Chaz, W
Issue With Setting registerRepository
Jun 3, 2012 9:05 AM
Hi All,
Can someone help me with the following issue:
strObjectOfRemoteCall: (mx.rpc.remoting::RemoteObject)#0
  callGetAccountManager = (mx.rpc.remoting::Operation)#1
    argumentNames = (Array)#2
    arguments = (Object)#3
    concurrency = "multiple"
    lastResult = (null)
    makeObjectsBindable = true
    name = "callGetAccountManager"
    operationManager = (null)
    properties = (null)
    resultElementType = (null)
    resultType = (null)
    service = (mx.rpc.remoting::RemoteObject)#0
    showBusyCursor = false
  channelSet = (mx.messaging::ChannelSet)#4
    authenticated = false
    channelIds = (Array)#5
      [0] (null)
    channels = (Array)#6
      [0] (mx.messaging.channels::AMFChannel)#7
        channelSets = (Array)#8
          [0] (mx.messaging::ChannelSet)#4
        connected = true
        connectTimeout = -1
        enableSmallMessages = true
        endpoint = "http://dgbnhm90lt01/flex2gateway/"
        failoverURIs = (Array)#9
        id = (null)
        mpiEnabled = false
        netConnection = (flash.net::NetConnection)#10
          client = (mx.messaging.channels::AMFChannel)#7
          connected = false
          httpIdleTimeout = 0
          maxPeerConnections = 8
          objectEncoding = 3
          proxyType = "none"
          uri = "http://dgbnhm90lt01/flex2gateway/"
        piggybackingEnabled = false
        polling = false
        pollingEnabled = true
        pollingInterval = 3000
        protocol = "http"
        reconnecting = false
        recordMessageSizes = false
        recordMessageTimes = false
        requestTimeout = -1
        url = "http://dgbnhm90lt01/flex2gateway/"
        useSmallMessages = false
    clustered = false
    connected = true
    currentChannel = (mx.messaging.channels::AMFChannel)#7
    heartbeatInterval = 0
    initialDestinationId = (null)
    messageAgents = (Array)#11
      [0] (mx.rpc::AsyncRequest)#12
        autoConnect = true
        clientId = "FBE7089A-D30E-9864-4598-132ED088655E"
        connected = true
        defaultHeaders = (null)
        destination = "ColdFusion"
        id = "3D5287FE-8595-54AB-0B1E-B2F48A501A63"
        priority = -1
        reconnectAttempts = 0
        reconnectInterval = 0
        requestTimeout = -1
        subtopic = ""
  convertParametersHandler = (null)
  convertResultHandler = (null)
  managers = (null)
  operations = (Object)#13
  requestTimeout = -1
  source = "CFSite.Muzo._component._remoteaccess.roMuzoLCCS" strObjectOfError: (mx.rpc::Fault)#0
  content = (null)
  errorID = 0
  faultCode = "Server.Processing"
  faultDetail = "Either there are no methods with the specified method name and argument types, or the registerRepository method is overloaded with argument types that ColdFusion cannot decipher reliably. ColdFusion found 0 methods that matched the provided arguments. If this is a Java object and you verified that the method exists, you may need to use the javacast function to reduce ambiguity."
  faultString = "Unable to invoke CFC - The registerRepository method was not found."
  message = "faultCode:Server.Processing faultString:'Unable to invoke CFC - The registerRepository method was not found.' faultDetail:'Either there are no methods with the specified method name and argument types, or the registerRepository method is overloaded with argument types that ColdFusion cannot decipher reliably. ColdFusion found 0 methods that matched the provided arguments. If this is a Java object and you verified that the method exists, you may need to use the javacast function to reduce ambiguity.'"
  name = "Error"
  rootCause = (null)
have anyone had this problem.
I am trying to set the register repository in the com.adobe.rtc.account.AccountManager
Charles
