SqueezerRAH
3D Rendering
May 31, 2012 6:05 AM
Tags: #3d #cs6
After creating a reflection of a text extrusion in CS6 Extended, when I select 3D>Render the rendering process erases the reflection. The opacity is up and the selected colors are quite visible. This does not happen all the time, just most of the time. Is there something that I'm doing wrong or is this a bug? Anybody else having this problem?
Thanks in advance. Mike
    Jun 1, 2012 12:01 PM   in reply to SqueezerRAH
    Yes, there is a bug if you have:
    1. Set ground plane shadow opacity to 0%
    2. Set ground plane reflection opacity to 100%
    If these are set at the same time the reflection disappears.
    Work Around is:
    1. Set Shadow Opacity to 1%
    2. In the 3D Panel select > SCENE and check Linearize Colors, you can uncheck it after it works, renders again.
    OR
    2. Change the camera move, or move mesh
    Let me know if that does not work.
