Can’t drag *without* duplicating!
May 31, 2012 9:34 AM
Tags: #mac #cs5.5 #flash_cs5.5
Whenever I drag a shape with the Selection or Free Transform tool, the shape I'm dragging gets duplicated. It's like Flash thinks I'm holding down the Option key when I'm not. This quick video shows the problem: http://www.erikphansen.com/flash-selection-tool.mov
Rebooting doesn't fix it. But I just discovered that using Flash from a Guest user account on my Mac works. So there's a preference somewhere that's screwed up.
Ideas?
I'm on a MBP running OS 10.7.4 and whatever the latest Flash CS 5.5 is.
Thanks a lot,
Erik
    May 31, 2012 9:43 AM   in reply to ErikPHansen
    drag and duplicate, it is when you let down the Control key (at least so it is in windows), you may be a keyboard problem
    May 31, 2012 10:07 AM   in reply to ErikPHansen
    Starting Flash and immediately holding CTRL+ALT+SHIFT on Windows pops up the clear all flash pro settings dialog. Perhaps try that (your alt being option, so CTRL+OPT+SHIFT). If it works a dialog will pop up immediately asking if you want to clear pro configs.
