leighjor
dreamweaver unable to start correctly error 0xc0000022
Jun 2, 2012 5:09 AM
Just bought and downloaded CS6  design and web premium . Seems done until I go to open Dreamweaver and I get the error stating dreamweaver unable to start correctly (0xc0000022). Photoshop , Flash and others open OK. Im runnning i7 2600CPU 8gb ddr3 64bit WIn7 ssd with 40gb free. I have tried  both suggested methods of downloading files with same result. All help much appreciated.
    Jun 2, 2012 2:02 PM   in reply to leighjor
    Did you receive any specific error messages when installing your suite?  Or was Dreamweaver previously functioning and it is now failing too?
    Jun 3, 2012 11:52 AM   in reply to leighjor
    But do you receive an error while installing the program?  It seems like you are continuing to download the install files and then running the install again.  After the installation is complete you then launch Dreamweaver which is failing.  Did Dreamweaver ever work on your computer?
    You can also utilize the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ to review your istallation logs.
    Jun 4, 2012 9:57 AM   in reply to leighjor
    Have you run the Adobe Support Advisor referenced in message #3?  Did it report any possible resolutions?
    Apr 6, 2013 9:32 AM   in reply to leighjor
    This kind of problem can be solved by changing the premissions and ownerships of the following files: msvcr110.dll msvcp100.dll msvcp110.dll msvcr100_clr0400.dll msvcr110.dll.
    Owner with full premission has to be current logged in user with full rights to access the dll. Or you can do the same by putting administrator as the full owner but you have to run the application (dreamweaver, photoshop etc) with Administrator privileges.
