I have a button that keeps blowing up my code
May 30, 2012 8:27 AM
can someone take a look and tell me why? I have imported the classes
package {
import flash.display.MovieClip;
import flash.net.URLLoader;
import flash.net.URLRequest;
import flash.events.Event;
    import com.yahoo.astra.fl.controls.Tree;
import com.yahoo.astra.fl.controls.treeClasses.*;
import flash.events.MouseEvent;
import fl.controls.Button;
public class VideoPlaylistNoThumb extends MovieClip {
  private var xmlLoader:URLLoader;
  public var btnNext:Button;
  //btnNext.label = "Next";
  public function VideoPlaylistNoThumb():void {
   // Load the playlist file, then initialize the media player.
   xmlLoader = new URLLoader();
   xmlLoader.addEventListener(Event.COMPLETE, initMediaPlayer);
   xmlLoader.load(new URLRequest("playlist2.xml"));
  public function initMediaPlayer(event:Event):void {
   var myXML:XML = new XML(xmlLoader.data);
   var item:XML;
   for each(item in myXML.vid) { // populate playlist.
    // Send data to List.
    videoList.addItem({label:item.attribute("desc").toXMLString(),
    data:item.attribute("src").toXMLString(),
    data:item.attribute("id").toXMLString(),
    data:item.attribute("wNnext").toXMLString(),
    data:item.attribute("aNext").toXMLString(),
    data:item.attribute("allNext").toXMLString(),
    ttURL:item.attribute("ttURL").toXMLString()});
   // Select the first video.
   videoList.selectedIndex = 0;
   myVid.autoRewind = true;
   // Listen for item selection.
   videoList.addEventListener(Event.CHANGE, listListener);
   // And automatically load it into myVid.
   myVid.source = videoList.selectedItem.data;
   myVidCaptioning.source = videoList.selectedItem.ttURL;
   myVidCaptioning.flvPlayback = myVid;
   // Pause video until selected or played.
   //myVid.pause();
  // Detect when new video is selected, and play it
  function listListener(event:Event):void {
   myVid.stop();
   myVidCaptioning.source = event.target.selectedItem.ttURL;
   myVidCaptioning.showCaptions = false;
   myVidCaptioning.showCaptions = true;
   myVid.autoPlay = true;
   myVid.play(event.target.selectedItem.data);
   function clickHandler(event:MouseEvent):void {
      trace("I have been clicked");
  btnNext.addEventListener(MouseEvent.CLICK, clickHandler);
It is not recognizing btnNext
    May 30, 2012 9:27 AM   in reply to dpattersonCBT
    What kind of button you're using whatever turn it into the library symbol and a name asiganela "As Linkage", something like myButton
    and in your code
      public var btnNext: myButton = new myButton ();
       addChild (btnNext);
    May 30, 2012 9:58 AM   in reply to dpattersonCBT
    ok, in the library click the right button on your btnNext symbol, then select the option "Properties", then select "advanced" (bottom left), then check "Export for ActionScript", and in the field Class type:
    myButton
    Now use the code before you send
    May 30, 2012 10:29 AM   in reply to dpattersonCBT
    Maybe you need a constructor
      public var btnNext:myButton ;
      public funtion VideoPlaylistNoThumb():void{
           btnNext= new myButton ();
          addChild (btnNext);
    //more code
    Jun 1, 2012 2:26 PM   in reply to dpattersonCBT
    if your button is already part of the display list, you can probably remove public var btnNext:Button; ... and just go back to your original code, forget all the other responses, and add the button listener here instead:
    however, if your button is NOT already part of the display list, you DO need public var btnNext:Button; and then you'd have to ADD it to the display list like this:
              btnNext = new btnNext();
              addChild(btnNext);
    keep in mind that the btnNext will need the actionscript linkage identifier "btnNext" and check the box for "export for actionscript" and "export in frame 1" ... you can set these in the properties of the library symbol.
