problem with long load times after 6.0.1 update
May 25, 2012 9:51 AM
  Latest reply: genefama, May 31, 2012 8:48 PM
Branched from an earlier discussion. Branched to a new discussion.
Replies 1 2 Previous Next
    May 31, 2012 8:48 AM   in reply to Jim Simon
    Just unquartine the file and move on with your lives. I can't believe all the horrible advice being given in this forum. Reinstall Windows? What are you people running, a 13 year old OS, like XP? c'mon people.
    May 31, 2012 8:54 AM   in reply to gishnetwork
    Nobody is stopping you to move on.
    May 31, 2012 9:04 AM   in reply to gishnetwork
    Well, it's not terrible advice, especially the way a lot of users will install 100 different pieces of garbage from places on the Internet even Al Gore doesn't know exist.
    Of course I realize you're joking, but naturally you wouldn't be able to install CS6 on WinXP. Just for the record.
    FWIW, it's not like it takes more than about 2 hours of watching TV to wipe and reinstall. It's a good way of freshing up a system or getting rid of evidence....errr, I mean, old registry entries.
    Where did I keep those encrypted top-secret government conspiracy files anyway....?
    May 31, 2012 9:09 AM   in reply to Harm Millaard
    Oh okay Harm. I'll do that. It's clear you want bad advice to be given instead of countered so that the ultimately correct advice bubbles up.
    I misread his advice, it's actually great. Every time Adobe comes out with a new CS suite, reinstall your entire computer from Windows on up.  Silly me. Spread the word.
    Oh, and the Adobe employee whose reponse was basically "Well, you don't have to use Norton AV now do you?". Awesome... Great advice. How many thousands of files are in the in the suite, and the forward looking heuristics catches a single file... Yeah, great advice Adobe, let's point the finger at someone who is not even clearly at fault for incorrectly catching something at a rate of a fraction of a fraction of a percent.
    May 31, 2012 9:27 AM   in reply to gishnetwork
    Todd stated: "you have several options---and one of them is to not use that antivirus software"
    Generally speaking, if you're using quotation marks it should be an actual quote. Paraphrasing usually entails using brackets, such as saying "you have [limited] options---and [your best option] is to not use [Norton AV]"
    I suppose I could further restate Todd's comments as "you have several options---and one of them is to note use that antivirus software [while another option would be to learn how to actually use the antivirus software that you have installed on your system so you know how to deal with situations where the antivirus software has made an error and you need to correct it]."
    Todd was fair, didn't point the finger, just mentioned what is probably the quickest solution when no other solutions were currently known. Clearly the problem here, as admitted by Norton explicitly, is that there are some unintended results from the way Norton software finds and quarantines files, and the solution lies in the proper management of the AV software not the various 3rd party applications running on the same system. That's all it is...understanding how your AV software works and knowing how to use the AV tool itself to undo errors in reporting and quarantining. It is because of this sort of conflict that Norton allows you to override it's process in the first place.
    It's not an Adobe vs. Norton thing, it's just how heuristics work. As Ron Bugundy might say, "60% of the time, it works every time."
    May 31, 2012 9:41 AM   in reply to gishnetwork
    That's not such a bad thing to do if you don't need the older versions any more.  You start with a fresh, uncluttered system.
    I'm not suggesting it's necessary, but it can be a good way to start when a new CS suite comes out.
    May 31, 2012 9:45 AM   in reply to Christian Jolly
    Which is why I prefixed it with "basically". Brackets only apply if you are paraphrasing inside a quote. I paraphrased his entire statement, noting that I am transforming what he said by first stating "basically".
    Todd was not fair. He knew what the issue was and how to solve it - simply unquarantine the file. Instead of stating that, he comes up with some advice of, basically, "how about not using that software then".
    What if Photoshop caused Windows to crash because of some simple little config issue, but instead of illustrating that one just needs to change a config, a Microsoft employee says "If a piece of software is interferring with your use of Windows, you of course, don't have to use that software, now do you?". Problem solved.
    My issue with Todds comment is that there was easier and more concise advice to be given, and I expect more from an Adobe employee.
    May 31, 2012 9:52 AM   in reply to gishnetwork
    That's not a very good analogy because Photoshop is widely recognized as the best photo editor on the planet.  There isn't any other software that can compete with the feature set of Photoshop.
    Whereas Norton is widely recognized as very problematic for a great many users, and best avoided at all costs if you want a truly efficient and well functioning system.
    May 31, 2012 10:00 AM   in reply to Jim Simon
    I guess its horses for courses, Ive used Norton for must be 20+ years, never had any main problems, and if it flags up a potential problem that turns out to be ok, I have no problem with that. Much better than a virus getting through.
    Chris
    May 31, 2012 10:04 AM   in reply to Jim Simon
    This is not true. Maybe, at some point in the past this may have been true, but it is not now. I've been using it for 3 years across hundreds of systems, and never had an issue. This is not even an issue, it was a forward-looking guess that caught something. Like someone else said, basically, similar to, and wholly like - [I'd rather have it catch a few too many than a few too little.] (I don't want the english teacher to get on me so I covered all my bases).
    Why don't you enlighten us as to what AV is good then? Then I can search it in the Adobe foums, and check the AV's performance rating to verify that whatever you reccomend doesn't cause problems for Adobe's users, users in general, and still does a good job at protecting.
    May 31, 2012 10:18 AM   in reply to gishnetwork
    I think Norton has always done a GOOD job at what it does, and my problems with Norton - along with many others - has nothing to do with how well it cleans and protects a system.
    I haven't used it in 3 or 4 years myself because it did use to be pretty overwhelming on a system. And many users disliked how very nearly impossible it was to actually remove it from the system. Again, this has nothing to do with the effectiveness of the product but rather the management of computer resources.
    I personally found that other software out there suited my needs just as well. I currently run Microsoft Security Essentials becuase it is free, effective, and does not eat my system resources alive. I would recommend it to anybody, but I would not suggest that it is as COMPREHENSIVE as Norton (because it is not, but for many users like myself, the most comprehensive tool is not what is needed...this is why so many different tools exist).
    If I were having trouble with MS Security Essentials I'd look elsewhere, but I'm fine for now. I have had to manually correct it from time to time, but I've not "blamed" the software for doing it's job, nor blamed other programs for acting in a way that my anti-virus thinks is suspect. I just fix it and move on.
    Norton has a bad reputation for a reason, it's well documented on the web and not just imaginary (and to some degree, the same can be said for McAfee). The things that left a bad taste in people's mouths 4 years ago may have been resolved but like me, many people may have found other solutions that work very well for them and give no reason to go back to Norton at the present time.
    You say Norton works well for you and that is fine, but on the original topic of this thread, don't expect it to be perfect, and understand that it may make a mistake once in a while that requires you to intervene.
    May 31, 2012 10:33 AM   in reply to Christian Jolly
    Norton used to be a hog. But it rebuilt it's engine from the ground up a few years ago. I reccomend MSSE for consumers, but not businesses, we research AV's annually, and Norton (plain ole AV) has been the best performer for the price for 3 years.
    The original topic of the thread was an issue happening today. I am countering what other people have brought into the conversation, runner up advice formed against something that is no longer the currency.
    #1 Nothing wrong with Norton. (believe me, 5 years ago I wouldn't believe you if you said I'd be defending Norton).
    #2 Windows does not need a reinstall.
    May 31, 2012 8:48 PM   in reply to gishnetwork
    Solid software works under combat conditions.  If you find yourself repurposing your system in hopes of making a new program work, you're likely to make everything else work as poorly as the new program. Norton's been around since the 80's.  CS6 is two weeks old.
1 2 Previous Next
Actions
