Hello- question from an illustrator to flash workflow n00b.
I'm creating a flash experience with animated characters.
I'm building my art assets in illustrator.
I've found it relatively easy & straightforward to import assets from illustrator into flash.
I can conveniently import my layers and symbols from illustrator as separate layers and symbols in flash and manipulate them.
However, let's say after import I want to change something with an asset using illustrator. For example, I have a character with facial features, including eyes. I want to change the eyes in illustrator and have those changes then be propogated in some way- automagically or manually- in flash.
What is the right way to do this? Are there best practices for being able to go back and forth between flash and illustrator?
Thank you!
~ sae
You can copy paste modified parts of your artwork from Illustrator to Flash. Here's more information:
http://helpx.adobe.com/flash/using/illustrator-ai-files-flash.html
Suhas Yogin
Thanks for the reply Suhas.
I guess the answer to my question is that there is no good way. In the photoshop/illustrator workflow, I can paste a document from illustrator into photoshop and then double-click it in photoshop to open it back up in illustrator and edit the original. I have seen posts on people doing this between Flash and Illustrator with the now-discontinued Flash Catalyst- a process that was apparently called round-tripping. Ideally, this is the functionality I'd like to have between Flash and Illustrator but I take it from your reply that the answer is 'Does not exist.'
~ sae
