I have xml data from three different datasets that I want to use in a master detail region.
So initially, a list of model codes is displayed. When the user clicks on a specific model, the model inputs appear in the detail region. One of these inputs is a list of map units. I also want a real name description of the map unit to be displayed. It's working for one map code, but not for all of them.
My question is: "How do I get the description to disply for each of the map codes?"
Here is my code:
_______________________________________________________
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
<script src="/SpryAssets/xpath.js" type="text/javascript"></script>
<script src="/SpryAssets/SpryData.js" type="text/javascript"></script>
<link href="/SpryAssets/SprySpotlightColumn.css" rel="stylesheet" type="text/css" />
<script type="text/javascript">
var DSpresence = new Spry.Data.XMLDataSet("/SpeciesReview/Copy of tblSppMapUnitPres.xml", "dataroot/Copy_x0020_of_x0020_tblSppMapUnitPres");
var DSancillary = new Spry.Data.XMLDataSet("/SpeciesReview/ModelingAncillarywname.xml", "dataroot/Sheet1", {sortOnLoad: "CommonName", sortOrderOnLoad: "ascending"});
var DSpresence2 = new Spry.Data.XMLDataSet("/SpeciesReview/Copy of tblSppMapUnitPres.xml", "dataroot/Copy_x0020_of_x0020_tblSppMapUnitPres[strSpeciesModelCode=' DSancillary::strSpeciesModelCode']");
var dsMUDescription = new Spry.Data.XMLDataSet("/SpeciesReview/tblMapUnitDesc.xml", "dataroot/tblMapUnitDesc");
var dsMUDescription2= new Spry.Data.XMLDataSet("/SpeciesReview/tblMapUnitDesc.xml", "dataroot/tblMapUnitDesc[intLSGapMapCode='{DSpresence2::intLSGapMapCo de}']");
</script>
</head>
<body>
<div style="width: 100%">
<div id="Species_DIV" spry:region="DSancillary DSpresence dsMUDescription" width="50%" style="float:left">
<table id="DSancillary">
<tr>
<th>Species Code</th>
</tr>
<tr spry:repeat="DSancillary" "DSpresence" "dsMUDescription" spry:setrow="DSancillary" >
<td>{strSpeciesModelCode}</td>
</tr>
</table>
</div>
<div id="Species_Detail_DIV" spry:detailregion="DSancillary DSpresence dsMUDescription" style="float:right; margin-top:20px; width: 40%">
<table id="Species_Detail_Table" >
<tr width="100%">
<th style="font-family:Verdana, Geneva, sans-serif; font-size:14px; background-color:#CCCCCC; font-weight:bold">Modeling variables used for {strSpeciesModelCode}</th>
</tr>
<tr>
<td spry:if="'{memModelNotes}' != ''">Hand Model Notes: {DSancillary::memModelNotes}</td></tr>
<tr>
<td spry:if="'{DSancillary::ysnHydroFW}' == 1">HydroFW: {DSancillary::ysnHydroFW}<br />Buffer from flowing water: {DSancillary::intFromBuffFW}<br />
Buffer into flowing water: {DSancillary::intIntoBuffFW}
</td></tr>
<tr>
<td spry:if="'{DSancillary::ysnHydroOW}' == 1"> Buffer from open water: {DSancillary::intFromBuffFW}<br />Buffer into open water: {DSancillary::intIntoBuffOW}</td></tr>
<tr><td><br /></td></tr>
<tr><th>Mapcode:</th></tr>
<tr spry:repeat="DSpresence">
<td spry:if="'{DSpresence::ysnPres}' == '1'">{DSpresence::intLSGapMapCode}</td><td spry:if= "'{DSpresence::intLSGapMapCode}'=='{dsMUDescription::intLSGapMapCode} '">{dsMUDescription::strLSGapName}</td>
</tr>
<tr><td><ul>
<li spry:repeat="DSpresence" spry:if="'{DSpresence::ysnPres}' == '1'">{DSpresence::intLSGapMapCode}{dsMUDescription::intLSGapMapCode}< /li>
</ul></td></tr>
</table>
</div>
</div>
</body>
The best way to do this is to use xPath filtering. This http://labs.adobe.com/technologies/spry/samples/data_region/FilterXPat h_with_params.html example will give you the general idea.
The example uses a URL variable but there is no need for that if you use a procedure similar to
function newXPath(cat){
DSpresence.setXPath("dataroot/Copy_x0020_of_x0020_tblSppMapUnitPres[s trSpeciesModelCode='{DSpresence::strSpeciesModelCode}']");
DSpresence.loadData();
The function can be triggered with an onclick event placed on {strSpeciesModelCode}
Gramps
