What is the Acrobat error 130:11? it says there is a problem with my creative cloud license. I just started and paid for my subscription and it has been working fine since I installed it one week ago.
Your answer was exactly correct. I had a CS3 version installed. I had to uninstall both CS3 and CS6 and start again. Everything is working good now. When the CS6 version installed, it removed the desktop icon so I thought it had uninstalled the CS3. Wonder why it worked for a week and then suddenly the error.
if you had cs3 previously in your computer
>firstly, completely uninstall all components of CS3 you need to run the "cleaner tool"
but take note about the EULA before using this tool.
you can get it here: http://www.adobe.com/support/contact/cscleanertool.html?promoid=GYTAU
>restart computer, then reinstall all softwares
I'm moving this thread over to our download/installation forum.
For general Creative Cloud Membership questions, here is the FAQ link:
http://www.adobe.com/products/creativecloud/faq.html
-Dav
Ok, here I am exactly 1 week later and I have the same error 130:11. This is really a SERIOUS ISSUE. I am locked out of the software when I get this error.
As suggested last time, I uninstalled the CS3 version and reinstalled the cloud version. Now what? Do I have to uninstall the cloud version and reinstall again? Why?
This is unacceptable to receive this kind of error and be locked out of the software when my subscription is perfectly valid and I have lots of work to do!
As a reminder, I had posted in my original message that the software worked for 1 week and then I received the 1st error. If you look at the dates, you will see that I am getting this error again after 1 week, even though I had uninstalled the CS3 version.
This is another unacceptable aspect of this issue. Why can I use the software for 1 week and then out of nowhere I am locked out?
I had already unistalled my earlier version of Acrobat Pro. Got the same error. After visiting this thread, I uninstalled Acrobat X Pro which on my Windows 7 platform has two uninstall options. I had to run uninstall twice since the Application Manager didn't recognize the first uninstall I ran. I then ran the Application Manager download and install, and that came up flagged with an install error. I ran the "fix" via Application Manager and that finally worked. This is the third or fourth time that I've had authorization issues with applications since I started with Creative Cloud (I've had authorization problems with Bridge and Photoshop in addition to Acrobat Pro). It's a real productivity killer to have to troubleshoot these issues and get the apps working again.
I have the CS5 Master Collection installed and a subset of CS4 installed. I'm not going to uninstall these apps, especially with Creative Cloud's flaky authorization behavior. For backward compatibility, InDesign in particular requires me to maintain multiple versions.
It only took me a day to experience the same issue. I'm taking the same, long, unistall and reinstall tack to try and fix it again. This time I also uninstalled Acrobat Reader X figuring maybe there are some shared registry entries that may get reset on this new install. The download is taking forever compared to yesterday's effort. By the way, why can't the Application Manager invoke uninstallation? It's not much of a "manager" since it only appears to do installs. Again the install failed, this time I'm capturing details which follow:
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DW050 ... WARNING: DW066 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 3 error(s), 2 warning(s)
WARNING: DW066: OS requirements not met for {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0
WARNING: DW066: OS requirements not met for {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0
----------- Payload: {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 -----------
ERROR: Error 1321.The Installer has insufficient privileges to modify the file C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\ViewerPS.dll.
ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
MSI Error message: Error 1321.The Installer has insufficient privileges to modify the file C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\ViewerPS.dll.
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Acrobat Professional: Install failed
I have Bridge and InDesign open (trying to do some work while troubleshooting this issue), so perhaps the DLL is in use?
I shut down all Adobe apps and ran install again. Similar message but different files that can't be overwritten:
Exit Code: 6
ERROR: Error 1321.The Installer has insufficient privileges to modify the file C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\acrobat.tlb.
MSI Error message: Error 1321.The Installer has insufficient privileges to modify the file C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\acrobat.tlb.
Great. Third install attempt also failed. I run my system as an admin, but I'll see if I can restart Application Manager with sysadmin priveleges. I don't know what the "OS requirements..." messages are about.
Hi BJN3
firstly....
>are you logged in as an "administrator"
try to log in as administrator with read and write permissions
then try to reinstall
please let me know if these helps....
Hi Jain,
I sent the log files from the previous instance of the error to David Baxter who forwarded them for analysis. Would it be helpful for me to send the logs again after the recurrence of the event?
I started the Adobe Application Manager using Run as Administrator (I run my system as Administrator anyway) and that did not affect the installer errors. I kept running the install fix and as with the earlier event, the intall eventually worked. Acrobat X is running, but I fully expect the 130:11 error to return.
BJ
This should not happen again if it has working fine. But if you can provide following details it would really help us to understand the root cause of the issue:
You can alternatively mail me at priyjain@adobe.com if above information cannot be posted on forum.
-Priyank
As I posted, the error has already happened again this morning with the first pdf I attempted to open.
I'm sorry, I can't recall the specifics of the Acrobat Pro X install. I have had serialized versions of Acrobat Pro X installed before for multiple Creative Suite versions. The latest serialized version I had installed was with CS5 Master Collection (so it was serialized with the CS5 perpetual license). I do not have any other version of Acrobat Pro installed on my system. I had Reader X installed, I removed it while trying to troubleshoot the Pro X issue, and I just reinstalled Reader X so I have some means of reading pdf files.
When I installed Pro X, I believe I read that I needed to run an uninstaller before installing Acrobat Pro X and I recall instructions for removal via an Adobe tech web page. The prior version is not installed on my system it would make sense that I uninstalled it.
I have had Creative Cloud authorization errors with other suite applications, but these clear themselves up unlike this issue with Acrobat Pro X.
I have set Acrobat Reader X to open pdfs with my system and via Bridge CS6 until there's some fix for this 130:11 error.
You say it should not happen again. But we will see.
It was working fine for 1 week before I received the error. Then after uninstalling the previous version of Acrobat CS3, it worked again for 1 week and then the error was received.
To answer your questions:
1. Creative Design Suite CS3 was installed
2. Flash CS5 was installed
3. Perpetual license for both
Hope this helps.
Can you please try following to resolve this issue:
-Priyank
Yes!!! That's the answer.
You need to activate the account -- even though the only way to download the Cloud materials is with that account.
Adobe: You can do better than that. Possibly by adding some INSTRUCTIONS, or DIRECTIONS, or simply ASKING us to re0enter out Adobe names etc.
I (and many other new users) have wasted HOURS on this nonsense. I was about to cancel my Cloud account.
HoodedFang
Hi HoodedFang, I stumbled on this fix before and I doubt it's more than a temporary workaround that you may have to use with some frequency. I was working with Pro X for some time before it started generating 130:11 errors and I've had to redo activation with other CS6 apps before Acrobat Pro started acting up.
Right now I'm running the trial version of Acrobat Pro X as another workaround pending a more permanent solution to this problem. Good luck and recommend staying tuned.
After 7 days, the 130:11 error was back. I had not installed any other programs, so I installed Muse. When I launched it, it did not give me a Trial Expired screen or ability to login with my AdobeID.
However, after installing Muse, the Acrobat X program worked.
Now we will see if the error returns again in 7 days.
As I suspected. This is only a one-time workaround solution.
Once again, one week later my Acrobat X receives the 130:11 error. This has happened 4 weeks in a row.
This week I opened Muse and did not receive the Trial Expired screen and it did not clear up the problem.
This is horrible!!! I am in the middle of finalizing a client project for tomorrow and cannot afford to stop, uninstall and reinstall acrobat.
Why isn’t this issue being corrected once and for all?
I repeat what so many others have said, Come on Adobe – you can do better than this.
When is this issue going to be fixed?
Debra Miller
I've provided diagnostic log files and understand that Adobe's working on the problem. Until the fix comes, the workaround that I'm using is to unistall Acrobat X and instead of installing it via Adobe Application Manager, install the Acrobat X trial from the Adobe site. This would keep you running for more than a week, and hopefully long enough to have the fix update released.
OK. Here it is 1 week later and again the error 130:11 is here! Unbelievable that this has not been fixed.
Opening another Acrobat software does not help. The only thing I can do is either uninstall and reinstall Acrobat or install another piece of software.
The software is also constantly saying it needs to check my subscription online. It was my understanding this would be checked once a month. This is also a bother when I am trying to do my work.
Let's get real here Adobe!
Many of us have previous version of PS and or the Suite. We don't want/need to remove them as we try out the new CS6 Suite. We may need to have a simple Adobe Reader on the computer. We don't need/want all these conflicts with old and new programs. The nonsense of paying for a monthly subscription, only to be told at least once a day, that we are on a 'trial' or unregistered etc. is totally unacceptible.
I'll cancel my subscription and revert to my older (working well) copies of PS and ID if I keep getting error massages or am told to reinstall.
Will somebody at Adobe take responsibility for this fiasco? A public firing, and appology and a masive correction are all required at once.
As a software reviewer for a prominent Canadian magazine, I'm getting totally irritated by this mess. Fix it and fix it now.
HoodedFang
Priyank, as one human being to another, I’m sorry to say that your messages are extremely frustrating.
So far none of your “fixes” that you speak of so simply have worked.
I first installed Muse. Open Muse. Where is the “License this software” link?
Unless you can give exact instructions for where these links are in each of the software programs, please do not write such messages.
Thanks for your personal reply.
Here’s the problem as I see it:
Upon ordering the suite and downloading the various components, there is no indication that individual components need to be REGISTERED.
The message about ‘this is a 30 day trial’ is totally confusing. I already bought the product – and my credit card is already billed!
Trying to open an existing .PDF causes inconsistent results. One time my old Reader opened the file. Another time Acrobat. Then I got the 130:11 errors. I deleted Acrobat, installed Acrobat and everything worked – then back to the error message and a freeze.
I have registered my components. Sometimes they open (as they did this morning). Other times I have to open a couple of times.
NOTE: the time to open Photoshop or InDesign on my superfast desktop is s-l-o-w. My older versions open faster.
Suggestions: Add a set of INSTRUCTIONS to the download/installer page making it clear that the product needs to be REGISTERED again – even though the download needed the registration data;
Build in some sort of consistent memory module – Oh this person has already registered these components and does not need to reregister;
At error 130:11 detail what the message means and what to do with it – we don’t need to be doing long Google searches to resolve multi thousand dollar purchases.
I’ve been using Adobe products for production for a long time. This is by far the WORST Adobe experience (and the most costly).
Someone needs to fix the problem, apologize, and get the product working as it should – and VERY FAST
Peter Walpole
Since I installed Dreamweaver I now get the 130:11 related to Acrobat X every day, not just once a week as it was in the past.
I have to open Dreamweaver and get the license message so it can go online and validate my account.
Yes, this is a bother on a daily basis. But what if I don’t have internet access that day?
When is this going to be fixed?
Please install the updated version of the Adobe Application Manager from the link within this document
http://helpx.adobe.com/creative-suite/kb/trial--1-launch.html
It should resolve this issue.
I can honestly say I have now ‘beaten the system”. My installation of the CS6 suite is working OK.
Here’s how:
I had to register a number of the components with my email and password. I think three components required this. But I’ve had no error message since.
I have however had about three upgrades and Fixes. Today I applied the latest fix to InDesign (it activated as I loaded the program.
However:
Since moving to the Suite, Lightroom 4.1 no longer is an option to offload photos from my camera chip when placed in my card reader;
And
Photoshop is no longer to program that opens selected photos. Some Windows media module wants to do that. In fact I had to search down PS through a load of menus to make it an option again (Crazy)
Lightroom 4, as downloaded through the Suite’s Manager loaded in my C: partition, not my usual Programs/Adobe location.
I get the impression that nobody actually beta tested the whole suite before release. That’s why I’m a software reviewer, because I look for these snags
InDesign is wonderful, with loads of ways (too many?) of doing a task. Lighroom is indispensable (for my work). PremierPro is way too loaded for ‘learn on the job’ – I need a good manual.
Adobe needs to fix these snags and fast.
I am getting really fed up with this 130:11 licensing error with Acrobat X!
After reading this thread, I have installed the updated Adobe Application Manager as suggested above, I have registered the software yet again, but because I accidentally opened a CS5 application while removing CS5 apps from my taskbar, Acrobat X now just shuts down without warning.
I am sitting here with six CS6 apps open without any license warnings but do you think I can keep Acrobat open for more than a few seconds - NO.
Can someone please do something about this bug urgently?
I think we're having another bug, not the licensing error. I've been getting Acrobat X opening a document, doing the annoying accessibility scan, and then unceremoniously closing as I scroll through the document. No message, no crash, just closing.
Did you get tech support advice to install the trial version of Acrobat Pro X as a workaround for the 130:11 errors? I did, and I'm now wondering if this application behavior is related to that installation. I'll try uninstalling and Acrobat X Pro yet again, then try installing it from the updated Application Manager.
You might try the same. I'll post back with the results of my reinstallation.
Okay, just uninstalled and reinstalled Acrobat X Pro via the updated Application Manager. I wonder why Application Manager can't update itself. Nevermind, this release is all half-baked and buggy.
Acrobat X Pro now starts (with that damn accessiblity stuff that we Wacom users have to disable via api renaming) and it's not closing down so far. It's still annoying with "Reading Untagged Document" messages that I have to kill, but it's staying open.
Uninstalled and reinstalled Acrobat X and it's working OK at the moment.
When I contacted tech support a couple of months back about the 130:11 error, the weekend support staff didn't know anything about it! they suggested I try contacting them in the week ![]()
