Elisa WD
Cannot put dwt file to remote /BC site
May 30, 2012 1:56 AM
Hey... I cannot put my dwt file to a BC site.
I got to the point where my template.dwt was ready and I put the site to remote server. But the template does not go to remote: Templates:template.dwt - error occured.
Any ideas? I also tried to create a new site straight in BC but the option to import a site of my own is not available:
Import your current website in minutes and build it yourself from there (This option is currently not available)
Then I went back to DW and decided to try and create a new template from scratch ( in case I missed something before)
and then I noticed that there is a chekbox which is grayed out in all of the html templates.
The link under goes to Adobe site where it just says that since 2010 InContext Editing will be discountinued as a standalone service…
So… Is it possible to use my own template with BC? Does anyone know?
  • Liam Dilley
    Feb 28, 2012
    May 30, 2012 2:10 AM   in reply to Elisa WD
    Hey there, Your usign CS6 or 5? If five and using the BC extension you need to mange your BC stuff through there. With CS6 you need to use the integrated features
    You can not "Put" any DWT files onto the BC system manually via FTP into the templates folder, it only handles .html files. If your using DW you use the BC stuff which converts .dwt files into the .html files it needs to work.
  • Liam Dilley
    Feb 28, 2012
    May 30, 2012 4:07 AM   in reply to Elisa WD
    The BC part of Dreamweaver converts dwt files. The system itsefl does not.
    I use Coda2, I do not use DW6 so you will need to wait for someone who does to use it.
    May 30, 2012 7:18 AM   in reply to Elisa WD
    I had this problem as well , My solution was when setting up your FTP setting in DW  in the username you have to put /dw after your username, thats what lets the .dwt file to be uploaded
    Cheers
    Laz
    May 30, 2012 5:46 PM   in reply to lazmattlabs
    I use CS6 and no PUT/ GET .dwt issues at all. there are a few login screens for some odd reason make sure you're logged-in to BC both FTP and the BC panel.
  • Liam Dilley
    Feb 28, 2012
    May 31, 2012 4:20 AM   in reply to Elisa WD
    Your not uploading files, you can not just put as a standard put to the server. Use the BC stuff to do that.
    May 31, 2012 7:50 AM   in reply to Elisa WD
    Hi Elisa,
    Can you please send me a private message and attach that .dwt file? Or open a new case and attach the template to the case so we can have a closer look.
    Thanks and regards,
    Florin Carlig
    Jun 1, 2012 1:24 AM   in reply to Elisa WD
    Hi Elisa,
    Looking at the code, the problem might be that you don't have the {tag_pagecontent} tag in the editable region that's inside the <body> tag. Business Catalyst requires a specific template structure: only one editable region in the <body> (besides the other 2 that Dreamweaver creates inside the <head> tag) and that region has to have the {tag_pagecontent} tag. You can see more details in this article that details how Business Catalyst and Dreamweaver work: http://www.businesscatalyst.com/support/dw#templates
    Hope this helps.
    Florin Carlig
    Dec 4, 2012 1:25 PM   in reply to lazmattlabs
    WOW. What an odd thing. Adding the DW worked for me too!
    My hero for the day, you are.
