I understand that under the "system requirements" the Adobe website says that you can't install PS CS6 (Extended) on case-sensitive drives (I'm using a MacBook Pro, OS X v. 10.7.4). This seems to have been the case at least since CS5.
I didn't see this, and I bought (quite excitedly) the update from CS PS5 (Extended) to PS6. I had NO PROBLEM installing PS5 on this drive.
Of course, as other users have indicated, the installer refuses to let you install on a case-sensitive drive (e.g., no options to install on another disk). There is also no mention that CS6 must be installed on the boot drive.
Requiring installation on the boot drive has serious implications for those of us who require case-sensitive drives for other work; I don't want to have to reboot from another drive when I use PS, and switch back and forth -- that's simply foolish.
From my point of view (as a user, granted), this is lazy programming, and this needs to be fixed ASAP. At least in my case, I have a $400 lump of software just taking up space, when I want to be up to my eyeballs enjoying PS6 in all it's glory.
Outside an Adobe fix, I don't see a solution to this problem. If I wipe my drive, format it as not case-sensitive, then I lose functionality for other critical work. Further, I'm not sure that the process of wiping the drive, formating it as non case-sensitive, and restoring everything from TimeMachine would even work (since the backup material is coming from a case-senstive drive and trying to go to a drive that is not case-sensitive).
The REALLY frustrating part is that I've installed Photoshop 3, 4, and 5 (and from much, much further back) on case-sensitive disks -- all with no problems. It's only now that the issue smacks me in the face.
There's got to be a work-around, if not a "real" solution.
Whatever help you might be able to offer would be greatly appreciated; details can be sent to cdretk at gmail dot com.
I have hope, and I thank you in advance.
Yes, I saw it discussed previously, but none of the discussions involved a case in which the user has sucessfully installed CS PS5 Extended on the case-sensitive drive in question.
Thanks for your suggestion, but I did do my "homework" before posting. I was hoping for an Adobe response that would be helpful.
I understand that you're still working on it - that's great. It does not explain why installation worked on this drive for CS5 and not for CS6. It turns out that this boot drive is NOT case-sensitive; it is "Journaled HFS+" directly from the System Information panel (Serial ATA tab) from "About this Mac."
This means that while the idea of installing on a case-sensitive drive may have been "discussed to death," this presents a different problem that is unresolved.
Based on the error message that was thrown (I have no logs or anything else), I'm not sure I could have stated it more clearly. Trying to install again, the specific error reads as follows:
[Red triangle with an exclamation point inside] We've encountered the following issues
Installation on case-sensitive volumes is not supported. Please chose a different volume for installation.
The only choice is "Quit" (that's the only button showing).
Well, I guess then it's up to Chris or someone from Adobe to ask you for the specific log files that elucidate what's happened, since you don't think the drive is case-sensitive.
Is there anything you've done that's special to the drive(s) on your MacBook? Is any other drive case-sensitive?
-Noel
Now I've solved this (no thanks to Adobe, in whom I'm very disappointed).
In the past, when you wanted to install something on your Mac, you'd simply copy a folder to your Applications directory.
As Photoshop (among other programs) has gotten more complicated, it's decided that it needs to install things in the various system directories and potentially in your user directory.
Herein lies the issue (and the solution, in this case). My user directory is on the drive that is case-sensitive. I don't know what Adobe needs to install there (since Photoshop is, after installation, available to all users), but that was the key.
SOLUTION: Log in as another (administrator-enabled) user and install. Bang - it works with no problems.
Yes, I still had to copy all of my plug-ins, etc. from PS5 by hand (and sort out the ones PS6 doesn't like - again by hand), but at least it's working.
Good software engineering practices dictate that installed software should PREFER case-sensitive drives, and not case-insensitive drives (think about the data).
Good installation support (on the telephone) should at least suggest trying a different user account...
Adobe: You owe me for my time on this one. Where shall I send my bill?
I don't even get a "Helpful" for suggesting it might be an issue with another drive?
LOL, don't worry about it, I'm just being a bit mischievous because it's the end of a long day.
Glad to hear you got to the bottom of that. I suppose since Apple is case-insensitive by default (not to mention Windows being case-insensitive), having a case-sensitive drive does mean you're kind of out of the mainstream.
-Noel
...but not really out of the mainstream, right?
Software developers need case sensitivity (especially those who work in groups -- have you ever used "Subversion?").
Unix users need case sensitivity -- both developers and users (like me).
Web developers need case sensitivity (based on the servers they use).
There have been very long discussions about why case-sensitivity is "good" and "needed" (quick Google search will show you that), and, quite frankly, it's simply good software development practice.
I use Subversion in my business, where we develop on Windows machines. I do have one engineer with an Apple, but he develops in a VMware virtual machine using Windows 7. I'll have to ask him whether he ever retrieves files to his Mac outside the VM.
In any case
, I don't find case insensitivity an issue. I don't know how that would map to Apple systems, but as long as you don't try to put two files in the same folder with the same name (using different case) I don't see it as a problem.
I'm not arguing with you - if you need case sensitivity that's fine, but perhaps you might want to separate your server needs from your workstation, because like it or not, in today's world you're in the minority with case sensitivity enabled.
-Noel
I realize this is a stale discussion but...
cdre-tk wrote:
...In the past, when you wanted to install something on your Mac, you'd simply copy a folder to your Applications directory.
As Photoshop (among other programs) has gotten more complicated, it's decided that it needs to install things in the various system directories...
How old is your perception of "in the past"?. Program installers from the early 1990s would drop stuff all over the system, especially in the Extensions folder.
cdre-tk wrote:
...I don't know what Adobe needs to install there (since Photoshop is, after installation, available to all users), but that was the key...
Photoshop may be available to all users but each user has their own preferences that need to be written to their own user space. The fact that you don't know about this may give good cause for you to learn about your system prior to telling developers what they should do.
Where should we send the bill for educating you about your system? ![]()
From what I've read from this discussion, your issue involved a case sensitive drive being used for your main user account, even though your system drive was case-insensitive. If you created a fresh account for Photoshop, that account would have appeared on that case-insensitive system drive. So all that you have accomplished is a basic installation on a case-insensitive drive, as recommended by Adobe. Your "SOLUTION" was doing what Adobe requires and it is what every other Photoshop user does.
I find it stunning that case sensitive drives are not supported. They certainly were with CS5. Is Apple backing away from the case sensitive, journaled partition - maybe backwards to something like DOS. Hey - here's an idea how about 8.3 file names being required for CS7.
I also loved the blame on the Apple tools. I have a hard time believe XCode requires case insensitive drives. Sounds more like developer error to me. Adobe - how about you folks just cowboy up and fix this debacle?
Guess I'm staying on CS5. What a pathetic effort.
Erik
We are trying to use the correct cases, but there are situations where the dev tools get things more than a little confused.
We've been working with Apple on this for a long time. We find a few problems, Apple eventually fixes those, then a few new problems appear in the dev tools which we have to find and document, then wait for the tools to be fixed, etc.
Sorry I was having a bad day yesterday. Karma sucks - I got to work today and someone went off on me the same way about computer software my group builds. I thought of this thread and how I deserved it.
It's not an issue of using cases or not in the installation path. The part that sucks is I have to repartition my HDD to use CS6. That's going to take a number of hours to backup, partition, and restore the data. The installer won't run until I do this work. Yuck.
E
