AmmarSM
auto indenting in dreamweaver cs6
Jun 2, 2012 5:11 AM
Tags: #dreamweaver
why the code dont auto indent in dreamweaver i use the latest cs6, as an example the table code below it
should indent the tr tag some spaces more than the parent table tag but it dont i need to do it manually so am i missing something ?
<table>
<tr>
<td>15</td>
<td>15</td>
<td>30</td>
</tr>
<tr>
<td>45</td>
<td>60</td>
<td>45</td>
</tr>
<tr>
<td>60</td>
<td>90</td>
<td>90</td>
</tr>
</table>
    Jun 2, 2012 5:25 AM   in reply to AmmarSM
    Edit > Preferences > Code Format
    Make sure the Indent box is checked.
    Jun 3, 2012 11:59 PM   in reply to AmmarSM
    Sorry, don't know any other settings.
    For me, if I check that option, I get indented code.
    If I don't check it, the code is left aligned.
    Jun 4, 2012 12:19 PM   in reply to AmmarSM
    Edit > Preferences > Code Format > hit Tag Library button for advanced features. See screenshot:
    Code formatting changes won't effect your exisiting code.  Only works on new code.
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    Jun 29, 2012 6:36 PM   in reply to Nancy O.
    With CS5 is the same, non of these settings have worked, but go to:
    C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS5\configuration\Commands\TableCommands.js
    and 39-41 lines add some spaces bofere <
    var tableCells='  <'+'TD>' + theNBSP + '<'+'/TD>\n';
    var tableScopeRowCells='  <'+'TH>' + theNBSP + '<'+'/TH>\n';
    var tableScopeColCells='  <'+'TH>' + theNBSP + '<'+'/TH>\n';
    this have worked, but if you try to insert new row <td> is not indented:
    <table cellspacing="0" cellpadding="0">
    <tr>
      <th> </th>
      <th> </th>
    </tr>
    <tr>
      <td> </td>
      <td> </td>
    </tr>
    <tr>
    <td>new row</td>
    <td>not indented</td>
    </tr>
    </table>
    and didnt have found how to fix insert new row (below or above same is not indented).
    Jan 8, 2013 4:34 PM   in reply to Tomas...
    Just go into Preferences, Code Formating, and then the Tag Libraries. Find the TAG and change the line break setting to add line breaks for the before, inside, or after conditions.
    After making the change, in Code View click: Format Source Code.
