wizbard
Trouble with search form recordset WHERE...AND clause
May 14, 2012 3:53 PM
Tags: #dreamweaver_cs5.5 #recordset #search_box
Hi, I have created a member directory 'memb_directory' page with a repeating table and added a 'lastName' search box that works just fine as long as I use the simple, one variable recordset format ('rsMemDir') in Dreamweaver 5.5. But I need to have it only return those names for whom the 'member_pub' boolean field in the MySQL database = 1 (checkbox is checked) and for the life of me, I've tried every 'WHERE ... AND' SQL statement permutation I can think of, but keep getting an "internal server error" response as DW analyzes the code. Any leads much appreciated.
    May 15, 2012 11:10 AM   in reply to wizbard
    Please show us the SQL string you are trying to use.
    May 21, 2012 3:52 PM   in reply to wizbard
    You just need to use parenthesis to control the order of operations.
    SELECT *
    FROM member
    WHERE member_pub = 1 AND (lastName like %colname% OR firstName like %colname%  OR emailLogin = %colname%)
    ORDER BY lastName ASC
    SQL WHERE clauses use basic PEMDAS rules to combine operations. In boolean algebra, AND is equivalent to multiplication, while OR is addition.
    May 29, 2012 11:28 AM   in reply to wizbard
    Please show us
    1) The sql statement you are using
    2) the value of the search string you are testing
    3) an example of the results you are getting
    May 29, 2012 12:57 PM   in reply to wizbard
    But what is the value of the search string submitted when those results are displayed? You might want to use an echo statement to verify that. Also, you are using wildcards with the equality operator for the email_login, which is not valid. Either use the LIKE predicate, or remove the wildcard characters.
    May 30, 2012 2:27 PM   in reply to wizbard
    It doesn't appear that you are using those other fields. You are populating only one variable and using that for all 3 conditions in the WHERE clause.
    $colname_rsMemDir = "-1";
    if (isset($_GET['searchStr'])) {
      $colname_rsMemDir = $_GET['searchStr'];
    May 30, 2012 3:53 PM   in reply to wizbard
    You got it.
    May 31, 2012 3:04 PM   in reply to wizbard
    Please echo the value of $query_rsMemDir after it is populated, and also attach the url querystring so we can see how the values are populated from the form.
    May 31, 2012 3:48 PM   in reply to wizbard
    OK, there's your problem. First of all, I'm not a php programmer.
    >$colname3_rsMemDir = "-1";
    Here you are setting the default value to -1.
    >if (isset($_GET['searchStr3'])) {
    >  $colname3_rsMemDir = $_GET['searchStr3'];
    Here you test if the field is set. If it is, you assign it to the variable, otherwise you keep the default value. Problem is that is appears isset() considers the empty string as set. So you really need to test if isset() and not equal to the empty string (!=""). Or consider using the empty() function rather than isset(). Again, I'm not a php programmer so I don't know if one method is better than another.
