I cannot get my export of DNxHD to export in 10-bit depth. The original file is DNxHD 10-bit, but when I export using the settings pictured in the attached pic and re-import and do any color grading...it's clear that it has shifted to 8 bit.
1) There are no non 32 bit effects on the footage.
2) the sequence is setup for max bit depth.
3) When i grade the clip before exporting and re-importing, it is clearly 10bit.
I record to DNxHD 10 bit and like to use DNxHD as my intermediate when sending to other programs or just want to flatten a complicated part of the timeline. My other options produce too huge of files (animation, dpx, etc) and I really would like to keep it in the family.
Any thoughts how I can get Premiere to export DNxHD to a 10-bit?
Jim, in layman's terms, when you add extreme contrast to gradients in an 8bit image, you see obvious banding and "stair-stepping" appear because there are reduced steps from black to white to start with. Adding contrast doesn't add the 'steps' back in...it just makes the existing (or lack of) step more apparant. 10 bit doesn't show such banding. I'm not at my studio right now otherwise I would show you the comparison. It's obvious.
Okay, here's a screenshot. You will notice the crazy banding on the left after grading is applied to this clip. This clip was an exported DNxHD 10-bit file to the aforementioned settings without grading, imported into premiere, and graded. I also graded the original before exporting and the banding is non-existant.
Here's a link to a 1920 file: http://www.adrive.com/public/6fw8nG/Bit1.jpg
Even at 8 bits, I've never seen banding that bad. I'm inclined to say something else is going on here.
It looks worse than the normal banding you're probably used to for the following reasons: 1) This was shot in Sony S-log, a very flat gamma. S-log gamma is very unforgiving in 8-bit especially with this amount of contrast applied in post. 2) There is a gaussian blur mask over this particular portion...making the banding even worse. When the blur is off...the banding is still there, it just look closer to what you're probably used to seeing.
On another note, things often work out better when you frame dimensions are evenly divisible by 8.
Interesting, I've never heard of this. Please explain. When I do the "scope" crop...I'll do 1920x816 instead if what you say is true.
Okay after some troubleshooting, I narrowed down the problem to the Gaussian Blur effect. This is indeed marked as a 32-bit effect, but it seems when exporting to DNxHD (I haven't tried any other codecs), it clamps to 8-bit. The clamping doesn't happen within Premiere though (when I add Gaussian Blur AND extreme contrast to the clip on the timeline), only when the video is exported.
Screenshot #1: Added Gaussian Blur, exported to DNxHD (again above settings), imported into Premiere, Added extreme contrast using fast color corrector.
Screenshot #2: No effects, exported to DNxHD, imported into Premiere, added Gaussian Blur, added extreme contrast using fast color corrector.
Richard,
I would have un-checked "Render at Maximum Depth" in the Export Settings dialog and try again. You have already specified 10-bit in the DNxHD Codec configuration so i see no need in then telling Pr to render out to 24-bit by using the "Render at Maximum Depth" option in the Export Settings dialog. Maybe that's the problem, telling the exporter to do 10-bit via the codec configuration and at the same time tell it to do 24-bit via the Export Settings. (I would have skipped the "Render at Maximum Depth" no matter what when going to DNxHD.)
If the problem persists, place the media in a 1920 x 1080 timeline and render out to 1920 x 1080. Maybe DNxHD cannot handle non-broadcast frame sizes.
If the problem still presists, try another codec to see if it is a codec related issue or not.
/Roger
Averdahl wrote:
Richard,
/Roger
Roger...looks like we posted at the same time. The issue was the Gaussian Blur effect.
Yes, but maybe the issue goes away if you do un-check the "Render at Maximum Depth" when you use the Gaussian Blur.
Just went and tried it. Unchecked this option and still was banded.
What version of Pr?
GPU Acceleration on or off?
Can you post a screen shot of the Timeline?
Version 6.0.1
MPE enabled
Screeshot:
Another theory...it's a CS6 bug. (Been using it for 2 weeks and there are ALOT of strange little bugs) I'm going to do the same test in 5.5 and see if the problem exists.
Okay I just tried the expirement in CS5.5 and it has the same problem. I also tried exporting to DPX to see if it occurs on that type of file and it did NOT have the problem. So far it's only limited to DNxHD. I'm going to try more variation in the Avid codec settings and see where that gets me. Perhaps encoding to the higher bitrates/framerates.
Averdahl wrote:
Can you post a screen shot of the Timeline when you have all filters on the clip, ie a screen shot from the Timeline you are exporting from. (I should have been more clear.)
/Roger
I don't understand. You mean a screenshot of the effects controls panel?
The screen shot you posted of the Timeline have one clip with *no* filters on it, and since filters are involved with the issue it would have been nice to see the actual Timeline you are exporting from, with the clips that has filters on them. (I have seen issues when the fault was in the timeline itself and not within the codec, hence the request.)
Since you now have found out that it is a codec issue there is no need to post a new screen shot. ![]()
/Roger
Okay another update. I pulled in some other shots...and it does appear to be the codec and NOT the Gaussian Blur effect. The fault in my testing was that I was applying the blur after importing the exported DNxHD file and hereby obliterating the banding. The new clip I'm testing is a shot of a wall with the lens out of focus, creating a nice, smooth gradient to test with.
Here's my updated test:
Screenshot #1: Exported to DNxHD, imported into Premiere, added extreme contrast using fast color corrector.
Screenshot #2: Original clip, added extreme contrast using fast color corrector.
I just noticed that I'm running the v2.3.4 version of the Avid codecs. There is apparantly a 2.3.7 version. Installing now...
Most deliverables these days use some form of MPEG compression - broadcast, DVD, Blu-ray, web, phones and tablets, etc. The MPEG 2 codec divides the frame up into 8 x 8 "blocks" of pixels for encoding, so things work out best when the entire frame fits an even number of blocks.
Do the math on every standard resolution. You'll find both dimensions are evenly divisible by 8. This is not by accident.
Oh okay, you're referring to deliverables, not intermediates. I don't think the critera is necessarily the same.
