Text on all the forum discussion topic lists are now like 10-11pixels in size. Way too small.
Yes they have, and a major sore point with me. Not only is it hard to read, the type is so small it is hard to tell it the post is bold (unread) or not.
There is no reasson for this microtype, and I use a 24 inch screen.
But the pannel on the right has larger font which I guess is the important part for Adobe.
Well, for Internet Explorer you may press CTRL and the + key to increase the font size... I did that, once was enough, to make the text easier to read
You would press CTRL and the - key to unzoom... each key press is a 10% change, from what I read at Microsoft
http://search.microsoft.com/search.aspx?mkt=en-US&setlang=en-US
As has been said numerous times, yes there are workarounds, but why should we have to do that to get a usable workplace and it is a weak workaround at best.
Yes it makes the type larger, but it makes the spaces and headers larger also. So you end up with a small view of the page, especially noticable when in reply mode. You then end up doing a lot of scrolling.
It is a kick in the gut that Adobe does not take into consideration points raised by the main helpers on these sites. Where is the input for Adobe to change in the first place?
Web page zooming is NOT a viable solution.
Any web designer will IMMEDIATELY explain that expecting users to change standard behavior of the browser so your site specifically will be functional is ludicrous. Adobe, being the leader of creative industry creation applications, should hold themsleves to at the very least a standard used by every other web designer on the planet.
10px, bold, light blue, text would not be recommended on ANY site if the text is expected to be read. And in a discussion forum it's nothing short of insulting and reflects contempt for the users. So many of Adobe's help lines are relieved by the fact users can post in forums for solutions. If one can't read the text.. why bother ever even looking at the forums?
Ctrl+ / Ctrl- works on most browsers (on Windows, at least).
It is a good way to make the main section of the forum easily readable. On the other hand, it will create overlays in various places.
You are probably right. However, making fonts generally bigger (as it was in the 1st round of this new skin), is not a solution either.
I think the text size needs to be adjusted according to the users' screen resolution. The layout for a 800x600 monitor must be completely different than for a 2000+ monitor.
However, I don't think the designers/authors of this new skin are capable of such a radical concept.
Grove25,
I have noticed the same thing. While it does not look "refined," it might be helpful when viewed on some devices. That one, I can live with, but if other changes are enacted, someone might want to address it.
Looks OK in the editor, but then, when posted, the leading seems to increase a few points.
Hunt
