http://fmsguru.com/showtutorial.cfm?tutorialID=13
this is good tutorial, but not working to me.
(i'm using windows server 2008, FMS 4, flash player 10.2)
but i change to <SWFVerification enabled="true"> this is working
status is info:
NetConnection.Connect.Rejected
NetConnection.Connect.Closed ,
----ok fine, working.
Next i add swf file in SWFs folder
but i getting same status:
is info:
i'm checked this things
* Restart server & applications
* swf name
* path
but no use, what am i do wrong?
You might have already checked this but just to confirm, the default SWF folder location is FMS_root_install/applications/<your-application/SWFs or you have to use the <SWFFolder></SWFFolder> tag to specify your location.
Can you please share your configuration?
Apurva
already i create SWFs folder in "applications/<my-application/ " directory - same to same.
which configuration can i share with you. (already i gave)
