ricbuchner
ID 5.5 crash, then all my font links are gone.
May 31, 2012 9:55 AM
Tags: #missing #font #links #pink #alert
Hi.
I'm opening a file that I edited before, with no problems.
Now I had to use this same file, but replace the language in it - easy peasy.
The problem is that, in the very few minutes I start working on it, ID is crashing.
So I open it again, and voala: all text is highlighted in light PINK...
Before crash, everything was fine, all text were great, with no alerts on it (pink or yellow)...
I tried to do a package of this file. So the fonts would be saved in a separated folder.
All fonts I see in there, were .PFB and .PFM extentions.
I'm no expert in font management whatsoever... all the fonts I use are installed in my windows fonts folder...
Can someone help me with that??
THanks!!
    May 31, 2012 10:00 AM   in reply to ricbuchner
    From where are you opening the file now?
    May 31, 2012 12:35 PM   in reply to ricbuchner
    Is this from the packaged folder or the old location? Type 1 fonts don't work on Windows in the Document Fonts folder, if I remember correctly. If ,in fact you are trying to open from a package, try renaming the Document Fonts folder to anything else and see if it makes a difference.
    May 31, 2012 2:07 PM   in reply to ricbuchner
    Sounds like maybe one of the fonts is damaged, but hard to tell
