I know this topic seems to be common, but a lot of the things I have seen in other posts really has not helped me at all.
So, I think it's my turn to ask.
I am on Flash 11.2.202.235.
My OS is Mac OS X Lion.
No matter what browser I use, or at least the three that are on this computer, they all don't work and there's no crash report that could help me at all. It crashes every so often after maybe, 2 or 3 youtube videos or 5 or 10 minutes of seeing anything that would require flash.
First, when Flash Player crashes on Google Chrome 19, the whole webpage turns white, and I have to reload the page countless amounts of times until it works again.
When I try in Firefox, an error pops up that says "The Adobe Flash Plugin has crashed. No report available. Reload the page to try again." With a very depressed looking lego block.
When it crashes in Safari, the area of what is supposed to be the thing using flash becomes white and nothing happens.
I've tried reinstalling, clearing cache, deleting the browsers and reinstalling, and all of that, but, it continues to crash and I hope someone could help me!
Hi Dean,
I'm sorry you're going through this. This type of behavior is definitely not normal or common, so hopefully we can figure out what's going on. I suspect you have some software or hardware on your system that is conflicting with Flash and causing these crashes to occur.
To start, can you send me (ccampbel@adobe.com) a copy of your system profile report? Next, open up Chrome and type "about:flash" in the address bar and post the contents of the page that is displayed.
Chris
Hello! Thanks for replying! I just emailed you and
here's the about:flash page from chrome:
| Google Chrome | 19.0.1084.54 () |
| OS | Mac OS X |
| Flash plugin | 11.2.202.235 /Applications/Google Chrome.app/Contents/Versions/19.0.1084.54/Google Chrome Framework.framework/Internet Plug-Ins/Flash Player Plugin for Chrome.plugin |
| Flash plugin | 11.2.202.235 /Users/DeanxLeong/Library/Application Support/Google/Chrome/NPAPIFlash/Flash Player Plugin for Chrome.plugin (not used) |
| Flash plugin | 11.2.202.235 /Library/Internet Plug-Ins/Flash Player.plugin (not used) |
| --- Crash data --- | |
| Crash Reporting | Enable crash reporting to see crash IDs |
| For more details | https://support.google.com/chrome/?p=ui_usagestat |
| --- GPU information --- | |
| --- GPU driver, more information --- | |
| Vendor Id | 0x10de |
| Device Id | 0x08a3 |
| Driver vendor | |
| Driver version | 7.2.9 |
| Driver date | |
| Pixel shader version | 1.20 |
| Vertex shader version | 1.20 |
| GL version | 2.1 |
| GL_VENDOR | NVIDIA Corporation |
| GL_RENDERER | NVIDIA GeForce 320M OpenGL Engine |
| GL_VERSION | 2.1 NVIDIA-7.2.9 |
| GL_EXTENSIONS | GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod |
Sorry for cutting in. I have exactly the same problem too and all things have been done, but no luck. I am using a Mac Pro with OS X 10.7.4, and here comes my about:flash results:
| OS | Mac OS X |
| Flash plugin | 11.2.202.235 /Volumes/Jumpin Flash/Users/fred/Library/Application Support/Google/Chrome/NPAPIFlash/Flash Player Plugin for Chrome.plugin (not used) |
| Device Id | 0x019d |
| Driver vendor | |
| Driver version | 7.18.18 |
| Driver date | |
| GL version | 2.1 |
| GL_RENDERER | NVIDIA Quadro FX 5600 OpenGL Engine |
| GL_VERSION | 2.1 NVIDIA-7.18.18 |
| GL_EXTENSIONS | GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite |
Fred
Hi Dean and Fred,
Thanks for posting the logs. Could you both enable crash reporting in Chrome, wait for another crash or two, then post the logs again? I was hoping to get crash id's that Chrome stores but it won't start to track these until reporting is enabled.
Chris
Below is my log after checking "Automatically send usage statistics and crash reports to Google".
Fred
| Google Chrome | 19.0.1084.56 () |
| OS | Mac OS X |
| Flash plugin | 11.3.300.257 /Applications/Google Chrome.app/Contents/Versions/19.0.1084.56/Google Chrome Framework.framework/Internet Plug-Ins/Flash Player Plugin for Chrome.plugin |
| Flash plugin | 11.3.300.257 /Library/Internet Plug-Ins/Flash Player.plugin (not used) |
| Driver vendor | |
| Driver date | |
| GL version | 2.1 |
| GL_EXTENSIONS | GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod |
hmm, unfortunately we're not getting any crash id's in your log. Could you open a new bug report at bugbase.adobe.com and include the steps you take and a link to this forum post? Getting the bug in will make sure we don't loose track of this issue.
I'm using now ver 11.2.202 and no problems at all, at last they should show us an easy link to older version and uninstaller, is not easy to find older releases.
PD, i did not put any log, because it fail in all browsers(chrome, firefox and safari on w7 64), then is not caused from any other plugin or extension, just flash player bug.
i have the identical problem in both Firefox 12.0 and Safari 5.1.7, running OSX 10.6.8. face it: this update is badly b0rked. Rushing to stave off HTML5 in the marketplace* inevitably increases the likelihood of bugs by compressing QA and Beta times.11.3.300.257 Flash ought to be acknowledged as a failure by Adobe, and a big <blink>LINK</BLINK> to the previous, actually functioning release be place on the acknowledgement page. in the alternative, we can keep supplying Adobe engineers with helpful crash reports, further supporting Adobe, Inc. NOTE: no such problems have been reported for other platforms exploited ^W supported by Flash. Mais c'est incroyable!
*which honestly shouldn't be a marketplace at all. the rendering part of the web works because it can't be held hostage by any one business entity... HTMLN is never compiled... it's text...but i digress...
adam
I had what I believe may be the same problem. I have managed to fix it on my machine. Hopefully this will help others fix their problems too, because Flash is everywhere so when it's borked, the internet is borked.
I recently upgraded to Mac OS X 10.7.4, and shortly (but not immediately) thereafter upgraded Adobe Flash Player to 11.3.300.257. Flash content broke in all browsers. Firefox displayed an error message: "The Adobe Flash plugin has crashed. No report available." Safari displayed an similar error message. Chrome would play audio but no video.
I tried uninstalling 11.3.300.257 and installing 11.2.202.233, which did not fix the problem. I tried uninstalling that and installing 10.3.183.18, which did not fix the problem either.
Finally, digging through the console logs, I found a stack trace of one of the crashes. It appeared to be dying in the nVidia graphics driver. I upgraded my nVidia driver and the problem is now fixed. (In my case, I have an nVidia Quadro FX 5600 in a Mac Pro and nVidia's 270.00.00f06 driver did the trick.)
Good luck, everyone.
Flash on my 2008 Mac Pro (OS X 10.7.4) is now back to business, thanks a million for the tips!
All of you can download the new nVidia driver here:
http://www.nvidia.com/object/macosx-270.00.00f06-driver.html
Thanks again!
Fred
kebin0017,
The original post for this thread was made before Flash Player 11.3 was released. As we have noted, there are severe issues with the latest release of Flash Player (11.3). Please see this post for updates:
Are you having problems with Flash 11.3?
If you have a reliable and consistent way of reproducing a crash, we're very interested in hearing about it. Please create a bug at bugbase.adobe.com and post back with the bug number or URL. I'll investigate immediately.
Chris
