wmkolcz
SQL Question actually. Select items for all 12 months
May 27, 2012 2:17 PM
I am trying to create a reporting query where I SUM up all the amounts in the database for all 12 mont and come up with a result even if there isn't an amount totalled. I created a table called monthsInYear that has the ID (unique identifier) 1-12 and the months Jan - Dec. I want to SUM up the amounts per month and come up with 12 results (one per month).
I tried the query below but it only comes up with 1 month and all the amounts totalled to it.
March484714.13
I am using:
SELECT monthsInYear.month, IFNULL( SUM(income.amount), 0 ) AS amount
                FROM monthsInYear
                LEFT OUTER JOIN income ON EXTRACT(MONTH FROM income.dateAdded) = monthsInYear.monthID
                WHERE income.orgID = 10031
                AND YEAR(income.DateAdded) = '2011'
                ORDER BY EXTRACT(MONTH FROM income.dateAdded) ASC
Can anyone tell me what I am doing wrong. I would much much prefer something like:
January       3000
February     3000
March         4000
April           0
May           5000
June           6000
July            5465
    May 28, 2012 5:28 AM   in reply to wmkolcz
    Are you sure your query is even running?  You are requesting a field and a sum, but you don't have a group by clause.
    May 30, 2012 12:58 AM   in reply to wmkolcz
    I would start from something this
    SELECT monthsInYear.month, IFNULL(income.amount, 0 ) AS amount
    FROM monthsInYear
    WHERE EXTRACT(MONTH FROM income.dateAdded) = monthsInYear.monthID
    AND income.orgID = 10031
    ORDER BY EXTRACT(MONTH FROM monthsInYear.month) ASC
    May 30, 2012 2:34 PM   in reply to wmkolcz
    Use a left join.
    May 30, 2012 4:25 PM   in reply to wmkolcz
    Do a left join the way you did in the opening post.  In other words, the table from which you want all the rows should be left of the word left.
    May 31, 2012 1:07 AM   in reply to wmkolcz
    Hi
    As Dan Baruk rightly said try something like below
    SELECT m.month, m.monthID, IFNULL(SUM(e.cost), 0) AS amount
    FROM monthsInYear m
    LEFT JOIN getExpenses e ON m.monthID = EXTRACT(MONTH FROM e.dateAdded)
    WHERE e.orgID = 10031
    AND YEAR(e.dateAdded) = '2011'
    GROUP BY m.month, m.monthID
    ORDER BY EXTRACT(MONTH FROM e.dateAdded) ASC
    Here is a got article related to joins
    http://www.devx.com/dbzone/Article/17403/1954
    Regards
    Sreekar
    May 31, 2012 5:13 PM   in reply to wmkolcz
    It might be your grouping fields.  Group by the non-aggregate fields in your select clause.  Once again, I'm surprised the query actually ran the way you presented it.
    May 31, 2012 11:43 PM   in reply to Sreeindia
    FROM monthsInYear m
    I think it is sufficient to group by just one column, using the table to the left of the join, like this:
    FROM monthsInYear m
    GROUP BY m.monthID
    ORDER BY m.monthID ASC
    Jun 4, 2012 9:27 AM   in reply to wmkolcz
    But when I run this, it gives me total for only the months that have a total and not the 0 for the ones that come up as null. Any ideas?
    Also tried
    SELECT m.month, IFNULL( SUM(i.cost), 0 ) AS amount
    FROM getExpenses i LEFT OUTER JOIN monthsInYear m
    ON m.monthID = EXTRACT(MONTH FROM i.dateAdded)
    WHERE orgID = 10031
    AND YEAR(i.dateAdded) = '2011'
    GROUP BY m.month
    ORDER BY EXTRACT(MONTH FROM i.dateAdded) ASC
    There are two problems. First, the tables in your join are reversed. A LEFT JOIN returns all records from the left hand table (expenses) even if there are no matching records in the right hand table. What you want is the opposite. So the months table must on be on the left side of the JOIN:
                FROM    monthsInYear m LEFT JOIN getExpenses i ON m.monthID = EXTRACT(MONTH FROM i.dateAdded)
    Second, when there is no matching expense record, the column values will all be null. So as soon as you use one of the expense fields in your WHERE clause, ie
                WHERE i.orgID = 10031
    ... those missing records are dropped, because a null value is never equal to anything. So you are negating the outer join altogether. You need to move those conditions into the JOIN clause instead:
                  FROM   monthsInyear m LEFT OUTER JOIN getExpenses i
                                            AND i.orgID = 10031
                                            AND YEAR(i.dateAdded) = 2011
                 GROUP BY m.month
                 ORDER BY m.month
