Q: What is the Adobe Download Assistant?
A: Trial versions of Adobe Creative Suite, Photoshop Elements, and Adobe Premiere Elements are downloaded using the Adobe Download Assistant — a small application that is meant to improve download reliability and avoid issues that commonly occur during large downloads, such as frequent disconnects. After the trial product is downloaded, Adobe Download Assistant should automatically start installing the product.
Q: I installed the Adobe Download Assistant, but my trial didn't download?
A: Under certain conditions, the Adobe Download Assistant installs but does not immediately start downloading the trial product. If this happens:
1. Quit the Adobe Download Assistant.
2. In your browser, return to the product trial download page on Adobe.com. Refresh the page, then click the Download now button again and follow the prompts.
Important: When you start the download, be sure to select your User folder or Desktop folder. A common cause of errors are due to attempts to download the Adobe Download Assistant to the Program Files/Applications folder. The Adobe Download Assistant only downloads the trial application files. Once the download is complete it will launch the application installer; when the installer is launched you can then choose to install the actual trial application into the Program Files/Application folder.
For more info, see
Troubleshoot Adobe Download Assistant
or
Q: I've have a problem on Windows 7. The download manager just sits there, and does nothing, even after I navigate back to the trial page. It turns out that you can't install Flash in the Programs folder. You have to pick a different folder for ADA to actually work?
A: You are correct, the Adobe Download Assistant does not have sufficient permission to save files to the Program Files folder. If you run the Adobe Download Assistant as an administrator, or save to a different location (for example, in your Users folder), this should resolve the issue.
Q: When I try and download the Creative Suite Design Premium the Download Assistant opens and I log in. On the top it says "Welcome, User" but on the bottom right below the action bar for the download it says "Sign in ith your Adobe ID to continue" and the action/download bar just sits there. I have quit and restarted numerous times and even left it running all night. Nothing is working though. I have Windows 7 Home Premium and see no error messages.
A: Try opening your browser by right-clicking in the start-programs menu and select "Run as Administrator".
Q: I am trying to download the Premiere trial version onto Windows. I had no issues installing Adobe Download Assistant, however when I tried to log in, it came up with error 100, claiming it could not communicate with the internet.
A: Many of the errors which forum users are experiencing with the download process is due to trying to download to the Program Files/Applications folder. This seems to cause Error 100, 101, 107, and even problems with being able to extract the install files after the download completes. The Adobe Download Assistant is only downloading the install files. Once the download is complete it will then launch the installer. Once the installer itself is launched you can then install to the Program Files/Application folder.
Q: I've tried everything and nothing works. I'm really frustrated and I don't know what else to do. How can I download a trial?
A: Another way to get trials of Adobe software is to sign-up for a Free Creative Cloud Membership. With Creative Cloud Membership you can download full, downloadable 30-day trials of all our CS6 Master Collection straight to your desktop, and store up to 2GB of files. Alternately, you can review http://forums.adobe.com/thread/981369 which provides information on how to obtain direct downloads.
The download has not been iniciated properly using Adobe Download Assistant. You can have look on this related forum. http://forums.adobe.com/message/4468540
Alternately you can follow the steps listed at http://forums.adobe.com/thread/981369 to initiate a direct download.
Contact Adobe Support(http://www.adobe.com/support/contact/) or Chat Support(http://www.adobe.com/support/download-install/supportinfo/)
I have suddenly become computer illiterate... that's the only conclusion I can draw from my total failure to install the Premiere Pro CS6 trial version for Mac.
Step1: I downloaded the Adobe Downloader Assistant installer and installed ADA in the default location (/Applications), which then was followed by said ADA launch. I logged in, selected PP and started a 2 hrs download of a 1.7 GB file.
Step2: I come back after a while and find a nice DVD icon on my Desktop, reading PP CS6: Great! I quit ADA and open that folder, to find another folder in it, with 3 subfolders and an "Install" application. Click on it. Nada. Reclick on it. Same + an error -1704 "can't open application".
Step3-30: I am cutting a long story short, but after reading all the support threads I could find, trying to reinstall ADA on my desktop, relog on the website, restart and cancel PP CS6 download a few times (without ADA noticing that there was already a 1.7 GB corresponding to that same file), and repeatedly failed to launch the install.app, I decided to act stupidely and remove all files and go to:
Step 31: reinstall ADA, re-download PP CS6.
Step 32: I waited after the install, nothing happened so I went to the new PP CS6 "DVD" and found the "install" app, which reliably did not start anything.
Step 33: I rebooted. After the reboot, the DVD was gone, replaced by an empty folder of the same name...
Step 34: me typing all this... I am using a 2011 iMac running Lion and Creative Suite CS 5.5. Thanks for any pointers...
Uwxplorer have you tried initiating a direct download per the link Manish offered in message #3?
Btw the likely cause of your issue is choosing the Applications folder to download your install files too. The Adobe Download Assistant does not have sufficient permissions to write to this folder since it is not installing an application just downloading the install files.
Jeff,
as I said, I read the support threads and discovered this "Applications Folder" subtlety and tried to work around it as described. BTW, as I mentioned, the default folder the ADA seems to want to install itself in is "Applications"... So unless Apple is providing zero flexibility to third-party installers, maybe that would be a first fix to apply to the ADA, don't you think?
Basically, you are telling me I wasted my time downloading the 1.7 GB twice as instructed using the tools provided by Adobe, and there is no fix to it except for just ignoring that "recommended" approach and using the alternate one...
Will try and report any problems.
Thanks.
Uwxplorer the Adobe Download Assistant installs itself to the Applications folder. The default to download the install files though is to the User folder. I recommended the alternate approach as it appears from this thread you have already spent considerable time trying to utilize the Adobe Download Assistant.
If you would like to continue with using the Adobe Download Assistant though then I would recommend completing solution 1 in Troubleshoot Adobe Download Assistant - http://helpx.adobe.com/creative-suite/kb/troubleshoot-download-assista nt.html#main_Solution_1 to reset the downloading experience. As previously discussed you will want to choose the default location of the User folder for your download location for your install files when reinitiating the download.
I did download directly. That worked. Now I am reading this thread, as I was welcome by a "serious error" crash right in the middle at the start of my first project...
Excellent happy to hear you were able to download successfully. It also looks like you have located the appropriate thread for your error. You may also want to try searching the Premiere Pro CS5, CS5.5, & CS6 forum - http://forums.adobe.com/community/premiere/premierepro_current to see if there is any other threads discussing your difficulties.
Hello.
I have tried to install CS6 trial twice, with each attempt connected to an independent download of the 5.9GB installer to a different location. I'm getting the same error with both the default destination (users folder) and a different location (dowloads folder). When the installer opens the .dmg file, the checksum verrification fails. I can still mount the installer by skipping the verrification, but then when I try to install just one of the applications, speed grade, for example, the installer fails with this error:
Exit Code: 15
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 2 error(s), 0 warning(s)
ERROR: ASU has quit unexpectedly.
ERROR: Media DB Error : 18
I have tried the 5-hour download twice with the same results. What is wrong with the installer download data?
Ben Hopkins
Benjamin Hopkins do you receive any message within the Adobe Download Assistant such as the download is still extracting? I would recommend you try initiating a direct download following the steps listed in http://forums.adobe.com/thread/981369.
I also received the Error #101. It is very frustrating. I thought I would try Adobe because I was having trouble with Roxio and AVS locking up or shutting down. I have a Very robust new computer, iCore 7, 16GB ram, 1 TB hard drive.
I guess I will go back to Roxio, at least is has downloaded successfully to my computer.
Kimberkam and additional posters please make sure to review this thread in it's entirety prior to posting. Almost all issues regarding downloading the software are covered in this thread. There have been several posts now where users are requesting the same information which has already been covered.
If you have tried the steps in this message thread and are still facing difficulties then we need additional details to help you. Please provide the following:
I have LITERALLY spent all day TWICE now trying to install the trial version of CS6. I got an error message both times, even after I shut down everything on my computer during the install.... I still get a message after waiting while it installs and initializes, etc. which says, Installation Failed.Installer failed to initialize. Try again after shutting down your anti-virus and firewall (WHICH I HAD DONE AFTER THE FIRST ATTEMPT GAVE ME THIS ERROR.) I am BEYOND frustrated and aggravated.... can you help me???
PLEASE HELP ME: I did the direct download for Adobe Premiere free trial and just as it was in the last stages of installing it (this is after waiting 40+ minutes for the folder to download) it just completely vanished. I tried downloading it again, waiting another 30-40 minutes, where it told me "another adobe installer program is already running, close all adobe installers and retry". Now it won't let me open anything, and there is NO adobe installer program running. I am absolutely aggravated after waiting an hour and a half for nothing, and I'm about ready to give up on adobe. Thanks for the waste of time...
Bruhn9 did you have a specific inquiry regarding downloading the trial version? You may want to search through the responses which are already available in the Trial Download & Install FAQ forum - http://forums.adobe.com/community/download_install_setup/ada_faq?view= overview.
Locking this discussion as all of the recent posts have been previously discussed or are covered within the linked support documents in the original message. If you still have an outstanding inquiry after reviewing this discussion thread then please post to either of the following relevant forums:
Downloading, Installing, Setting up forum - http://forums.adobe.com/community/download_install_setup
When posting please include the following information:
