I recently upgraded to FB 4 and installed SDK 4.6.
I can't get any code hints for XML typed objects while using SDK 4.6, while SDK 4.1 gives me correct hints for the same source code in the same project and workspace.
This is the (flawed) SDK 4.6 result of code hinting an XML type object
This is the (correct) result of code hinting using SDK 4.1
CH also seems to work fine for other classes in SDK 4.6 (I haven't tried them all of course).
Is this a known problem, have any of you guys encountered it too?
Is there a workaround / fix?
Ferrie
Tagging onto this as I'd love to know the answer too!
Hi Ferrie,
Thanks for reporting this issue. A bug has been logged for this.. https://bugs.adobe.com/jira/browse/FB-33326
This will be fixed in future releases of FB.
-Radhakrishna
