Phoenix701
Adobe Provisioning Toolkit Enterprise Edition question
Jun 4, 2012 8:35 AM
Tags: #design #adobe #premium #suite #5.5 #options #package #enterprise #updater #edition #toolkit #provisioning #configure
I am having a problem with Adobe Provisioning Toolkit Enterprise Edition. While configuring the package to install the Design Premium Suite 5.5 I enter the Serial Number and select Distribute updates manually. During the install process it appears that something in the package is looking to the network for information or updates in two places.
The reason I know this is because our Internet filter software is catching this request and asking for a name and password to continure the process. I have the name and password of course but this prevents me from doing an unattended install which is the reason I'm using Adobe Provisioning Toolkit Enterprise Edition.
Does anyone know what the package install might be looking for and how to stop it? Thanks for any help!
    Jun 4, 2012 10:33 AM   in reply to Phoenix701
    It's probably looking for Adobe AIR and Flash Player as used by the installer itself. Could be the "newer version of Flash already in place vs. bundled version" issue. Still, unless it prevents your installs from going through, it should not be a problem. Does your test install work?
    Mylenium
    Jun 4, 2012 1:29 PM   in reply to Phoenix701
    Moving this discussion to the Creative Suite Enterprise Deployment forum.
    Jun 5, 2012 3:09 AM   in reply to Mylenium
    If you included Air in your package then it will try and connect to the internet, if you have a proxy server setup then this will cause an error. Please disable Air and deploy after main package has been installed. Updates can also be managed with the RUM tool (please see the Enterprise Deployment Guide for more information) this allows you to remotely initiate the updates and specify proxy server information or can be used with AUSST if you have or would like to have your own internal Adobe Update Server.
    Cheers
    Karl
    CS Enterprise Systems Engineer
