Can't download... Download Error (403)
Could you please explain a bit more where you are getting this error and the exact error message you are getting. This will help us in understanding you problem.
I am for I can not download photoshop 6 and always error 101
Please share the following logs from your machine:
On windows: %temp%/AdobeDownload/DLMNative.log
On mac: ~/Library/Logs/AdobeDownload/DLMNative.log
-thanks
After update to Version 4.3.0.256 released on 09/26/2017 I have a problem like this Download Error. Reload don't take eny effect... What should i do?.....
Windows 10 Pro x64 All Windows updates installed
I have the same problem
also have this problem on windows 10 64x.
Have you tried again and did it work?
The Download Error occurs in the Adobe Application Manager. I attempt to download a program and I get, "Download Error, please retry (which I have done several times) or contact customer support (which hasn't been easy). Error 403...
Which Os are you on and which version.
I'm moving this thread over to our download/installation forum.
For general Creative Cloud Membership questions, here is the FAQ link:
http://www.adobe.com/products/creativecloud/faq.html
-Dave
There is no information here about how to sort out this error problem. Trying to get hold of support from this page is also absolutely frustrating.s
This is what we get from the Adobe application manager.
Denzil
Can you please attach the log content here. It will help us identify the problem.
I am just the end user? Where would I find these log content? Your system
is not the best when it comes to helping the end user.
Denzil
On mac: ~/Library/Logs/AdobeDownload/DLMNative.log (on Lion open the Terminal app and type "open Library/" then go to the subfolder)
Sorry. That did not help I cannot find that location on my computer, I
checked all Adobe folders. I checked the windows folder. I checked all Temp
folders I came across. I even did a search for the location using the
windows search option. I cannot find that location. I think it will be
easier to phone???
Denzil
In MS-DOS and Microsoft Windows, the temporary directory is set by the environment variable TEMP. Originally, the default was c:\Temp, then %Windows%\Temp. In the XP era, the temporary directory was set per-user as Local Settings\Temp, although still user-relocatable. For Windows Vista, 7 & 8 the temp location has moved again to within the AppData section of the User Profile typically C:\Users\User Name\AppData\Local\Temp. In all versions of Windows the temp location can be accessed, for example in Explorer, Run... boxes and in application's internal code by using %temp%, as with other environmental variables it is synonymous with the full path.
Hey everyone,
I've encountered the same issue!
Where is support?
Good thing there is a 30 day money back guarantee on subscriptions!
06/01/12 13:22:22:576 | [INFO] | | | | | | | Calling regsvr32 C:\Windows\system32\regsvr32.exe /s C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities
06/01/12 13:22:22:980 | [INFO] | | | | | | | Finished regsvr32. Exit code: 0
06/01/12 13:22:22:980 | [INFO] | | | | | | | Calling regsvr32 C:\Windows\system32\regsvr32.exe /s C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities
06/01/12 13:22:23:317 | [INFO] | | | | | | | Finished regsvr32. Exit code: 0
06/01/12 13:22:23:317 | [INFO] | | | | | | | AAM URI protocol handler registered.
06/01/12 13:22:23:546 | [INFO] | | | | | | | AAM URI: AAM shortcut created on all user's desktop and start menu adobe folder.
06/01/12 13:23:00:601 | [INFO] | | | | | | | Calling regsvr32 C:\Windows\system32\regsvr32.exe /s C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities
06/01/12 13:23:00:727 | [INFO] | | | | | | | Finished regsvr32. Exit code: 0
06/01/12 13:23:00:728 | [INFO] | | | | | | | Calling regsvr32 C:\Windows\system32\regsvr32.exe /s C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities
06/01/12 13:23:00:874 | [INFO] | | | | | | | Finished regsvr32. Exit code: 0
06/01/12 13:23:00:874 | [INFO] | | | | | | | AAM URI protocol handler registered.
06/01/12 13:23:00:919 | [INFO] | | | | | | | AAM URI: AAM shortcut created on all user's desktop and start menu adobe folder.
06/01/12 13:23:43:314 | [INFO] | | | | | | | Session is created and key generated is {B18B373D-6218-417C-A772-3889A2F5CBBE}
06/01/12 13:23:46:521 | [WARN] | {B18B373D-6218-417C-A772-3889A2F5CBBE} | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 13:23:46:521 | [ERROR] | {B18B373D-6218-417C-A772-3889A2F5CBBE} | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/win32/AAMVersion.xml). DLE error status is -2
06/01/12 13:23:54:540 | [WARN] | {B18B373D-6218-417C-A772-3889A2F5CBBE} | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 13:23:54:541 | [ERROR] | {B18B373D-6218-417C-A772-3889A2F5CBBE} | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/win32/AAMVersion.xml). DLE error status is -2
06/01/12 13:27:10:662 | [INFO] | {B18B373D-6218-417C-A772-3889A2F5CBBE} | | | | | | Going to close the session
06/01/12 13:27:10:665 | [INFO] | {B18B373D-6218-417C-A772-3889A2F5CBBE} | | | | | | All waiting operations finished for this session
06/01/12 13:31:58:952 | [INFO] | | | | | | | Session is created and key generated is {523BE79C-0026-41D3-9212-966B08519DBD}
06/01/12 13:32:02:168 | [WARN] | {523BE79C-0026-41D3-9212-966B08519DBD} | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 13:32:02:168 | [ERROR] | {523BE79C-0026-41D3-9212-966B08519DBD} | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/win32/AAMVersion.xml). DLE error status is -2
06/01/12 13:34:48:380 | [WARN] | {523BE79C-0026-41D3-9212-966B08519DBD} | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 13:34:48:380 | [ERROR] | {523BE79C-0026-41D3-9212-966B08519DBD} | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/win32/AAMVersion.xml). DLE error status is -2
06/01/12 13:34:52:970 | [WARN] | {523BE79C-0026-41D3-9212-966B08519DBD} | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 13:34:52:971 | [ERROR] | {523BE79C-0026-41D3-9212-966B08519DBD} | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/win32/AAMVersion.xml). DLE error status is -2
06/01/12 13:34:56:385 | [INFO] | {523BE79C-0026-41D3-9212-966B08519DBD} | | | | | | Going to close the session
06/01/12 13:34:56:386 | [INFO] | {523BE79C-0026-41D3-9212-966B08519DBD} | | | | | | All waiting operations finished for this session
06/01/12 13:35:18:846 | [INFO] | | | | | | | Session is created and key generated is {4BFDA2FC-C751-42FC-B0B5-C3EBFCF6F999}
06/01/12 13:35:21:930 | [WARN] | {4BFDA2FC-C751-42FC-B0B5-C3EBFCF6F999} | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 13:35:21:930 | [ERROR] | {4BFDA2FC-C751-42FC-B0B5-C3EBFCF6F999} | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/win32/AAMVersion.xml). DLE error status is -2
I managed to get assistance from Support.
They had me DL the trial version of my product outside of https://creative.adobe.com/apps bypassing application manager.
Install, log-in and and activate.
Support indicated Adobe is working on the Application manager issue.
Sadly, there is no Mac OSX trial version of Acrobat Pro, which is what I need right now, to do my JOB.
Hi guys - having same issue as Denzilern
log file below
05/25/12 17:50:22:144 | [INFO] | | | | | | | AAM URI protocol handler registered.
05/25/12 17:50:22:164 | [INFO] | | | | | | | Adobe Application Manager shortcut created at /Applications/
05/25/12 17:50:22:574 | [INFO] | | | | | | | AAM Helper: Closing IPC Channel
05/25/12 17:50:24:640 | [INFO] | | | | | | | Launching AAM Helper process at start time itself.
05/25/12 17:50:25:017 | [INFO] | | | | | | | Session is created and key generated is 17A7A399-D919-4682-AF73-C66029C18992
05/25/12 17:50:51:282 | [ERROR] | | | | | | | Failed to get the pref data from the opm db
05/25/12 17:51:04:760 | [INFO] | | | | | | | Session is created and key generated is 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD
05/25/12 17:51:05:110 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | The value of ETAG for the file is "66417bef5d6a904b09b647edc71d24aa:1335657217"
05/25/12 17:51:06:635 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | The value of ETAG for the file is "ee25f7aea9949e6a0865622b1b90e35b:1335657217"
05/25/12 17:51:08:407 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | The value of ETAG for the file is "47e7d858d354c37ec79cfa692c1162ca:1335583358"
05/25/12 18:04:03:254 | [INFO] | | | | | | | deployment lock has been acquired.
05/25/12 18:04:07:984 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | launchDE for session = 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD
05/25/12 18:04:07:985 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | Going to init the IPC channel
05/25/12 18:04:08:162 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | De has been launched. Listening on the IPC now...
05/25/12 18:04:08:162 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | IPC has been initialized
05/25/12 18:08:16:304 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | done packet received from the DE with exit code - 0
05/25/12 18:08:16:837 | [INFO] | | | | | | | Trying to unmount the dmg mounted at path - /Volumes/Adobe InDesign CS6
05/25/12 18:08:18:634 | [INFO] | | | | | | | Trying to unmount the dmg mounted at path - /Volumes/Adobe InDesign CS6
05/25/12 18:08:18:714 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | Going to close the session
05/25/12 18:08:20:786 | [INFO] | 706A7B12-F9BB-472B-86A9-BE7BE94FB2DD | | | | | | All waiting operations finished for this session
05/25/12 18:17:18:136 | [INFO] | 17A7A399-D919-4682-AF73-C66029C18992 | | | | | | Going to close the session
05/25/12 18:17:18:138 | [INFO] | 17A7A399-D919-4682-AF73-C66029C18992 | | | | | | All waiting operations finished for this session
05/31/12 14:57:02:433 | [INFO] | | | | | | | Session is created and key generated is A51C4DD0-B2C1-4800-889C-5D5FF5DA2358
05/31/12 14:57:04:072 | [WARN] | A51C4DD0-B2C1-4800-889C-5D5FF5DA2358 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 14:57:04:072 | [ERROR] | A51C4DD0-B2C1-4800-889C-5D5FF5DA2358 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 14:57:13:351 | [WARN] | A51C4DD0-B2C1-4800-889C-5D5FF5DA2358 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 14:57:13:351 | [ERROR] | A51C4DD0-B2C1-4800-889C-5D5FF5DA2358 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 14:57:16:737 | [INFO] | A51C4DD0-B2C1-4800-889C-5D5FF5DA2358 | | | | | | Going to close the session
05/31/12 14:57:16:738 | [INFO] | A51C4DD0-B2C1-4800-889C-5D5FF5DA2358 | | | | | | All waiting operations finished for this session
05/31/12 15:01:16:006 | [INFO] | | | | | | | Session is created and key generated is 93266430-79B1-4E67-8B05-11EF44652B57
05/31/12 15:01:18:277 | [WARN] | 93266430-79B1-4E67-8B05-11EF44652B57 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:01:18:277 | [ERROR] | 93266430-79B1-4E67-8B05-11EF44652B57 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:01:21:654 | [WARN] | 93266430-79B1-4E67-8B05-11EF44652B57 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:01:21:654 | [ERROR] | 93266430-79B1-4E67-8B05-11EF44652B57 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:01:25:340 | [WARN] | 93266430-79B1-4E67-8B05-11EF44652B57 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:01:25:340 | [ERROR] | 93266430-79B1-4E67-8B05-11EF44652B57 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:01:28:140 | [INFO] | 93266430-79B1-4E67-8B05-11EF44652B57 | | | | | | Going to close the session
05/31/12 15:01:28:141 | [INFO] | 93266430-79B1-4E67-8B05-11EF44652B57 | | | | | | All waiting operations finished for this session
05/31/12 15:01:45:008 | [INFO] | | | | | | | Session is created and key generated is 4FB4E749-449E-4D3F-B46A-A5D4FFDC850F
05/31/12 15:01:46:138 | [WARN] | 4FB4E749-449E-4D3F-B46A-A5D4FFDC850F | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:01:46:138 | [ERROR] | 4FB4E749-449E-4D3F-B46A-A5D4FFDC850F | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:01:48:020 | [INFO] | 4FB4E749-449E-4D3F-B46A-A5D4FFDC850F | | | | | | Going to close the session
05/31/12 15:01:48:021 | [INFO] | 4FB4E749-449E-4D3F-B46A-A5D4FFDC850F | | | | | | All waiting operations finished for this session
05/31/12 15:03:03:196 | [INFO] | | | | | | | Session is created and key generated is 3E10967C-C73A-4475-BF5F-ADABFD5D17BF
05/31/12 15:03:05:132 | [WARN] | 3E10967C-C73A-4475-BF5F-ADABFD5D17BF | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:03:05:132 | [ERROR] | 3E10967C-C73A-4475-BF5F-ADABFD5D17BF | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:03:08:560 | [WARN] | 3E10967C-C73A-4475-BF5F-ADABFD5D17BF | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:03:08:560 | [ERROR] | 3E10967C-C73A-4475-BF5F-ADABFD5D17BF | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:03:10:219 | [INFO] | 3E10967C-C73A-4475-BF5F-ADABFD5D17BF | | | | | | Going to close the session
05/31/12 15:03:10:220 | [INFO] | 3E10967C-C73A-4475-BF5F-ADABFD5D17BF | | | | | | All waiting operations finished for this session
05/31/12 15:03:17:417 | [INFO] | | | | | | | Session is created and key generated is 74F563D7-0820-40AA-81FB-5D1616F25A3F
05/31/12 15:03:18:967 | [WARN] | 74F563D7-0820-40AA-81FB-5D1616F25A3F | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:03:18:967 | [ERROR] | 74F563D7-0820-40AA-81FB-5D1616F25A3F | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:03:21:072 | [INFO] | 74F563D7-0820-40AA-81FB-5D1616F25A3F | | | | | | Going to close the session
05/31/12 15:03:21:073 | [INFO] | 74F563D7-0820-40AA-81FB-5D1616F25A3F | | | | | | All waiting operations finished for this session
05/31/12 15:15:15:881 | [INFO] | | | | | | | Session is created and key generated is AA40581E-2C38-486F-8072-981F7114D454
05/31/12 15:15:16:536 | [WARN] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:15:16:536 | [ERROR] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:15:19:343 | [WARN] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:15:19:343 | [ERROR] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:15:20:956 | [WARN] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:15:20:956 | [ERROR] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:15:22:594 | [WARN] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:15:22:594 | [ERROR] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:15:24:123 | [INFO] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | Going to close the session
05/31/12 15:15:24:124 | [INFO] | AA40581E-2C38-486F-8072-981F7114D454 | | | | | | All waiting operations finished for this session
05/31/12 15:16:20:042 | [INFO] | | | | | | | Session is created and key generated is E72E119B-0106-4538-9A42-8A1FF4EF70A8
05/31/12 15:16:20:921 | [WARN] | E72E119B-0106-4538-9A42-8A1FF4EF70A8 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:16:20:921 | [ERROR] | E72E119B-0106-4538-9A42-8A1FF4EF70A8 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:16:24:860 | [INFO] | E72E119B-0106-4538-9A42-8A1FF4EF70A8 | | | | | | Going to close the session
05/31/12 15:16:24:861 | [INFO] | E72E119B-0106-4538-9A42-8A1FF4EF70A8 | | | | | | All waiting operations finished for this session
05/31/12 15:16:36:903 | [INFO] | | | | | | | Session is created and key generated is 060CF575-675E-41C1-9247-29287A521B7D
05/31/12 15:16:37:748 | [WARN] | 060CF575-675E-41C1-9247-29287A521B7D | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:16:37:748 | [ERROR] | 060CF575-675E-41C1-9247-29287A521B7D | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:16:40:106 | [INFO] | 060CF575-675E-41C1-9247-29287A521B7D | | | | | | Going to close the session
05/31/12 15:16:40:107 | [INFO] | 060CF575-675E-41C1-9247-29287A521B7D | | | | | | All waiting operations finished for this session
05/31/12 15:16:46:494 | [INFO] | | | | | | | Session is created and key generated is 747F4831-8F0C-474D-9DBE-C2972A865A1E
05/31/12 15:16:47:553 | [WARN] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:16:47:554 | [ERROR] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:16:50:824 | [WARN] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:16:50:824 | [ERROR] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:16:52:771 | [WARN] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:16:52:771 | [ERROR] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:16:54:643 | [WARN] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:16:54:643 | [ERROR] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:16:56:211 | [WARN] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:16:56:211 | [ERROR] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:16:57:522 | [WARN] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 15:16:57:522 | [ERROR] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 15:17:01:730 | [INFO] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | Going to close the session
05/31/12 15:17:01:730 | [INFO] | 747F4831-8F0C-474D-9DBE-C2972A865A1E | | | | | | All waiting operations finished for this session
05/31/12 16:06:22:459 | [INFO] | | | | | | | Session is created and key generated is BBB131BC-EE09-464B-BA6E-BCB7A832059B
05/31/12 16:06:23:719 | [WARN] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 16:06:23:719 | [ERROR] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 16:06:27:727 | [WARN] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 16:06:27:727 | [ERROR] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 16:06:29:041 | [WARN] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 16:06:29:041 | [ERROR] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 16:06:30:627 | [WARN] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 16:06:30:628 | [ERROR] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 16:06:48:692 | [INFO] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | Going to close the session
05/31/12 16:06:48:693 | [INFO] | BBB131BC-EE09-464B-BA6E-BCB7A832059B | | | | | | All waiting operations finished for this session
05/31/12 17:24:15:709 | [INFO] | | | | | | | Session is created and key generated is 990DB190-5A9A-4D7F-8E5C-7EAFC177727F
05/31/12 17:24:16:294 | [WARN] | 990DB190-5A9A-4D7F-8E5C-7EAFC177727F | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 17:24:16:295 | [ERROR] | 990DB190-5A9A-4D7F-8E5C-7EAFC177727F | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 17:29:57:575 | [WARN] | 990DB190-5A9A-4D7F-8E5C-7EAFC177727F | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 17:29:57:575 | [ERROR] | 990DB190-5A9A-4D7F-8E5C-7EAFC177727F | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 17:33:33:723 | [INFO] | 990DB190-5A9A-4D7F-8E5C-7EAFC177727F | | | | | | Going to close the session
05/31/12 17:33:33:724 | [INFO] | 990DB190-5A9A-4D7F-8E5C-7EAFC177727F | | | | | | All waiting operations finished for this session
05/31/12 17:35:28:693 | [INFO] | | | | | | | Session is created and key generated is BD442AC0-7AA3-4297-99D6-98508DB46DB3
05/31/12 17:35:30:488 | [WARN] | BD442AC0-7AA3-4297-99D6-98508DB46DB3 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 17:35:30:488 | [ERROR] | BD442AC0-7AA3-4297-99D6-98508DB46DB3 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 17:35:33:962 | [WARN] | BD442AC0-7AA3-4297-99D6-98508DB46DB3 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 17:35:33:963 | [ERROR] | BD442AC0-7AA3-4297-99D6-98508DB46DB3 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 17:35:36:729 | [WARN] | BD442AC0-7AA3-4297-99D6-98508DB46DB3 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 17:35:36:730 | [ERROR] | BD442AC0-7AA3-4297-99D6-98508DB46DB3 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 17:35:42:274 | [INFO] | BD442AC0-7AA3-4297-99D6-98508DB46DB3 | | | | | | Going to close the session
05/31/12 17:35:42:603 | [INFO] | BD442AC0-7AA3-4297-99D6-98508DB46DB3 | | | | | | All waiting operations finished for this session
05/31/12 17:36:04:943 | [INFO] | | | | | | | Session is created and key generated is 8C3A0178-03A5-454D-BD20-023DE0B2DFE8
05/31/12 17:36:07:092 | [WARN] | 8C3A0178-03A5-454D-BD20-023DE0B2DFE8 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
05/31/12 17:36:07:092 | [ERROR] | 8C3A0178-03A5-454D-BD20-023DE0B2DFE8 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
05/31/12 17:36:11:467 | [INFO] | 8C3A0178-03A5-454D-BD20-023DE0B2DFE8 | | | | | | Going to close the session
05/31/12 17:36:11:467 | [INFO] | 8C3A0178-03A5-454D-BD20-023DE0B2DFE8 | | | | | | All waiting operations finished for this session
Succesfully was able to log in to AAM and start download after removing following folders from System level Application Support, quitting InDesign CS6 then relogging into creative.adobe.com.
AAMUpdater
AAMUpdaterInventory
AdobeApplicationManager
This is the error message that I got.
Denzil
This is my error for MUSE download and install..
06/01/12 06:19:51:953 | [WARN] | {CCDE7BA6-DF71-45F6-8F55-E51635801FAF} | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 06:19:51:953 | [ERROR] | {CCDE7BA6-DF71-45F6-8F55-E51635801FAF} | | | | | | Failed to get the file size for the file (http://ccmdl.adobe.com/AdobeProducts/MUSE/1/win32/Muse_1_0_CCM_LS10.exe). DLE error status is -2
As of late June 2. I was able to download Muse on my home comp. via the AAM system 🙂
Message was edited by: mrbugjacobs
Same here:
06/01/12 14:01:58:590 | [INFO] | | | | | | | AAM URI protocol handler registered.
06/01/12 14:01:58:591 | [WARN] | | | | | | | AAM URI: Failed to create Adobe Application Manager shortcut.
06/01/12 14:03:18:009 | [INFO] | | | | | | | AAM URI protocol handler registered.
06/01/12 14:03:18:010 | [WARN] | | | | | | | AAM URI: Failed to create Adobe Application Manager shortcut.
06/01/12 14:03:30:812 | [INFO] | | | | | | | Session is created and key generated is 68175249-904D-4180-BABE-FE9674525261
06/01/12 14:03:31:507 | [WARN] | 68175249-904D-4180-BABE-FE9674525261 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 14:03:31:507 | [ERROR] | 68175249-904D-4180-BABE-FE9674525261 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
06/01/12 14:03:35:966 | [INFO] | 68175249-904D-4180-BABE-FE9674525261 | | | | | | Going to close the session
06/01/12 14:03:35:968 | [INFO] | 68175249-904D-4180-BABE-FE9674525261 | | | | | | All waiting operations finished for this session
06/01/12 14:07:35:607 | [INFO] | | | | | | | Session is created and key generated is C5F53B0A-086E-4DF1-8B7F-FE003250FD4E
06/01/12 14:07:36:304 | [WARN] | C5F53B0A-086E-4DF1-8B7F-FE003250FD4E | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 14:07:36:305 | [ERROR] | C5F53B0A-086E-4DF1-8B7F-FE003250FD4E | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
06/01/12 14:07:40:420 | [INFO] | C5F53B0A-086E-4DF1-8B7F-FE003250FD4E | | | | | | Going to close the session
06/01/12 14:07:40:421 | [INFO] | C5F53B0A-086E-4DF1-8B7F-FE003250FD4E | | | | | | All waiting operations finished for this session
06/01/12 14:10:13:312 | [INFO] | | | | | | | Session is created and key generated is 750BA72D-1094-4B1C-9982-DB890C965D7D
06/01/12 14:10:14:409 | [WARN] | 750BA72D-1094-4B1C-9982-DB890C965D7D | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 14:10:14:409 | [ERROR] | 750BA72D-1094-4B1C-9982-DB890C965D7D | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
06/01/12 14:10:17:639 | [WARN] | 750BA72D-1094-4B1C-9982-DB890C965D7D | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 14:10:17:640 | [ERROR] | 750BA72D-1094-4B1C-9982-DB890C965D7D | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
06/01/12 14:11:13:794 | [INFO] | 750BA72D-1094-4B1C-9982-DB890C965D7D | | | | | | Going to close the session
06/01/12 14:11:13:794 | [INFO] | 750BA72D-1094-4B1C-9982-DB890C965D7D | | | | | | All waiting operations finished for this session
06/01/12 14:12:04:873 | [INFO] | | | | | | | AAM URI protocol handler registered.
06/01/12 14:12:04:918 | [INFO] | | | | | | | Adobe Application Manager shortcut created at /Applications/
06/01/12 14:12:14:470 | [INFO] | | | | | | | Session is created and key generated is 85280327-709A-458B-9A01-D1C417329B34
06/01/12 14:12:15:511 | [WARN] | 85280327-709A-458B-9A01-D1C417329B34 | | | | | | Some Error has come during download operation with Error type - -40, and Error Code - 403
06/01/12 14:12:15:512 | [ERROR] | 85280327-709A-458B-9A01-D1C417329B34 | | | | | | Failed to get the file size for the file (https://ccmdls.adobe.com/AdobeProducts/AAM/1/osx10/AAMVersion.xml). DLE error status is -2
06/01/12 14:14:23:232 | [INFO] | 85280327-709A-458B-9A01-D1C417329B34 | | | | | | Going to close the session
06/01/12 14:14:23:233 | [INFO] | 85280327-709A-458B-9A01-D1C417329B34 | | | | | | All waiting operations finished for this session
