see, it works similar as before. There were just two strengths and fixed hue range before (I suppose), now you have separate pair of sliders for 2 hue ranges and finer control of strength. Tried on some Canon SX110 raws and works very well. Old version wasn't effective enough because amount of fringing is sometimes huge on this cheap 10x zoom lens. The same with 400D kit lens. I've been waiting for this for years
However, although authomatic CA removal is working good so far, maybe it would be fine to have slider as an option in lens profile section
This version is out only for several days and it wasn't announced on sites like dpreview etc. I discovered it today after reading your post
As about defringe slider in local adjustments someone asked a few days ago (for LR) - it works like sliders for sharpness, NR etc in local adjustments - correcting global amount of defringe for local area - so numbers are different
SSprengel, do you find specifically that the new controls don't allow you to eliminate it, while the old one did?
I seem to be able to get color (e.g., the sky color in the image above) in tigher places than I used to, so it may not be all bad. Better subject color could offset a little fringing and be a net gain.
-Noel
Hi Rob,
Camera Raw 7.1 finally presented the controls to us Photoshop users that you were talking about the other day in the context of Lightroom. And now it's clear what you were talking about.
What you say makes sense, though what doesn't make all THAT much sense is a design that presents one color-range for one set of controls but unconstrained color for the other set. ![]()
-Noel
Hey Noel,
I'm not qualified to answer definitively, but my .02: the local defringing has a built in eye-dropper - i.e. it's "adaptive" - i.e. whatever color is fringing in the painted area is the color you're trying to remove. So, the globals need constraints, but the locals - not so much.
I've mostly used the local defringing - carefully and successfully. The globals often do more harm than good still, unless the target fringe is really a consistent/unique color... - has been my experience. "Mostly blue" fringing around tree leaves in a blue sky is hard to remove with the global... "Truly purple" fringing is more easily removed...
R
Okay, I've had more time to look at this... It seems to me that Photoshop CS6's Camera Raw 7.1 beta is not as good as its predecessors at achieving a balance between good color and defringing.
Note the following three images, excerpted from a Canon 40D raw file, which can be found here.
Converted in Ps CS4, ACR 5.7:
Converted in Ps CS5, ACR 6.7:
Converted in Ps CS6, ACR 7.1 beta:
The specific color fringing I'm struggling with is the remnant Bayer pattern colors.
Here's a 400% zoom in on several problem areas. You can see the color-fringing I'm talking about on the left, and amongst the dark letters.
Now, it's clear that the results are dependent on the settings, but I guess the one thing I want to point out is that for the ACR 7.1 beta conversion I have actually dialed-in some defringing, which is more aggressive than the out-of-box default - and I'm not sure I want to make it more aggressive.
It seems to me the "Defringe All Edges" feature better compensated for the Bayer Pattern color fringing than this new code does. I will continue to experiment to see if I can find a better set of defaults...
Defringe: All Edges was a good feature. I'm sorry to see it go.
-Noel
Thanks, Vit. Yes, the Moire Reduction does work quite well on this kind of fringing. But I really want to have Camera Raw 7 work as well as or better than its predecessor on default settings and on all edges.
The new Defringe process is *almost* as good. And turning it up higher isn't really an option, as you have shown with your post on CA correction.
Since posting the above I have tweaked the defaults I have set, and the difference between 6.7 (with Defringe All Edges) and 7.1 with my defaults is now very small, and with some improvements in other characteristics, so I think I'm pretty happy.
-Noel
Hi Dorin,
There is some debayering color pattern in each conversion, but the Defringe: All Edges function makes it less in the CS4 and CS5 conversions. That's not a default setting. Without that setting, there's slightly more such color inaccuracy around edges in CS6 conversions.
Yes, I double checked my settings:
-Noel
I have decided to drop back to 7.0.
The Defringe function in Camera Raw 7.1 RC creates some truly awful columnar color artifacts, such as those seen here in this 200% Nearest Neighbor enlargement of a Camera Raw processed image.
You Adobe folks need to rethink this change. It's absolutely NO better than its predecessor in any way.
-Noel
Noel,
How do you propose to "drop back"?
Do you propose simply to substitute the 7.0 "Camera Raw.8bi" for the 7.1, or do you intend to reinstall PsCS6?
The reason I ask is that I recollect reading recently somewhere in this forum, I think it may have been Eric Chan but can't be sure, that with CS6 it is no longer possible to roll back from one version of ACR to another simply with a plugin substitution because there are now other relevant files involved.
Glad to hear that the plugin substitution does in fact work - its always good to have that capability as a safety valve.
I don't know for sure where I read that it wouldn't work but I'm damn sure that I read something to that effect somewhere and from someone who I regarded as a reliable source. Ah well, seems the old memory is not what it used to be.![]()
I had to dig the geeky hex code-named resources out of the Photoshop release distribution and rename them Camera Raw.8bi for both 32 and 64 bit plug-ins, but all indications are that it does work without a downside. I've reset my Camera Raw default preferences back to use the Defringe: All Edges feature and that's very satisfying.
I won't be updating to any of the newer versions if Adobe doesn't deal with the problems they're introducing, and even if they do I may not update if they don't provide access to the older defringing feature as an option.
It's just silly to release a new version that drops essential features and doesn't have the ability to create as good a conversion as what's already released. But we can rest assured they're going to release 7.1 just as we've seen it, because that's just the way they do business.
Adobe, you need to change your processes so that feedback from beta testing can actually be applied to your software before that software is released.
FYI, I didn't see a speed difference as Vit did.
-Noel
All the problems still appear to exist in 7.1.
The features removed without acceptable substitutes are still missing, with no option to select them.
Adobe: You need to heed the feedback from folks kind enough to test your beta software and actually fix what you’ve done wrong before actually releasing it.
-Noel
