PC is not using even 25% of CPU when rendering
May 29, 2012 10:52 AM
I have an i7-920, overclocked to 3.5GHz, 120GB SSD benchmarked at 225MB/s read, 200MB/s write, a RAID0 SATAII HDDs benchmarked at 190MB/s read and 150MB/s write.
When I am rendering video to an ISO, the CPU never goes above 25%, and the HDD array I am writing to blinks once every 5 seconds.
Does Premier Elements have some throttle limiter in it somewhere that's holding it back? If not, is there a tuning parameter I am missing? PE's cache is set to the SSD.
    May 29, 2012 12:05 PM   in reply to JeffRozz
    That MAY be a bad idea...
    SSD and Video Editing http://forums.adobe.com/thread/902915?tstart=0
    May 29, 2012 12:12 PM   in reply to JeffRozz
    Depends on which version of the program you're using and which version of the operating system you have.
    With the 64-bit version of version 10 and 64-bit Windows 7, you'll see much improved performance -- but it's still not likely to clock out your processors. And would you really want to?
    May 29, 2012 1:09 PM   in reply to JeffRozz
    This is a user to user forum, not Adobe support, so I doubt that anyone here will be able to provide insight into the technical "internals" of the program
    May 29, 2012 1:12 PM   in reply to John T Smith
    Also, have you properly set up your project with the correct project settings for your video? If you have, you should NOT see red lines above your clips when you add them to your timeline. Is that the case in your project?
    If so, you should not NEED to max out your system in order for the program to run like a top.
    Jun 3, 2012 3:38 AM   in reply to JeffRozz
    If you set the correct Project Setting when creating the new project then, when you add video clips to the timeline, there should be no lines (red or green) running above the length of the clip.
    As you work with the clip then red lines will appear above the clips to which you have applied effects and transitions. If preview playback is smooth enough you can ignore them. If you need a smoother playback within PRE press the [Enter] key and PRE will make a new render of that section - the red lines will go green.
    So if you add a new clip and the red line immediately appears it means that your project setting is wrong.
    Notes:
    • when you add still images they will always show with a red line until you press enter
    • PRE always renders afresh the project when you share it. So it is not necessary to render when working with the project, it merely improves the preview.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
