Just bought and downloaded CS6 design and web premium . Seems done until I go to open Dreamweaver and I get the error stating dreamweaver unable to start correctly (0xc0000022). Photoshop , Flash and others open OK. Im runnning i7 2600CPU 8gb ddr3 64bit WIn7 ssd with 40gb free. I have tried both suggested methods of downloading files with same result. All help much appreciated.
This kind of problem can be solved by changing the premissions and ownerships of the following files: msvcr110.dll msvcp100.dll msvcp110.dll msvcr100_clr0400.dll msvcr110.dll.
Owner with full premission has to be current logged in user with full rights to access the dll. Or you can do the same by putting administrator as the full owner but you have to run the application (dreamweaver, photoshop etc) with Administrator privileges.
Did you receive any specific error messages when installing your suite? Or was Dreamweaver previously functioning and it is now failing too?
Hi Jeff,thanks for your reply.
I first installed by downloading Akamai NetSession installer, once done all other applications except Dreamweaver worked. I then got rid of that installation and downloaded using the alternative method i.e. direct download of an .exe and a the zip file. Again installed and Dreamweaver would not open. Other apps open but when I attempt to open Dreamweaver get message "The application was unable to start correctly (0xc0000022). Click OK to close the application.".
I am attempting to install design and web premium.cs6
But do you receive an error while installing the program? It seems like you are continuing to download the install files and then running the install again. After the installation is complete you then launch Dreamweaver which is failing. Did Dreamweaver ever work on your computer?
You can also utilize the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ to review your istallation logs.
Dreamweaver CS6 has never worked. As soon as installation complete I try to open dreamweaver and no success, the other apps open OK. I previously was using dw cs4 without problems. I deactivated and deleted this before downloading CS6 and used the adobe cleaner to get rid of remnants.
Have got to installation stage once again but now it seems to be stuck (last 8 hrs ) on 33%.
Have you run the Adobe Support Advisor referenced in message #3? Did it report any possible resolutions?
Have spent 4hrs with ADobe support , giving them access to my PC -- and the issue is still not resolve. My sytem is clean, all av and firewall etc has been diasbale, even started in the proper/true Admin profile and tried. Just makes me think there must be some packaging issue with download as only 32 bit apps dont work.
Thanks! This actually worked!
thanks for your comment.
