Cant open new install of Audition CS6 Constantly Crashing
May 31, 2012 10:43 AM
| Process: | Adobe Audition CS6 [344] |
| Path: | /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/MacOS/Adobe Audition CS6 |
| Identifier: | com.adobe.Audition.5.0 |
| Version: | 5.0x708 (5.0) |
| Code Type: | X86 (Native) |
Parent Process: launchd [142]
| Date/Time: | 2012-05-31 10:37:09.638 -0700 |
| OS Version: | Mac OS X 10.7.3 (11D50d) |
Report Version: 9
| Interval Since Last Report: | 1297586 sec |
| Crashes Since Last Report: | 3 |
Per-App Interval Since Last Report: 18 sec
Per-App Crashes Since Last Report: 3
| Anonymous UUID: | B058F01B-40B0-4B77-B0AF-086642178641 |
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
objc[344]: garbage collection is OFF
terminate called throwing an exception
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
| 0 libsystem_kernel.dylib | 0x9c4899c6 __pthread_kill + 10 | |
| 1 libsystem_c.dylib | 0x9a2adf78 pthread_kill + 106 | |
| 2 libsystem_c.dylib | 0x9a29ebdd abort + 167 | |
| 3 libc++abi.dylib | 0x9afa5921 abort_message + 94 | |
| 4 libc++abi.dylib | 0x9afa31bc default_terminate() + 36 | |
| 5 libc++abi.dylib | 0x9afa31fe safe_handler_caller(void (*)()) + 15 | |
| 6 libc++abi.dylib | 0x9afa3268 std::terminate() + 23 | |
| 7 libc++abi.dylib | 0x9afa42a0 __cxa_throw + 112 | |
| 8 com.adobe.auui.framework | 0x04e5e2b3 BIB_T_NMT::BIBThrowError(BIBError*) + 195 | |
| 9 com.adobe.auui.framework | 0x04e83580 dvaui::drawbot::AGMTextDoc::GetLineBounds(int) const + 412 | |
| 10 com.adobe.auui.framework | 0x04e69d01 dvaui::drawbot::AGMFontInterface::MeasureMultiLineStringHeight(unsign ed short const*, float, int) const + 509 | |
| 11 com.adobe.dvaui.framework | 0x00580a50 dvaui::controls::UI_StaticText::GetRecommendedSize_Helper(dvaui::draw bot::Drawbot*, boost::intrusive_ptr<dvaui::ui::Theme>, bool) const + 496 | |
| 12 com.adobe.dvaui.framework | 0x00580d12 dvaui::controls::UI_StaticText::UI_GetRecommendedSize(dvaui::drawbot: :Drawbot*) const + 60 | |
| 13 com.adobe.dvaui.framework | 0x006af6c8 dvaui::ui::(anonymous namespace)::LayoutNode::operator()(boost::intrusive_ptr<dvaui::ui::UI _Node>) + 448 | |
| 14 com.adobe.dvaui.framework | 0x006afdba dvaui::ui::AutoLayoutSubView(boost::intrusive_ptr<dvaui::ui::UI_SubVi ew>, dvaui::drawbot::Drawbot*) + 986 | |
| 15 com.adobe.dvaui.framework | 0x0068dae9 dvaui::ui::UI_SubViewAdapter::AutoLayout(dvaui::drawbot::Drawbot*, boost::intrusive_ptr<dvaui::ui::UI_Node>, boost::intrusive_ptr<dvaui::ui::UI_Node>) const + 47 | |
| 16 com.adobe.dvaui.framework | 0x006b4ad8 dvaui::ui::UI_NodeArchive::CreateNode(boost::intrusive_ptr<dvaui::ui: :UI_Node>, dvacore::proplist::PropList const&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) + 1984 | |
| 17 com.adobe.dvaui.framework | 0x006b54e7 dvaui::ui::UI_NodeArchive::BuildFromPropList(dvacore::proplist::PropL ist const&, std::map<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*, std::less<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const>, std::allocator<std::pair<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*> > >&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) + 313 | |
| 18 com.adobe.dvaui.framework | 0x006b5714 dvaui::ui::UI_NodeBuilder::Build(dvaui::drawbot::SupplierInterface const*, std::map<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*, std::less<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const>, std::allocator<std::pair<std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const, dvaui::ui::UI_Node*> > >&, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>) const + 148 | |
| 19 com.adobe.dvaui.framework | 0x006520d8 dvaui::sharedui::DVAAboutDlog::ConstructCommon(dvaui::utility::Resour ceManager const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::geom::PointT<float>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>, bool) + 1238 | |
| 20 com.adobe.dvaui.framework | 0x00652a6c dvaui::sharedui::DVAAboutDlog::DVAAboutDlog(dvaui::utility::ResourceM anager const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvacore::geom::PointT<float>, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvaui::drawbot::SupplierInterface const*, dvaui::ui::UI_Node*, boost::function<boost::intrusive_ptr<dvaui::ui::UI_Node> ()(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&)>, bool) + 462 | |
| 21 com.adobe.auui.framework | 0x047d4a69 aui::SplashScreen::SplashScreen(dvaworkspace::workspace::Workspace*, dvaui::utility::ResourceManager*) + 181 | |
| 22 com.adobe.auui.framework | 0x047c0d2a aui::Application::GetNewSplashScreen() + 62 | |
| 23 com.adobe.exo.framework | 0x01d2d5cb exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 687 | |
| 24 com.adobe.auui.framework | 0x047c7131 aui::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 145 | |
| 25 com.adobe.auui.framework | 0x047d5162 AudMacMain(int, char**) + 386 | |
| 26 com.adobe.Audition.5.0 | 0x00002e3f main + 159 | |
| 27 com.adobe.Audition.5.0 | 0x00002c55 start + 53 |
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
| 0 libsystem_kernel.dylib | 0x9c48a90a kevent + 10 | |
| 1 libdispatch.dylib | 0x900eac58 _dispatch_mgr_invoke + 969 | |
| 2 libdispatch.dylib | 0x900e96a7 _dispatch_mgr_thread + 53 |
Thread 2:
| 0 libsystem_kernel.dylib | 0x9c48a02e __workq_kernreturn + 10 | |
| 1 libsystem_c.dylib | 0x9a2adccf _pthread_wqthread + 773 | |
| 2 libsystem_c.dylib | 0x9a2af6fe start_wqthread + 30 |
Thread 3:
Thread 4:
| 0 libsystem_kernel.dylib | 0x9c48983e __psynch_cvwait + 10 | |
| 1 libsystem_c.dylib | 0x9a2afe21 _pthread_cond_wait + 827 | |
| 2 libsystem_c.dylib | 0x9a26042c pthread_cond_wait$UNIX2003 + 71 | |
| 3 com.apple.CoreServices.CarbonCore | 0x98c82e62 TSWaitOnCondition + 124 | |
| 4 com.apple.CoreServices.CarbonCore | 0x98bf43c5 TSWaitOnConditionTimedRelative + 136 | |
| 5 com.apple.CoreServices.CarbonCore | 0x98c56681 MPWaitOnQueue + 200 | |
| 6 com.adobe.ACE | 0x080b6a69 0x8077000 + 260713 | |
| 7 com.adobe.ACE | 0x080b5d99 0x8077000 + 257433 | |
| 8 com.apple.CoreServices.CarbonCore | 0x98c575e0 PrivateMPEntryPoint + 68 | |
| 9 libsystem_c.dylib | 0x9a2abed9 _pthread_start + 335 | |
| 10 libsystem_c.dylib | 0x9a2af6de thread_start + 34 |
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x9afa6330 ecx: 0xbffff04c edx: 0x9c4899c6
edi: 0xaceae2c0 esi: 0x00000006 ebp: 0xbffff068 esp: 0xbffff04c
ss: 0x00000023 efl: 0x00000246 eip: 0x9c4899c6 cs: 0x0000000b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x04f83e18
Logical CPU: 0
Binary Images:
| 0x1000 - | 0x2ff3 +com.adobe.Audition.5.0 (5.0x708 - 5.0) <7143E96E-16C4-15B3-73E1-B69B2E28AC62> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/MacOS/Adobe Audition CS6 | |
| 0x7000 - | 0xaffb +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <6CE1936E-6AC7-6900-769B-876CBB68B5BC> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter | |
| 0x12000 - | 0x18ff7 +com.adobe.boost_date_time.framework (6.0.0 - 6.0.0.348464) <A946B021-8CB6-375A-0D5B-37E16B6DED76> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boos t_date_time | |
| 0x32000 - | 0x40ff3 +com.adobe.boost_threads.framework (6.0.0 - 6.0.0.348464) <EE427D2F-44C8-9DF7-9432-E0EAC2073322> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_ threads | |
| 0x5e000 - | 0x68ff7 +com.adobe.boost_signals.framework (6.0.0 - 6.0.0.348464) <123701D0-BA86-956E-9D3A-1F05A4F2EEEB> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_ signals | |
| 0x7f000 - | 0x82fff +com.adobe.boost_system.framework (6.0.0 - 6.0.0.348464) <733D47FB-B703-E1DD-42B8-FC60CDC67286> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_s ystem |
0x89000 - 0x246fe3 +com.adobe.dvacore.framework (6.0.0 - 6.0.0.348464) <663DD48C-414B-7C64-79F1-2EEA08DBCD5B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x42d000 - 0x84fff7 +com.adobe.dvaui.framework (6.0.0 - 6.0.0.348464) <6327A558-DF1E-3D65-413F-A78DDB9B9961> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0xd40000 - 0x105efeb +com.adobe.dvaadameve.framework (6.0.0 - 6.0.0.348464) <5AD031BA-0B79-0B68-E3AA-CB9A6C2126B1> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadamev e
0x1706000 - 0x17b2ff3 +com.adobe.dvaworkspace.framework (6.0.0 - 6.0.0.348464) <4D2F35A2-DAE2-D2B3-C091-1DF1EBB94EAA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvawork space
0x18ab000 - 0x18daff3 +com.adobe.dvamediatypes.framework (6.0.0 - 6.0.0.348464) <36494605-0BF9-C0C8-598D-243BD6D255BD> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamed iatypes
0x190f000 - 0x1963ffb +com.adobe.dvametadata.framework (6.0.0 - 6.0.0.348464) <E6D4B62C-F80D-DA36-8A17-1F43F85D4FC3> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametad ata
0x19f8000 - 0x1a54fef +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <123A0829-A85B-6E67-0E48-4F37B08E4C03> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x1a5d000 - 0x1b18fef +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.4 -f 49 - 66.145661) <B8855D3A-C827-D9EB-040E-F808043458DA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeX MPFiles
0x1b47000 - 0x1bd3fff +com.adobe.dvametadataUI.framework (6.0.0 - 6.0.0.348464) <BC4B79B3-337D-0AB9-8315-5F7C38A64869> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvamet adataUI
0x1c9e000 - 0x1cf8fff +com.adobe.dvatemporalxmp.framework (6.0.0 - 6.0.0.348464) <C10B326B-3B9A-6C0F-A757-E55ACB51C16B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvate mporalxmp
0x1d29000 - 0x1debff3 +com.adobe.exo.framework (6.0.0 - 6.0.0.348464) <A1DEBB6E-AE56-8B3E-62A3-2BDFD6FECEA8> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x1f34000 - 0x1f55ff7 +com.adobe.dvaunittesting.framework (6.0.0 - 6.0.0.348464) <3FFD4D0B-C02A-FDF1-8612-725D1BCA27DB> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaun ittesting
0x1f96000 - 0x1fa3ffb +com.adobe.aucore.framework (1.0 - 1.0) <40B2195C-9FBD-6DBD-111F-FDCA4387E9FF> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuCore.framework/Versions/A/AuCore
0x1fbb000 - 0x21fcff3 +com.adobe.audsp.framework (1.0 - 1.0) <B4E896CF-9EF7-95AB-7D05-17EC6CD4074B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuDSP.framework/Versions/A/AuDSP
0x22af000 - 0x2360ffb +com.adobe.dvaaudiofilterhost.framework (6.0.0 - 6.0.0.348464) <E6C1B553-B2A8-75A0-B40C-C01056D8729E> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/d vaaudiofilterhost
0x244c000 - 0x256afeb +com.adobe.auaudiocomponents.framework (1.0 - 1.0) <F61668F7-3716-A9A3-D7B3-3C3F6C2F7ABE> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuAudioComponents.framework/Versions/A/Au AudioComponents
0x2627000 - 0x26a8feb +com.adobe.dvaaudiodevice.framework (6.0.0 - 6.0.0.348464) <8E0B5B3D-B285-ECA7-E016-46BB8F4A54C5> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaau diodevice
0x275d000 - 0x27baffb +com.adobe.dvatransport.framework (6.0.0 - 6.0.0.348464) <1174AF4C-0FC5-D7B2-56DE-331C2B83B574> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatran sport
0x2830000 - 0x2868ff3 +com.adobe.dvamarshal.framework (6.0.0 - 6.0.0.348464) <DAC2C35E-02DF-8620-D050-E94A49BA2785> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarsha l
0x28f5000 - 0x2abbfe7 +com.adobe.dynamiclink.framework (6.0.0 - 6.0.0.348464) <87781694-3CCE-4E40-CF3D-8717BCA7805C> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamicl ink
0x2ca4000 - 0x2d5bffb +com.adobe.dvaplayer.framework (6.0.0 - 6.0.0.348464) <C31EDE2F-354C-369D-217A-4B9A272812CA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
0x2ea3000 - 0x3208fe7 +com.adobe.aubackend.framework (1.0 - 1.0) <EC8C1CFE-821A-9BDE-156D-430CAD6CDC2F> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuBackEnd.framework/Versions/A/AuBackEnd
0x3574000 - 0x357bfff +com.adobe.dvaundo.framework (6.0.0 - 6.0.0.348464) <3F921716-0B48-4C71-C633-99D05450A0D0> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
0x3589000 - 0x39cafef +com.adobe.auapplication.framework (1.0 - 1.0) <68A76749-D933-E0DF-D10D-21735F863B53> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuApplication.framework/Versions/A/AuAppl ication
0x3d6b000 - 0x3e36ff7 +com.adobe.auuitoolkit.framework (1.0 - 1.0) <0D46E172-E874-3889-43D1-CE1B88C840F5> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuUIToolkit.framework/Versions/A/AuUITool kit
0x3f9b000 - 0x404fffb +com.adobe.AdobeExtendScript (ExtendScript 4.2.12 - 4.2.12.18602) <2C860A49-8645-DC74-DC56-53BC99138C6F> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
0x4092000 - 0x4130ff3 +com.adobe.AdobeScCore (ScCore 4.2.12 - 4.2.12.18602) <D8CDF140-E42A-DCFB-AFFC-69B4694FB639> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
0x4166000 - 0x428dff3 +com.adobe.auscripting.framework (1.0 - 1.0) <18BB467E-16FF-AFE0-1C60-821D818E1C3F> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuScripting.framework/Versions/A/AuScript ing
0x443a000 - 0x4491ffb +com.adobe.dvaaudiofilterhostui.framework (6.0.0 - 6.0.0.348464) <09E4640D-C6CC-678E-787C-56567ABD70AA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A /dvaaudiofilterhostui
0x452a000 - 0x461afeb +com.adobe.auaudiocomponentsui.framework (1.0 - 1.0) <682B2B78-16D3-6965-F4C7-83E81BBDF034> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuAudioComponentsUI.framework/Versions/A/ AuAudioComponentsUI
0x4742000 - 0x5225feb +com.adobe.auui.framework (1.0 - 1.0) <487E4C9E-4BAA-4969-ACAD-BD9546DCAF02> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AuUI.framework/Versions/A/AuUI
0x5c3a000 - 0x5c77fff com.apple.vmutils (4.2.1 - 107) <43B3BFA5-8362-3EBD-B44B-32DCE9885082> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
0x5c91000 - 0x5ca5ff3 +com.adobe.boost_filesystem.framework (6.0.0 - 6.0.0.348464) <AB0E824D-AD9F-7AD5-9D5F-C6AE9D8BE579> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boo st_filesystem
0x5cc9000 - 0x5d5cfe7 +com.adobe.boost_regex.framework (6.0.0 - 6.0.0.348464) <04104232-C5E0-F4F5-5C5D-8A45E2FE9C3E> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_re gex
0x5df5000 - 0x5eb6ffb +com.adobe.dvaeve.framework (6.0.0 - 6.0.0.348464) <34CB64A1-5F13-89E5-8909-899F814F8301> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x6016000 - 0x62d2ff7 +libmkl_intel.dylib (??? - ???) <25E5013B-C664-8353-5B95-417876276056> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/libmkl_intel.dylib
0x6399000 - 0x6650ff7 +libmkl_sequential.dylib (??? - ???) <C0A18DB1-3D56-AF3A-2B0B-7FC163AEA80C> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/libmkl_sequential.dylib
0x66e3000 - 0x7007fe3 +libmkl_core.dylib (??? - ???) <93B3DD56-8103-45E8-AD8D-7F133535BB4B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/libmkl_core.dylib
0x709b000 - 0x709bfff libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <859B5BCC-B5D9-370F-8B6C-1E2B242D5DCD> /usr/lib/libmx.A.dylib
0x709e000 - 0x70caff3 com.apple.audio.CoreAudioKit (1.6.3 - 1.6.3) <7D47B1D3-4410-3524-BC47-FCDF49E48DB5> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudi oKit
0x70dd000 - 0x7186fe7 +iZotope_Radius (??? - ???) <85A9D505-8918-02CD-F5D9-EDA4AB5E24CD> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZoto pe_Radius
0x71bc000 - 0x71f1fff +iZotopeOmegaStreaming (??? - ???) <98FBD353-965B-5C41-19FC-50F91A973A7C> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/iZotopeOmegaStreaming.framework/Versions/ A/iZotopeOmegaStreaming
0x7204000 - 0x7822ff7 +com.sonic.AS_Storage (5.2.17 - compatibility 1.0.0) <C4D2F83C-4B3B-EABB-DEAA-E6E48ABEF174> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AS_Storage.framework/Versions/A/AS_Storag e
0x7baa000 - 0x7c17ffb +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1652) <82DA9279-45D2-AD40-C86C-F5A94B9DAAFF> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSessio n
0x7c66000 - 0x7ef4fec +libxerces-c-3.0.dylib (??? - ???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/libxerces-c-3.0.dylib
0x8077000 - 0x81f3ff3 +com.adobe.ACE (AdobeACE 2.19.18.19243 - 2.19.18.19243) <464E11C2-11BF-EED9-445F-B110D65E1944> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x8202000 - 0x88ddfe3 +com.adobe.AGM (AdobeAGM 4.26.17.19243 - 4.26.17.19243) <42C0275C-8715-D732-1EEB-12E4548DDA9F> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x895b000 - 0x8978ff3 +com.adobe.BIB (AdobeBIB 1.2.02.19243 - 1.2.02.19243) <652AAC98-9C63-CB58-8E03-45F14C8B3A1D> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x897e000 - 0x89a5ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <53AF73F4-B822-A23F-A7C6-0CFB6326D8AA> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
0x89ab000 - 0x8cd2ffb +com.adobe.CoolType (AdobeCoolType 5.10.31.19243 - 5.10.31.19243) <4DB6A24B-C380-EF7A-B9A1-BF373C6F0AAD> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
0x8d0a000 - 0x8decff3 +com.adobe.amtlib (amtlib 6.0.0.93 - 6.0.0.93) <2218F05B-09B7-AE0E-5EF7-98FBA5DF9C86> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x8dfb000 - 0x8dfbffb +com.adobe.PRM.framework (6.0.0 - 6.0.0.0) <3B615928-9364-A3BE-41FC-84383CDC01B9> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x8e02000 - 0x8e60ff7 +com.adobe.ASLFoundation.framework (6.0.0 - 6.0.0.0) <8EBBB1C5-8042-D532-D58B-36BBF96F4702> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFou ndation
0x8f1f000 - 0x8f3affb +com.adobe.ASLMessaging.framework (6.0.0 - 6.0.0.0) <959C4992-F28A-213F-6D1B-30E49C485FB9> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMess aging
0x8f66000 - 0x8f74fff +com.adobe.ASLUnitTesting.framework (6.0.0 - 6.0.0.0) <0B446A0F-87BC-03B9-01A7-6F4EEB956083> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUn itTesting
0x8f8e000 - 0x8fdbfef +com.adobe.MediaFoundation.framework (6.0.0 - 6.0.0.0) <D492885A-7550-1C92-58C2-DEFFE9A39712> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/Medi aFoundation
0x903f000 - 0x907cffb +com.adobe.DisplaySurface.framework (6.0.0 - 6.0.0.0) <EA64EA01-CE0E-5450-1CF9-8D45ED6EEA2B> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/Displ aySurface
0x90ce000 - 0x92e1ffb +com.adobe.ImageRenderer.framework (6.0.0 - 6.0.0.0) <EB99D6D9-C5AB-4232-DD5F-EF579D3EF263> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageR enderer
0x93d4000 - 0x93d5ffb +com.adobe.Memory.framework (6.0.0 - 6.0.0.0) <F9032F6D-6BBC-E66E-A5AE-BA4AA7D9167A> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x93dc000 - 0x942cffb +com.adobe.VideoFrame.framework (6.0.0 - 6.0.0.0) <2D5BC52D-BB03-9C26-EF01-2D18EF2349CB> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFram e
0x9475000 - 0x9497fe7 +com.mainconcept.mc.enc.dv (9.1 - 9.1.0.60018) <7F1E874F-0B3E-AD0B-A016-328DD319F3B0> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
0xa7c0000 - 0xa7ceffb libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <D3F1CC34-55EB-3D33-A7C2-025D5C8025D0> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
0xa7ef000 - 0xa7f0ff1 com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0xd7b0000 - 0xd7c2fff libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <ADEB72F9-0048-3C87-AD9B-71AA57D523E9> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
0x103bb000 - 0x103bfffb libFontRegistryUI.dylib (??? - ???) <E986346C-8132-33B6-8525-AA2A3233F99C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/A TS.framework/Resources/libFontRegistryUI.dylib
0x10a57000 - 0x10a58ffc ATSHI.dylib (??? - ???) <B244624E-E09E-34B2-A185-EB30AF08A95D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x8feb8000 - 0x8feeaaa7 dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
0x90005000 - 0x90062ffb com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x90063000 - 0x900a6ffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
0x900a7000 - 0x900e7ff7 com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x900e8000 - 0x900f6fff libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
0x9015c000 - 0x90163ffd com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x90164000 - 0x90167ffb com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x90168000 - 0x901d7fff com.apple.Heimdal (2.1 - 2.0) <BCF7C3F1-23BE-315A-BBB6-5F01C79CF626> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
0x90545000 - 0x90546ff7 libsystem_sandbox.dylib (??? - ???) <D272A77F-7F47-32CD-A36E-5A3FB966ED55> /usr/lib/system/libsystem_sandbox.dylib
0x90547000 - 0x9054affd libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x9054b000 - 0x9054bfff com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9054c000 - 0x90a28ff6 libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x90a58000 - 0x90a75fff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
0x90a76000 - 0x90afdfff com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x90afe000 - 0x90afefff com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x90aff000 - 0x90c60ffb com.apple.QuartzCore (1.7 - 270.2) <4A6035C8-1237-37E5-9FFF-1EFD735D8B18> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90c61000 - 0x90c62ff7 libquarantine.dylib (36.2.0 - compatibility 1.0.0) <3F974196-FBAD-3DBD-8ED0-DC16C2B3526B> /usr/lib/system/libquarantine.dylib
0x90c63000 - 0x90c70fff libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x90c71000 - 0x90c71fff libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
0x90cef000 - 0x90f74fe3 com.apple.QuickTime (7.7.1 - 2315) <E6249041-B569-3A96-897F-E84B1C057948> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x90f7f000 - 0x90fd0fff libFontRegistry.dylib (??? - ???) <DF69E8EC-9114-3757-8355-8F3E82156F85> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x90fd1000 - 0x90ff6ff9 libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x90ff7000 - 0x91059ff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
0x91284000 - 0x91393fff com.apple.DesktopServices (1.6.2 - 1.6.2) <33DCFB71-1D9E-30B6-BC4C-CD54068690BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x9149a000 - 0x914c8fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
0x914dd000 - 0x914f9ffc libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x914fa000 - 0x914fbfff liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
0x914fc000 - 0x9151effe com.apple.framework.familycontrols (3.0 - 300) <6B0920A5-3971-30EF-AE4C-5361BB7199EB> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x91637000 - 0x91637fff com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x91638000 - 0x9163fff5 libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
0x91640000 - 0x920d3ff6 com.apple.AppKit (6.7.3 - 1138.32) <008E7C05-C20C-344A-B51C-4A2441372785> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x92107000 - 0x9210aff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x9210b000 - 0x92134ffe com.apple.opencl (1.50.69 - 1.50.69) <44120D48-00A2-3C09-9055-36D309F1E7C9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x92135000 - 0x9213dff3 liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
0x9213e000 - 0x92200fff com.apple.CoreServices.OSServices (478.37 - 478.37) <00A48B2A-2D75-3FD0-9805-61BB11710879> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x92364000 - 0x925d7ff7 com.apple.CoreImage (7.93 - 1.0.1) <88FEFE5B-83A9-3CD9-BE2E-DB1E0553EBB0> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
0x925d8000 - 0x925ebffb com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <AE079D11-3A38-3707-A2DF-6BD2FC24B712> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x925ec000 - 0x925f4ff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
0x925f5000 - 0x92600ffe libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
0x92601000 - 0x92605fff com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x92606000 - 0x927fbff7 com.apple.CoreData (104.1 - 358.13) <EB02DCA7-DB2A-32DD-B49E-ECE54D078610> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x92871000 - 0x92875ff3 libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
0x92876000 - 0x9287affd IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x92891000 - 0x92928ff3 com.apple.securityfoundation (5.0 - 55107) <DF36D4ED-47F7-3F7F-AB09-32E5BFB7EF05> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x92929000 - 0x9296aff9 libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <CAE102A7-EA5E-391C-A91F-A08071A68652> /usr/lib/libcurl.4.dylib
0x9297e000 - 0x92a08ffb com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x92a09000 - 0x92a1dff7 com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x92a8a000 - 0x92ad3ff7 libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x92b20000 - 0x92c10ff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
0x9338c000 - 0x933c3fef com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
0x934f8000 - 0x935f0ff7 libFontParser.dylib (??? - ???) <8C069D3D-534F-3EBC-8035-A43E2B3A431A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x935f1000 - 0x93655fff com.apple.framework.IOKit (2.0 - ???) <8DAF4991-7359-3D1B-AC69-3CBA797D1E3C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x93656000 - 0x93657ff0 libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
0x93658000 - 0x937aafff com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <E369AC9E-F548-3DF6-B320-9D09E486070E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x937e9000 - 0x937f9fff libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
0x93855000 - 0x9385dfff com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x9385e000 - 0x93860ff9 com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x93939000 - 0x93947ff7 libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
0x9399a000 - 0x9399eff7 com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x9399f000 - 0x93a82ff7 libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
0x93a83000 - 0x93c5afff com.apple.CoreFoundation (6.7.1 - 635.19) <3A07EDA3-F460-3971-BFCB-AFE9A11F74F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x943c4000 - 0x943c5fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
0x943c6000 - 0x943c7fff com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x943c8000 - 0x94424fff com.apple.coreui (1.2.1 - 165.3) <65526A00-D355-3932-9279-9A7D6BF76D95> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x94aac000 - 0x94aadffd libCVMSPluginSupport.dylib (??? - ???) <6C364E11-B9B3-351A-B297-DB06FBAAFFD1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
0x94aae000 - 0x94b3bfe7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x94b3f000 - 0x94b42ffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
0x94b43000 - 0x94c53fe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
0x956ea000 - 0x9574bffb com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <E617857C-D870-3E2D-BA13-3732DD1BC15E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x958ab000 - 0x958b2ff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
0x958cb000 - 0x958d2fff com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x958d3000 - 0x95949fff com.apple.Metadata (10.7.0 - 627.28) <71AC8DA5-FA89-3411-A97C-65B6129E97BD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x959a1000 - 0x959d5ff8 libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
0x959d6000 - 0x959ebff7 com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x959ec000 - 0x95a15ff1 com.apple.CoreServicesInternal (113.12 - 113.12) <CFF78E35-81F5-36C2-A59F-BF85561AC16D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
0x95a16000 - 0x95b27ff7 libJP2.dylib (??? - ???) <143828CE-D429-3C66-A0DC-4F39536568E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x95b28000 - 0x95b2dff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
0x9616d000 - 0x96187fff com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x96188000 - 0x9619effe libxpc.dylib (77.18.0 - compatibility 1.0.0) <D40B8FD1-C671-3BD5-8C9E-054AF6D4FE9A> /usr/lib/system/libxpc.dylib
0x9619f000 - 0x961a2ff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
0x961ca000 - 0x961f9ff7 libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
0x96f4b000 - 0x9734dff6 libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x9734e000 - 0x973e3ff7 com.apple.LaunchServices (480.27.1 - 480.27.1) <8BFE799A-7E35-3834-9403-20E5ADE015D0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x973e4000 - 0x976eeff3 com.apple.Foundation (6.7.1 - 833.24) <8E2AD829-587C-3146-B483-9D0209B84192> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x976ef000 - 0x978a3ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
0x978a4000 - 0x97d19ff7 FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
0x97d9e000 - 0x97ebcfec com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x97efb000 - 0x97f29ff7 com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x97f34000 - 0x98003fff com.apple.ImageIO.framework (3.1.1 - 3.1.1) <D4D6EB78-8A6C-3474-921C-622C6951489B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x98004000 - 0x9892c5eb com.apple.CoreGraphics (1.600.0 - ???) <E285B0B6-F9FC-33BC-988F-ED619B32029C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9892d000 - 0x9894cfff com.apple.RemoteViewServices (1.3 - 44) <243F16F3-FFFE-3E81-A969-2EC947A11D89> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
0x98a7a000 - 0x98acaff0 libTIFF.dylib (??? - ???) <F532A16A-7761-355C-8B7B-CEF988D8EEFF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x98ae4000 - 0x98aeffff libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
0x98af0000 - 0x98b0dff3 com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x98b0e000 - 0x98b0effe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
0x98b0f000 - 0x98b45ff7 com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x98b46000 - 0x98b71fff com.apple.GSS (2.1 - 2.0) <DA24E4F9-F9D4-3CDB-89E4-6EAA7A9F6005> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x98b72000 - 0x98b82ff7 libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
0x98bad000 - 0x98bb5ff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
0x98bb6000 - 0x98eb8fff com.apple.CoreServices.CarbonCore (960.20 - 960.20) <E6300673-A013-3A91-BB1A-DD793B857E16> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x9916b000 - 0x991cdffb com.apple.datadetectorscore (3.0 - 179.4) <32262124-6F75-3999-86DA-590A90BA464C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
0x992e5000 - 0x993bbaab libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
0x99403000 - 0x9944bff7 com.apple.SystemConfiguration (1.11.2 - 1.11) <CA077C0D-8A54-38DB-9690-5D222899B93D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x9944c000 - 0x99461fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x995f8000 - 0x996b8ffb com.apple.ColorSync (4.7.1 - 4.7.1) <68413C12-2380-3B73-AF74-B9E069DFB89A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x996b9000 - 0x996c4ff3 libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <DD0529E3-9D71-37B6-9EB8-D7747B2B12C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x996c5000 - 0x996c5fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x996c6000 - 0x996d4fff libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
0x99a3a000 - 0x99a5dfff com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x99a5e000 - 0x99ad2fff com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
0x99daf000 - 0x9a0f3ffb com.apple.HIToolbox (1.8 - ???) <9540400F-B432-3116-AEAD-C1FBCFE67E73> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x9a161000 - 0x9a1b2ff9 com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x9a1b3000 - 0x9a1b8ffd libGFXShared.dylib (??? - ???) <179E77CE-C72C-3B5F-8F1E-3901517C24BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x9a1bb000 - 0x9a1c1ffd com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
0x9a1c2000 - 0x9a227ff7 libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x9a24f000 - 0x9a31afff libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
0x9a31b000 - 0x9a31bfff com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9a31c000 - 0x9a377ff3 com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
0x9a7ba000 - 0x9a7bbff4 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
0x9a7bc000 - 0x9a7f8ffa libGLImage.dylib (??? - ???) <05B36DC4-6B90-33E6-AE6A-10CAA1B70606> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x9a9b8000 - 0x9a9b8fff com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9a9b9000 - 0x9aa54ff3 com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x9aa55000 - 0x9aabcfff libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
0x9aabf000 - 0x9abebff9 com.apple.CFNetwork (520.3.2 - 520.3.2) <58021CA7-0C91-3395-8278-8BD76E03BDCB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x9ac25000 - 0x9ac5bff4 com.apple.LDAPFramework (3.0 - 120.1) <EA92FCA5-7A7E-328F-8C7F-4250FCC45879> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x9ac5c000 - 0x9ac65ff3 com.apple.CommonAuth (2.1 - 2.0) <5DA75D12-A4D6-3362-AD72-79A64C79669E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
0x9ac66000 - 0x9ac66ff2 com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x9ac67000 - 0x9ac69ffb libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9af9e000 - 0x9afa7fff libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
0x9afa8000 - 0x9afcaff1 com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
0x9b1e7000 - 0x9b1eaff9 libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <E06426D8-CC01-3754-B5B3-D15CBA5C8D73> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x9b639000 - 0x9b644ffc com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
0x9b77e000 - 0x9b782ffa libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
0x9b783000 - 0x9b7dcfff com.apple.HIServices (1.11 - ???) <F8B77735-B168-3E21-9B8F-921115B4C19B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x9b8bd000 - 0x9b961fff com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x9b962000 - 0x9b9ddffb com.apple.ApplicationServices.ATS (317.5.0 - ???) <7A8B0538-8E2E-3355-81E3-0C0A7EBED28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x9b9e3000 - 0x9b9e4fff libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
0x9b9e5000 - 0x9b9f0ffb com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x9ba41000 - 0x9ba51fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9ba9c000 - 0x9bac4ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
0x9bac5000 - 0x9bac9fff libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9bc0e000 - 0x9bc4eff7 libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
0x9bca7000 - 0x9bcc3ff5 com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
0x9bcc4000 - 0x9bcceff2 com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x9bccf000 - 0x9bd0cff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <4508AABD-EDA8-3BF7-B03A-978D2395C9A8> /usr/lib/libcups.2.dylib
0x9bd0d000 - 0x9bd13ffb com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x9bd14000 - 0x9bdfcfff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
0x9c047000 - 0x9c055fff com.apple.opengl (1.7.6 - 1.7.6) <5EF9685C-F8B2-3B22-B291-8012761E9AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9c46e000 - 0x9c470ff7 libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
0x9c471000 - 0x9c48fff7 libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
0x9c4ee000 - 0x9c4eeff0 com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x9c623000 - 0x9c6b0ff7 com.apple.CoreText (220.11.0 - ???) <720EFEE0-A92A-3519-9C88-D06E4DE14EAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x9c6b1000 - 0x9c6effff libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0FAB8C29-2A1B-3E25-BA34-BDD832B828DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9c6f0000 - 0x9c701fff libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
0x9cb29000 - 0x9cde5ff3 com.apple.security (7.0 - 55110) <2F4FCD65-2A30-3330-99DE-91FE1F78B9FB> /System/Library/Frameworks/Security.framework/Versions/A/Security
0xb0000000 - 0xb001afe3 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <928D8FAD-DEE7-F1D0-FE17-FA7F4E4C1E48> /Applications/Adobe Audition CS6/Adobe Audition CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xba900000 - 0xba91bffd libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <5635DF40-8D8E-3B8C-B075-7B3FC0F184A4> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21ff6 libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <17226124-8E8A-34EB-A2C4-D4A0469CF45B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
External Modification Summary:
Calls made by other processes targeting this process:
| task_for_pid: 2 | |
| thread_create: 0 | |
| thread_set_state: 0 |
Calls made by this process:
| task_for_pid: 0 | |
Calls made by all processes on this machine:
| task_for_pid: 556 | |
VM Region Summary:
ReadOnly portion of Libraries: Total=276.9M resident=173.3M(63%) swapped_out_or_unallocated=103.6M(37%)
Writable regions: Total=146.3M written=25.9M(18%) resident=30.3M(21%) swapped_out=0K(0%) unallocated=116.0M(79%)
| REGION TYPE | VIRTUAL |
| ATS (font support) | 31.9M |
| CG shared images | 96K |
| CoreGraphics | 8K |
| CoreServices | 1088K |
| MALLOC | 90.1M |
| MALLOC guard page | 32K |
| Memory tag=242 | 12K |
| Memory tag=243 | 4K |
| Stack | 70.1M |
| VM_ALLOCATE | 7784K |
| __CI_BITMAP | 80K |
| __DATA | 11.5M |
| __DATA/__OBJC | 108K |
| __IMAGE | 528K |
| __IMPORT | 84K |
| __LINKEDIT | 98.8M |
| __OBJC | 1624K |
| __PAGEZERO | 4K |
| __TEXT | 178.1M |
| __UNICODE | 544K |
| mapped file | 556.6M |
| shared memory | 312K |
| shared pmap | 10.5M |
| TOTAL | 1.0G |
Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 3.2 GHz, 24 GB, SMC 1.25f4
Graphics: NVIDIA Quadro 4000, NVIDIA Quadro 4000, PCIe, 2048 MB
Memory Module: DIMM Riser B/DIMM 1, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323541373243503844332D5335
Memory Module: DIMM Riser B/DIMM 2, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323541373243503844332D5335
Memory Module: DIMM Riser A/DIMM 1, 4 GB, DDR2 FB-DIMM, 800 MHz, 0x0D9B, 0x000000000000000000000000000000000000
Memory Module: DIMM Riser A/DIMM 2, 4 GB, DDR2 FB-DIMM, 800 MHz, 0x0D9B, 0x000000000000000000000000000000000000
Memory Module: DIMM Riser B/DIMM 3, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323541373243503844332D5335
Memory Module: DIMM Riser B/DIMM 4, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x80AD, 0x48594D5031323541373243503844332D5335
Memory Module: DIMM Riser A/DIMM 3, 4 GB, DDR2 FB-DIMM, 800 MHz, 0x0D9B, 0x000000000000000000000000000000000000
Memory Module: DIMM Riser A/DIMM 4, 4 GB, DDR2 FB-DIMM, 800 MHz, 0x0D9B, 0x000000000000000000000000000000000000
Bluetooth: Version 4.0.3f12, 2 service, 18 devices, 1 incoming serial ports
Network Service: Ethernet 2, Ethernet, en1
PCI Card: NVIDIA Quadro 4000, sppci_displaycontroller, Slot-1
PCI Card: NVIDIA Quadro 4000, NVDA,Parent, Slot-1
PCI Card: pci17d3,1280, sppci_raid, Slot-4
PCI Card: pcif1d0,c0ff, sppci_video, Slot-3@8,12,0
Serial ATA Device: ST3500630AS P, 500.11 GB
Parallel ATA Device: OPTIARC DVD RW AD-7170A
USB Device: hub_device, apple_vendor_id, 0x911c, 0xfd500000 / 2
USB Device: USB Receiver, 0x046d (Logitech Inc.), 0xc52b, 0xfd510000 / 5
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd530000 / 4
USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfd532000 / 6
USB Device: Apple Cinema HD Display, apple_vendor_id, 0x921c, 0xfd520000 / 3
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8206, 0x5d200000 / 2
FireWire Device: built-in_hub, 800mbit_speed
