Alex DeJesus 430 posts
Jul 25, 2008
Is File Conversion Necessary?
Jun 3, 2012 5:14 PM
Tags: #adobe #export #h264 #ae #premier
I was told recently that I should convert my video files to something else to improve rendering and exporting times. I shoot HDV, and recently started usung a DN60 for a tapeless workflow. I have CS6 and a reasonably fast computer.
I was under the impression that Premiere and AME handled HDV and all the other filetypes natively. Why then am I experiencing slow performance after all I have done to improve my system? What should I convert to? And wouldn't that be a time-consuming process in itself?
I continue to have problem after problem. As a future feature request, I would like to see a built-in troubleshooter for CS6 that would tell me where bottlenecks and other problems are in the system. I LOVE Adobe apps when everything is working, but unfortunately that is very seldom in my case.
My workflow consists of shooting HDV, ingesting M2t from DN60 or capturing from tape. Editing in Premiere, maybe some After Effects work for titles, etc, and on to Encore for DVD or AME for YouTube.
In this latest problem I'm having, AME is stuck for the past 30 minutes reading XMP trying to encode .h264 for YouTube.
    Jun 3, 2012 6:10 PM   in reply to Alex DeJesus
    You 1st thing you need to do is insure your sequence matches your video... which you will know when you put a video on the sequence timeline and there is NO red line over the timeline
    Please NOTE that the PPro CS6 screen may look a bit different
    For CS5 and later, the easy way to insure that your video and your project match
    See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
    Jun 3, 2012 6:51 PM   in reply to Alex DeJesus
    Long-GOP codecs are more CPU intensive, so yes, you will experience slowness you wouldn't with intraframe codecs, due to the CPU ops needed to render each frame to your display in real-time.
    Yes, it will take time to transcode, and it will eat up drive space, but you may make up the lost time in the editorial process.  My general rule is the shorter the project and less the footage, the more incentive to edit native.  Otherwise, transcode.
    My impression (not scientific) is that working on Long-GOP codecs is only going to be more painless on the fastest of multi-core systems.  "Reasonably fast computer" may not be good enough.  Try transcoding to AVI, Cineform, DNxHD or ProRes, and see for yourself what works best for you.
    Jun 3, 2012 6:59 PM   in reply to Alex DeJesus
    http://www.youtube.com/watch?v=BJLIwxaaiyA
    You should watch this video because you should be able to edit multiple layers of native AVCHD and native HDV using a medicore Core i7 system or at least I can.
    Jun 3, 2012 9:38 PM   in reply to Alex DeJesus
    That's not normal.  It's certainly not expected behavior simply because you're editing native.  You machine is plenty fast enough to be dealing with this footage as is.  Solve the real problem, instead of avoiding it by transcoding.
    Jun 4, 2012 10:06 AM   in reply to Alex DeJesus
    Your system should play native AVCHD and HDV files just fine. Make sure yuour power options are set to maximum performance.
    Jun 4, 2012 2:02 PM   in reply to Alex DeJesus
    Uncheck Write XMP ID to files on import and Enable clip and XMP metadata linking in preferences. See if that will help.
