jay81800
application crash on xoom [pointerIndex out of range]
Mar 27, 2012 5:52 AM
Tags: #xoom #motorola #air3.1.0.557 #android3.1
Got the following error in our system. Is anyone else seeing a similar problem?
Our test platform details are:
AIR 3.1.0.557
Android Version 3.1
XOOM
W/ProcessStats(  146): Skipping unknown process pid 17925
E/AndroidRuntime(  681): FATAL EXCEPTION: main
E/AndroidRuntime(  681): java.lang.IllegalArgumentException: pointerIndex out of range
E/AndroidRuntime(  681):     at android.view.MotionEvent.nativeGetPointerId(Native Method)
E/AndroidRuntime(  681):     at android.view.MotionEvent.getPointerId(MotionEvent.java:1522)
E/AndroidRuntime(  681):     at android.view.ScaleGestureDetector.onTouchEvent(ScaleGestureDetector.j ava:213)
E/AndroidRuntime(  681):     at com.adobe.air.AIRWindowSurfaceView.onTouchEvent(AIRWindowSurfaceView. java:623)
E/AndroidRuntime(  681):     at android.view.View.dispatchTouchEvent(View.java:4609)
E/AndroidRuntime(  681):     at android.view.ViewGroup.dispatchTransformedTouchEvent(ViewGroup.java:1 560)
E/AndroidRuntime(  681):     at android.view.ViewGroup.dispatchTouchEvent(ViewGroup.java:1333)
E/AndroidRuntime(  681):     at com.android.internal.policy.impl.PhoneWindow$DecorView.superDispatchT ouchEvent(PhoneWindow.java:1709)
E/AndroidRuntime(  681):     at com.android.internal.policy.impl.PhoneWindow.superDispatchTouchEvent( PhoneWindow.java:1264)
E/AndroidRuntime(  681):     at android.app.Activity.dispatchTouchEvent(Activity.java:2315)
E/AndroidRuntime(  681):     at com.android.internal.policy.impl.PhoneWindow$DecorView.dispatchTouchE vent(PhoneWindow.java:1682)
E/AndroidRuntime(  681):     at android.view.View.dispatchPointerEvent(View.java:4677)
E/AndroidRuntime(  681):     at android.view.ViewRoot.deliverPointerEvent(ViewRoot.java:2392)
E/AndroidRuntime(  681):     at android.view.ViewRoot.handleMessage(ViewRoot.java:2054)
E/AndroidRuntime(  681):     at android.os.Handler.dispatchMessage(Handler.java:99)
E/AndroidRuntime(  681):     at android.os.Looper.loop(Looper.java:132)
E/AndroidRuntime(  681):     at android.app.ActivityThread.main(ActivityThread.java:4157)
E/AndroidRuntime(  681):     at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime(  681):     at java.lang.reflect.Method.invoke(Method.java:491)
E/AndroidRuntime(  681):     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit .java:841)
E/AndroidRuntime(  681):     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:599)
E/AndroidRuntime(  681):     at dalvik.system.NativeStart.main(Native Method)
W/ActivityManager(  146):   Force finishing activity air.OurPlayer/.AppEntry
I/UsageStats(  146): Deleting usage file : usage-20120314
W/ActivityManager(  146): Activity pause timeout for ActivityRecord{40dcfc30 air.OurPlayer/.AppEntry}
I/ActivityManager(  146): Config changed: {1.0 0mcc0mnc ja_JP sw800dp w800dp h1232dp xlrg port finger -keyb/v/h -nav/h s.7}
D/TabletStatusBar(  199): lights on
I/ActivityManager(  146): No longer want com.google.android.gm (pid 461): hidden #16
I/WindowManager(  146): Input event dispatching timed out sending to air.OurPlayer/air.OurPlayer.AppEntry
W/ActivityManager(  146): Activity destroy timeout for ActivityRecord{40dcfc30 air.OurPlayer/.AppEntry}
I/ActivityManager(  146): Process air.OurPlayer (pid 681) has died.
I/WindowManager(  146): WIN DEATH: Window{417bca40 air.OurPlayer/air.OurPlayer.AppEntry paused=false}
W/WindowManager(  146): Force-removing child win Window{40d81968 SurfaceView paused=false} from container Window{417bca40 air.OurPlayer/air.OurPlayer.AppEntry paused=false}
W/WindowManager(  146): Force-removing child win Window{417c6cd0 SurfaceView paused=false} from container Window{417bca40 air.OurPlayer/air.OurPlayer.AppEntry paused=false}
W/WindowManager(  146): Failed looking up window
W/WindowManager(  146): java.lang.IllegalArgumentException: Requested window android.os.BinderProxy@40a08028 does not exist
W/WindowManager(  146):     at com.android.server.wm.WindowManagerService.windowForClientLocked(Wind owManagerService.java:6736)
W/WindowManager(  146):     at com.android.server.wm.WindowManagerService.windowForClientLocked(Wind owManagerService.java:6727)
W/WindowManager(  146):     at com.android.server.wm.WindowState$DeathRecipient.binderDied(WindowSta te.java:1390)
W/WindowManager(  146):     at android.os.BinderProxy.sendDeathNotice(Binder.java:418)
W/WindowManager(  146):     at dalvik.system.NativeStart.run(Native Method)
I/WindowManager(  146): WIN DEATH: null
W/WindowManager(  146): java.lang.IllegalArgumentException: Requested window android.os.BinderProxy@409df9d8 does not exist
I/WindowManager(  146): WINDOW DIED Window{417bca40 air.OurPlayer/air.OurPlayer.AppEntry paused=false}
I/WindowManager(  146): Input event dispatching timed out sending to application AppWindowToken{41bcbe50 token=ActivityRecord{40a06bf8 com.gau.go.launcherex/com.jiubang.ggheart.apps.desks.diy.GoLauncher}}
E/ActivityManager(  146): ANR in android.process.acore (com.gau.go.launcherex/com.jiubang.ggheart.apps.desks.diy.GoLauncher)
E/ActivityManager(  146): Reason: keyDispatchingTimedOut
E/ActivityManager(  146): Load: 0.24 / 0.26 / 0.34
E/ActivityManager(  146): CPU usage from 24927ms to 3514ms ago:
E/ActivityManager(  146):   10% 146/system_server: 5.5% user + 5% kernel / faults: 87 minor 2 major
E/ActivityManager(  146):   8.9% 90/mediaserver: 7.9% user + 1% kernel / faults: 1 minor 1 major
E/ActivityManager(  146):   1.7% 16265/kworker/u:0: 0% user + 1.7% kernel
E/ActivityManager(  146):   1.4% 87/surfaceflinger: 0% user + 1.4% kernel / faults: 5 minor
E/ActivityManager(  146):   1.1% 17935/kworker/u:1: 0% user + 1.1% kernel
E/ActivityManager(  146):   1.1% 16082/kworker/u:3: 0% user + 1.1% kernel
E/ActivityManager(  146):   0.1% 62/kinteractiveup: 0% user + 0.1% kernel
E/ActivityManager(  146):   0% 1//init: 0% user + 0% kernel / faults: 30 minor
E/ActivityManager(  146):   0% 3/ksoftirqd/0: 0% user + 0% kernel
E/ActivityManager(  146):   0% 6/migration/0: 0% user + 0% kernel
E/ActivityManager(  146):   0% 278/com.google.process.gapps: 0% user + 0% kernel
E/ActivityManager(  146):   0% 1357/zygote: 0% user + 0% kernel
E/ActivityManager(  146):   0% 13213/iscan_sysioc: 0% user + 0% kernel
E/ActivityManager(  146):   0% 13218/wpa_supplicant: 0% user + 0% kernel
E/ActivityManager(  146):   0% 16972/kworker/0:1: 0% user + 0% kernel
E/ActivityManager(  146):   0% 26834/kworker/1:0: 0% user + 0% kernel
E/ActivityManager(  146): 13% TOTAL: 6.5% user + 6.4% kernel + 0% iowait + 0% softirq
E/ActivityManager(  146): CPU usage from 361ms to 888ms later:
E/ActivityManager(  146):   7.2% 146/system_server: 3.6% user + 3.6% kernel / faults: 1 minor
E/ActivityManager(  146):     7.2% 173/InputDispatcher: 3.6% user + 3.6% kernel
E/ActivityManager(  146):   1.5% 26834/kworker/1:0: 0% user + 1.5% kernel
E/ActivityManager(  146): 2.8% TOTAL: 0.9% user + 1.8% kernel
Thanks.
