Clip Markers mislocation (CS6)
Jun 1, 2012 3:22 PM
Clip Markers are mislocated after changing Clip Speed in Timeline:
Steps to reproduce bug:
1.Place a Clip in a Sequence
2.Add Marker somewhere in the clip, set Marker Duration so that the label will be visible
3.Razor the clip at the marker
4.Change Speed of the first part of the razored clip
Results:Markers are mislocated
Feature Request/Bug Report Form
  ******BUG******
Concise problem statement:Malfunctioning Clip Markers placement after changing Clip Speed in Timeline
Expected results:No bugs expected
Link: http://www.adobe.com/go/wish
    Jun 1, 2012 3:29 PM   in reply to Steven Pribilinskiy
    Thanks for your feedback!
    Jun 1, 2012 4:30 PM   in reply to Steven Pribilinskiy
    I cannot reproduce
    When i set a marker duration it does not show on the clip.
    I cannot rember doing that in previous versions either.
    Jun 1, 2012 4:35 PM   in reply to Steven Pribilinskiy
    Your video doesn't show you doing that.  You're adding a Sequence Marker of the Encore Chapter variety.  That's not the same as a Clip Marker.
    Jun 2, 2012 2:27 AM   in reply to Steven Pribilinskiy
    Clip marker durattion is green, Encore markers make the druation red and url markers are oranje.
    You can  set Encore marker duration on a clip in the SM, (dont see the need, maybe just for the color).
    After the clip is razored the marker is not mislocated. You now have two instances with different in and out points of the same source clip in the timeline.
    Open them both from the timeline in the SM them you will see.
    When changing speed they will jump even more.
    IMO it is as designed.
    Although one has to click 3 times to get the correct duration shown on a clip in the timeline: double click to select the clip to open in the SM and once to show the duration. This is only when a speed change has been added to the clip and there are more than one instances on the timeline.
    Jun 2, 2012 2:57 AM   in reply to Steven Pribilinskiy
    I have several times and i see what i see.
