Same question, different problem. Our military contractor requires that the blank page be completely blank - no page number - nothing. However, the previous page must indicate that the next page is blank, as in 2-1 (2-2 blank) (in the footer/page number). I can't figure out how to advance the page number (2-2). We inherited this document, and the previous owner had a different master page for every page that required this notification (over 100 master pages!). There's got to be a better way, but I haven't been able to figure it out.
Thank you, Luca.
To Jive: Wow. That's a new one on me.
I guess you will need to create a master page with no headers or footers, but I don't know how you would program the page numbers into the last page of the document (for example, 2-2 blank). That wacky military. I just finished a military contract, which is why I needed to learn how to do the page intentionally blank in the first place.
I guess you could follow my directions for creating the TPILB, but leave the frame that contains the words "Page intentionally left blank" empty. That would solve your advancing the page issue and you could remove the headers and footers from the master page with the blank frame. But I'm stumped when it comes to adding the text to reflect what the next page number will be. Sorry. I'll think about this and try to find a solution...
By the way, if anyone knows of anyone hiring a very experienced writer in MD or VA, please let me know (how's that for a shameless plug??).
Hi all! I am using FM 8 and I was able to apply this rule, but for some reason, it does not apply to my TOC file or to pages where I only have tables (even though I have included the formats used there in the mapping table). Does anybody know what I'm doing wrong??
This is how I've automatically applied the TPILB at the end of my even page chapters:
Thanks in advance for your help!
Hello Joe,
If blank pages are being inserted, it's probably because the settings in the book template. You can make the book single page or double page. If it's double pages, it will insert the blank pages so that your chapters start on an odd page number for printing purposes. I don't have FrameMaker in front of me, so I can't tell you the exact steps, but if you click your book and click settings, you should be able to fix that issue.
Let me know if that solves your issue.
Megan
Hello Joe,
Sounds like there are elements being inherited from files somewhere.
Did you try this?
When you generate and update a book, the files in the book inherit structure information from the book file. A file’s Element Catalog may have inclusions and exclusions from the book, and other inherited information in the file may affect the formatting of its text elements.
If you delete a file from a book to use the file as a stand-alone document, reapply the file’s element definitions to remove any structure information that came from the book. If the file’s text formatting was affected by this structure information, reapplying the definitions also restores the file’s original formatting.
1. Make the appropriate document window or book window active. If a book window is active, select the documents you want to affect.
2. In the file, choose File > Import > Element Definitions.
3. Leave the Import from Document pop-up menu set to Current, select While Updating: Remove Information Inherited from Book, and click Import.
In addition to checking to see if book chapter pages have been set to
always be even in count, look to see if the chapters that follow are set
to begin specifically on a right or left hand page. For example, if
chapters are set to start on a right-hand page and is chapter 1 is three
pages long, it will also end on a right-hand page. Chapter 2 MUST then
insert an extra left-hand page in order to start on a right-hand page.
Megan,
Thank you for replying! That worked indeed, but I still do not have a solution for the tables that run across several pages. My temporary solution is either to manually assign a different master page or split the tables and insert an extra line of each page, but I was hoping for something automatic ![]()
Cheers,
Ana
@Error7103,
Great idea. Thanks for posting.
I'm testing it here. It works in most cases.
Anomalies that I see are:
Definitely worth more testing here. So far I'm stumped on these two anomalies.
Best regards,
