URL change after pasting
May 31, 2012 8:05 PM
Hi everyone,
I'm not sure if I should be posting this question here or in the regular Indesign forum but I'll try here first.
I created a new URL hyperlink and pasted the following link into the field:
http://law.ato.gov.au/atolaw/view.htm?docid=AID/AID2004688/00001
But when I click OK and then look in the URL field in the hyperlinks panel, I see that Indesign has changed the link to the following:
http://law.ato.gov.au/atolaw/view.htm%3Fdocid%3DAID/AID2004688/00001
Notice how it's swapping out the question mark (?) after .htm with %3F.
It's also swapping out the equals sign (=) with %3D.
This breaks the URL and makes it no longer workable.
I wondered if anyone knows why this is happening and whether there's a workaround?
Appreciate any help.
    May 31, 2012 10:24 PM   in reply to gwhPoster
    I tested with CS5:
    I have copied the URL and I have created a hyperlink manually, it works as expected. How do you create your links? %3D, %3F are url encoded characters. i.e: %xx, where xx is the hexadecimal value of the character code in the Unicode character set.
    Green4ever
    Jun 1, 2012 9:10 PM   in reply to gwhPoster
    I've don't have access to CS6. Hope someone will response to you.
    Jun 4, 2012 6:08 AM   in reply to Green4ever
    @gwhPoster – I answered in your thread at the InDesign forum (where your question initially caught my interest):
    http://forums.adobe.com/message/4459096#4459096
    Answer #1.
    The problem seems to be a bug, that made it from the beta to the final version of InDesign CS6.
    Please answer in the InDesign forum.
    @John Hawkinson: since I have no access to the bug base of InDesign CS6, can you confirm that there is a bug report for that problem? Or did we catch an unknown bug in this case?
    Uwe
    Jun 5, 2012 1:01 AM   in reply to Laubender
    Uwe,
    At this point, none of us have access to the ID bugbase for CS6.
    To make sure the bug is logged, please do so here:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Harbs
    Jun 5, 2012 1:39 AM   in reply to Harbs.
    @Harbs – just filed the bug report.
    The problem should be serious enough, especially for DPS users, that I expect it corrected with inDesign 8.0.1 in the near future…
    Uwe
