I have Win7 64bit machine running InDesign 7.5.2 - I was prompted to update the DPS tools when I went to create/upload a new folio.
I downloaded Folio Builder Panel 12.1.3 and Folio Producer 1.9.1 extracted the files and installed
Now when I launch Folio Builder Panel I get the following
"Än error has occurred {Error #3115]"
I have uninstalled DPS Builder and Producer, uninstalled InDesign and made sure Indesign folders under user preferences were removed.
Restarted machine, clean install of Indesign and online updates, install tools then Builder - still get the error
What is the fix?
It should not be this hard to do a simple upgrade.
Hello Andrew. Please see if this soution works from James: http://forums.adobe.com/message/4265514. If it does not work please let me me know.
close InDesign and follow the steps below
Then re-launch InDesign
This fixed the problem for me
I'm getting the same error message. Just installed CS6 upgrade from 5.5. I'm running OS Lion on an iMac. Is there a fix for macs please anyone?
Many thanks for your time.
Rosie
Message was edited by: RosieMolly
Ah, I just found the fix quoted elsewhere. Thank-you Bob Bringhurst - this worked. Posting it again here in case needed by someone else.
7. toutoungi, 30-May-2012 09:42 in reply to erichawkinson
Hi, i just updated to CS 6 (on a mac OS X 10.7.4) and I am getting the same error message: [Error #3115column 'folioIntent' already exists] Uninstalled everything and reinstalled, but that did not help. Can anyone help me with a fix for this? Thanks
| Reply Bob Bringhurst, Adobe Employee 30-May-2012 09:44 in reply to toutoungi
Did you remove the temporary folders in the Local Store folder as described above?
| Reply toutoungi, Community Member 30-May-2012 09:58 in reply to Bob Bringhurst
thanks for the quick response... Any idea where I could find them on a Mac? Was searching for a while but with out sucess... thanks again
| Reply Bob Bringhurst, Adobe Employee 30-May-2012 10:01 in reply to toutoungi
[User] > Library > Preferences > StageManager.[###] > Local Store. If you're on Lion, your system files are likely hidden. Hold down Option and choose Go > Library.
| Reply toutoungi, Community Member 30-May-2012 10:16 in reply to Bob Bringhurst
thanks... hidden files and folders... Everything works now!
