Kalle4001
CurrentRow MOD And Br
Jun 1, 2012 3:16 AM
hello I'm trying to get a loop. The idea is to just
create a table that shows 2 row and 5 column.
Instead of
1
2
3
4
a.s.o
I want
12345
space writable
678910
I've made a CurrentRow MOD and it working right to left, but
not the space
even if it is possible to loop the table instead of the columns
<table width="500" border="1">
<tr><cfoutput query="testrec" startRow="#StartRow_testrec#" maxRows="#MaxRows_testrec#">
<td>#testrec.tblOnskelista# </td>
<CFIF testrec.CurrentRow MOD 5 IS 0>
</TR>
<TR></TR>
</CFIF>
</cfoutput>
</table>
    Jun 1, 2012 4:36 AM   in reply to Kalle4001
    I think you'll find an empty <tr> doesn't - intrinsically - have any height.
    Adam
    Jun 1, 2012 8:57 AM   in reply to Kalle4001
    In the spot where you want your space, add a set of td tags containing a non breaking space.
    Jun 1, 2012 9:49 AM   in reply to Kalle4001
    I saw this exact same question on another forum: http://www.codingforums.com/showthread.php?t=263220
    ^_^
    Jun 1, 2012 10:10 AM   in reply to Kalle4001
    I tend to avoid the MOD calculation in a loop like this and instead use two loops:
    <table>
      <cfloop index="variables.i" from="#StartRow_testrec#" to="#EndRow_testrec#" step="5">
       <tr>
        <cfloop index="variables.y" from="#variables.i#" to="#variables.i+5#">
         <td><cfif variables.y LTE testrec.rowCount>#testrec.tblOnskelista[variables.y]#<cfelse> </cfif> </td>
        </cfloop>
       </tr>
      </cfloop>
    </table>
    Jun 4, 2012 1:46 AM   in reply to Kalle4001
    Couldn't you just do something as simple as this
    <tr>
    <cfoutput query="testrec" startRow="1" maxRows="5">
    </cfoutput>
    </tr>
    </table>
    <br>
    <tr>
    <cfoutput query="testrec" startRow="6" maxRows="5">
    </cfoutput>
    </tr>
    </table>
    Jun 4, 2012 5:29 AM   in reply to Kalle4001
    Kalle4001 wrote:
    i get wront when i start next 10 record
    <a href="<cfoutput>#CurrentPage#?PageNum_testrec=#Min(IncrementValue(Pag eNum_testrec),TotalPages_testrec)##QueryString_testrec#</cfoutput>">N e xt</a>
    now you say only the first 10
    This is apparently a new question. Have you resolved the first one?
    Jun 4, 2012 11:48 PM   in reply to Kalle4001
    You can just add if-conditions to control output according to the number of records. Here are examples:
    (1)
    <cfif testrec.recordcount GTE 1>
    <tr>
    </cfoutput>
    </tr>
    </table>
    </cfif>
    <br>
    <cfif testrec.recordcount GTE 6>
    <tr>
    </cfoutput>
    </tr>
    </table>
    </cfif>
    (2)
    <cfif testrec.recordcount GTE 11>
    <cfoutput query="testrec" startRow="11" maxRows="8">
    <cfset link = CurrentPage & "?PageNum_testrec=" & Min(IncrementValue(PageNum_testrec),TotalPages_testrec) & QueryString_testrec>
    <a href="#link#">Next</a><br>
    </cfoutput>
    </cfif>
    Jun 5, 2012 12:49 AM   in reply to Kalle4001
    I am assuming that your query is called testrec.
    Jun 5, 2012 3:50 AM   in reply to Kalle4001
    Then testrec.recordcount should exist! Make sure you put the above code in a position where the query is defined. For example, right after the cfquery tag.
