Acrobat Pro 10.1.3 crashes about every other time I launch it
May 29, 2012 11:01 AM
Tags: #acrobat #mac
When I launch Acrobat Pro 10.1.3 it crashes about half the time, and then I have to relaunch it. Has anyone else had this problem? Any solutions?
Branched to a new discussion.
  • David Kastendick
    Apr 7, 2010
    May 30, 2012 1:54 PM   in reply to bsnebold
    Couple of questios for you:
    • What OS are you running?
    • Did this recently start?
    • If so, what on your system have you changed?
    -David
  • David Kastendick
    Apr 7, 2010
    May 30, 2012 2:27 PM   in reply to bsnebold
    Was Acrobat X installed as part of CS6 or was it installed prior to you upgrading?  As the issue is intermittent, have you seen any sort of pattern to it crashing?  Do you have any 3rd party plugins installed?  If you launch Acrobat without plugins (hold down the Shift key on launch), does it crash?
    -David
    May 31, 2012 4:33 AM   in reply to bsnebold
    Hi.
    This is also happening to us. All software is latest version. Just started less than two weeks ago. Intalled all CS6 apps from Creative Cloud. No plugins for Acrobat.
    Loads then crashes closed.
    R.
  • David Kastendick
    Apr 7, 2010
    May 31, 2012 12:38 PM   in reply to INDUSTRY11
    Hi R.,
    Is Acrobat crashing for you each time you launch the application?  What OS are you running?
    -David
    May 31, 2012 4:11 PM   in reply to David Kastendick
    10.7.4 OSX
    Jun 1, 2012 2:15 AM   in reply to bsnebold
    I have also had similar problems on both my Macs since upgrading from 10.1.2 to 10.1.3.  I had ZERO problems with 10.1.2.
    Symptoms:
    - Acrobat crashes >50% when opening (by double-click) a pdf for the first time (especially if the pdf hasn't been opened in a long while)
    - Acrobat crashes less when reopening (by double-click) pdf's that are frequently opened and closed.
    - When starting the Acrobat application directly (not by double-click of pdf) it seldom crashes.
    - After crashing, an Apple crash report dialog box opens.  I have attached some of the crash report below.
    - Symptoms occur on both computers
    - I do NOT have any other Adobe software applications such as CS6,etc. (I do have Adobe Flash installed)
    Version:
    Adobe Acrobat Pro Version 10.1.3
    Macs:
    iMac 2007 (iMac7,1);  24";  2.8 MHz core 2 duo extreme
    Mac OS 10.6.8
    - All Apple software is up to date (as of June 1, 2012)
    MacBook Air 2012; 13"; Intel i5
    Mac OS X - Tiger
    Crash report:
    Process:         AdobeAcrobat [731]
    Path:            /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
    Identifier:      com.adobe.Acrobat.Pro
    Version:         10.1.3 (10.1.3)
    Code Type:       X86 (Native)
    Parent Process:  launchd [96]
    Date/Time:       2012-06-01 12:13:41.379 +0300
    OS Version:      Mac OS X 10.6.8 (10K549)
    Report Version:  6
    Interval Since Last Report:          258898 sec
    Crashes Since Last Report:           5
    Per-App Interval Since Last Report:  110153 sec
    Per-App Crashes Since Last Report:   5
    Anonymous UUID:                      7D78E080-D2CA-45BB-8E2C-66F381960269
    Exception Type:  EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Jun 5, 2012 8:12 AM   in reply to RWG0652
    Hi All,
    Anyone in this post, who is experiencing a crash, kindly list out the exact steps of operations you do with Acrobat before it crashes.
    Also mention what other Adobe Creative Suite apps are installed on your machine and how were they installed.
    And finally, whenever you experience the crash, kindly share via some file sharing server the crash log text that appears alongwith other related log files, namely
    ~/Users/<username>/Library/Logs/PDApp.log
    /tmp/amt3.log
    /tmp/oobelib.log
    Jun 14, 2012 10:14 AM   in reply to bsnebold
    Symptoms:
    Version:
    Macs:
    Mac OS 10.6.8
    Mac OS X - Tiger
    Jun 14, 2012 8:22 PM   in reply to vamalik
    X Pro shuts down by itself upon launching. Seemed like a common problem for Mac and PC but ignified resolutions. Any updates?
    I am not able to uninstall Acrobat X Pro from uninstaller : Invalid Application it claims.
    Installed CS6 (Design & Web Premium) on Mac OS X V10.6.8. Have CS2 on the same computer too but without any acrobat softwares.
    Many feedbacks fr PC users but not on Mac.
    Jun 16, 2012 10:31 PM   in reply to Dan Tam 123
    Similar symptoms as numediaman:
    - Acrobat crashes about 50% when opening a pdf via spotlight.
    - When starting the Acrobat application via the Acrobat menu open command it seldom crashes.
    - After crashing, an Apple crash report dialog box opens. See the crash report below.
    - Which software is installed in CS5.5 can be seen form the log file.
    As long as this issue is not solved, the system crash report, the amt3.log and the PDApp.log con be downloaded here:
    http://www. auditeon.com/xyz/acrobat_crash.zip
    (Remove the space between www. and auditeon)
    Adobe Acrobat version:
    MacBook Pro, version
    MacBookPro8,2
    i7@2.5Ghz, 8GB memory, Vertex3 sssd
    Operating system version:
    Mac OS X - Lion, 10.7.4 (11E53)
    Jun 17, 2012 5:39 PM   in reply to vamalik
    Acrobat has a 100% quit on launch rate for me.
    It happens whether I double-click the app in the Applications folder, launch the app using "spotlight", open via a pdf file from the hard drive, etc. - Makes no difference. Everytime I open Acrobat, it lasts for approximately 6 seconds, then quits, bringing up the Application Manager, which also quits though I assume that is because it is just registering the crash with Adobe?
    Installed via Creative Cloud along with PS, Ill, Ind CS6 (as well as the usual accompanying apps such as Bridge etc.)
    Have re-installed just to make sure that the installation wasn't stuffed up somehow, but still get same result.
    Log files: http://www.mediafire.com/?eiuw1n0ctwdlle5,5hvtniwllpvllop,zepmmh15dlrs r7w
    System:
      Model Identifier:          MacBookPro6,2
      Processor Name:          Intel Core i5
      Processor Speed:          2.4 GHz
      Memory:          8 GB
      Mac OS X Lion 10.7.4
      OWC Mercury Extreme Pro SSD 115 GB
    I use PDF files all day every day and this is rather frustrating. I am having to use Preview which I am not a fan of.
    Jun 19, 2012 2:01 AM   in reply to vamalik
    For me too, Adobe Acrobat Pro always crashes when freshly launched. When relaunching it immediately (clicking through OSX's 'restore windows' window), it always launches fine.
    Jun 19, 2012 5:55 PM   in reply to vamalik
    Acrobat 10.3.1 crashes 100% on start up on Mac OS 10.7.4. The open recent file window opens, and it will open a recent/previously opened file, but then promptlys crashes when anything is done (non responsive).
    Acrobat was installed with Adobe CS5 5.5 Premium Education Package as download from Adobe Education store.
    No other software was running at time of crash. Please fix.
    Jun 20, 2012 3:28 AM   in reply to dwerf_dwerf
    Unlike dwerf_dwerf, even "restoring windows" does not work for me…
    Jun 22, 2012 10:02 AM   in reply to bsnebold
    I'm having a similar problem.  Acrobat works may 70% of the time.  When it doesn't it's usually just trying to open a PDF then it crashes.  I'll try again and sometimes on the second try it doesn't crash.  Sometimes it takes longer.
    The weird thing is, I looked in the log files mentioned above and theres nothing in there about the crashes.
    Also, this problem didn't start occuring until I installed CS6.  In fact, initially after install Acrobat wouldn't launch at all.  I uninstalled and reinstalled several times until once it would at launch and not crash.  Now that I think about it, why did the installer install Acrobat over what was already 10.x.x?
    Jul 2, 2012 10:02 AM   in reply to bsnebold
    this happens to me when acrobat is NOT running, but not when it IS.
    just now, it wasn't running. i double-clicked an attachment in mail.app. CRASH
    and it crashes EVERY time. it's completely reporduceable.
    but, if i launch acrobat and then double-click the attachment, it's fine.
    Jul 2, 2012 3:25 PM   in reply to bsnebold
    It has been a month since any Adobe staff replied. Is there an update on the horizon? Maybe a work around?
    I can not use Acrobat at all. In a business where I need Acrobat 70% of my day, this is ridiculous…
    Can anyone suggest an alternative to Acrobat?
    Jul 23, 2012 12:41 AM   in reply to vamalik
    Hello, we are experiencing same issues ever since 10.1.3 upgrade. Acrobat crashes on 50% of launches or even more often. Back then I saw that it is a common problem and expected it to be solved rather quickly. But it never did!
    What can we do to prevent crashing?
    Acrobat Pro 10.1.3 on OS X 10.7.4
    My log files: http://db.tt/g5ndA4jg
    Aug 1, 2012 4:11 AM   in reply to bsnebold
    I am having the same issue on my Windows 7, 64bit machine. I use it from the cloud and have all updates installed.
    Please fix this adobe.. I pay a lot of money and I can't use this piece of software at all. Mine crashes 100%..
    Right now I am forced to look for alternatives.
    Aug 1, 2012 4:14 AM   in reply to StudentTim
    I managed to fix this. I uninstalled Acrobat and then ran the Acrobat cleaner tool. Rebooted and then reinstalled. Seems to be fine now.
    http://labs.adobe.com/downloads/acrobatcleaner.html
    Aug 3, 2012 8:30 PM   in reply to bsnebold
    Acrobat was crashing everytime I opened it, the crash report routine quit opening, I tried disabling all fonts except for system fonts - no change.  I unistalled, ran the cleaner tool and reinstalled - no change.  A few hours ago I updated my Macbook Air (factory install of Lion) to Mountail Lion and all is working fine.  Don't know why the new operating system fixed Acrobat X Pro, but I don't have the crashing on opening.
    Just my experience, after trying all of the other recommended fixes.
    Aug 3, 2012 8:37 PM   in reply to gilprice
    wow! i thought i had tried this since installing mountain lion, but i guess not: i just tried double-clicking a PDF on my desktop with acrobat *not* running. it came right up.
    i have no idea why ML works and L doesn't, but that makes me inclinded to think this is not adobe's problem but apples.
    thanks, gilprice!
    Aug 8, 2012 8:43 AM   in reply to bsnebold
    Sorry to burst the Mountain Lion solved my problem bubble but I still have the issue under ML that I did under Lion 10.7.4. If it is the first run of Acrobat from boot and you double click a PDF to open it it crashes out. If you open Acrobat and then open the file it seems to be fine. It's better under 10.8 but definitely not fixed.
    The reinstall trick did not fix the problem either.
    I have a MacBook Pro with Retina Display, running OSX 10.8 (ML) and CS6 via creative cloud. No other Apps running be they CS or other. I can normally replicate this error everytime from a reboot and open file.
    Once you have run Acrobat up successfully once the problem seems to go away until the next reboot.
    All the usual Mac fixes fail - delete the PLIST file - reinstall etc, got to be a program error somewhere, in my opinion.
    Aug 9, 2012 11:19 AM   in reply to kaostheory777
    Still no solution in sight? Strange, since this behavior has been known for a while now an Adobe is supposed to be "the" professional amongst the pdf-programs.
    Aug 11, 2012 7:26 AM   in reply to bsnebold
    Version:
    Adobe Acrobat Pro Version 10.1.3 (comes with CS6 premium suite)
    All CS6 Premium softwares  are installed.
    Other Adobe products installed:
    CS4 - Only Illustrator and Indesign (..and Bridge)
    Adobe Acrobat 10.1.3.23 Plugin for the browser (mozilla sea monkey)
    -Steps:
    Open a file with drawings (ie: exported from illustrator whatever the version or a contractor's pdf plan .
    Srolling the drawing, paning or zooming.. after a short period .. Acrobat quit without a word (no crash report).
    Now: Cliking an other pdf file or on the acrobat.exe.. does not work at all. Nothing occurs on the screen.
    FIXING:
    WAY #1: Try to erase the db.cache..
    Relaunch acrobat. Now it comes..but in trial mode (I am allowed to try the software for 32767 Days !! woo.. 90 years..See photo in attachment).
    Must re-Input the CS6 serial- Must re activate.
    Note: CS4 Has now lost its authorization.. Must re input the CS4 serial.
    WAY #2: Uninstall acrobat and reinstall. Input again the serial, activate again.. download the updates again and re install the updates again.
    WAY#3: Adobe to fix this problem, and waiting for the patch.
    Dell Precision WS690 :
    CPU Xeon 3.2 GHz X 2 (hyperthreaded)
    Quadro fx3500
    RAM 16 Gb
    Win 7 64 bits Ultimate
    Aug 13, 2012 12:10 AM   in reply to Piem3D
    Same Problem
    Installed CS6 about a month ago worked great until today.
    Tried deleting the DB.cache that gave us 4 hours of uninterupted use but it is crashing again.
    Acrobat 10.1.3.23
    Windows Server 2008 R2 Version 6.1.7601
    We have installed Indesign, Illustrator, Photoshop and bridge CS6 and CS5.5 and of course Acrobat.
    +1 to adobe releasing an update to fix this,
    this is from my event log:
    Fault bucket , type 0
    Event Name: PCA2
    Response: Not available
    Cab Id: 0
    Problem signature:
    P1: Acrobat.exe
    P2: 10.1.3.23
    P3: Adobe Acrobat
    P4: Adobe Acrobat
    P5: Adobe Systems Incorporated
    P6: 200
    P7: -1
    P8:
    P9:
    P10:
    Analysis symbol:
    Rechecking for solution: 0
    Report Id: 8691a869-e513-11e1-a641-60eb693e8020
    Report Status: 4
    Message was edited by: Narraman (poor spelling)
    Aug 13, 2012 4:28 PM   in reply to Narraman
    Additional note:
    Today Distiller started to crash simillar to Acrobat.
    Cant get distiller to run for more then half a second now.
    Another note:
    installed adobe reader today as a work around. so far it's running fine.
    Aug 19, 2012 4:53 AM   in reply to Narraman
    When I started Adobe Acrobat Pro, a message appeared that an update from version 10.1.3 to version 10.1.4 was available. I installed that and so far the above mentioned crash problems are finally resolved. (Using still OSX 10.7.4). Thanks!
    Calculating status...
    Aug 20, 2012 10:45 AM   in reply to David Kastendick
    Having the same problem since upgrading to CS6.  All CS6 apps are installed and working fine with the exception of Acrobat Pro 10.1.4 which crashes seconds after launch, AAM then launches asking to accept the software license agreement, which relaunches AP, which crashes, which... ad infinitum.
    Running Lion.  Latest versions of everything.  Unistalled CS3 then clean install of CS6.  Is there perhaps some residual system file buired in a sub-sub-sub-folder somewhere that's causing this?  Installed Reader as a work around but I really need to be able to use Pro for editing, etc..  Help, please!
    Aug 29, 2012 6:37 AM   in reply to st@bxl
    Same thing happenning here. All of a sudden, 10.1.4 crashes immediately on quit. Uninstalled, reinstalled, restarted, etc., etc., all to no avail. Acrobat 9 works fine.
    Aug 30, 2012 5:57 AM   in reply to st@bxl
    Hi st@bxl,
    Have you tried the solution mentioned by 818g here: http://forums.adobe.com/thread/1021670?tstart=0
    Aug 30, 2012 5:59 AM   in reply to RAILhead
    Hi Railhead,
    On what OS are you experiencing this issue? Can you share across the crash dump via some file sharing server?
    Sep 3, 2012 3:10 AM   in reply to vamalik
    Thanks!  This seems to have done the trick.  We'll see if it goes belly up again in 30 days.  For now, good to go.
    Nov 6, 2012 4:54 AM   in reply to bsnebold
    Same problem here. Restarting Acrobat after crash doesn't work here. It crashes every time
    ocess:         AdobeAcrobat [4910]
    Version:         10.1.1 (10.1.1)
    Parent Process:  launchd [185]
    Date/Time:       2012-11-06 13:52:14.590 +0100
    Report Version:  6
    Interval Since Last Report:          17007 sec
    Crashes Since Last Report:           14
    Per-App Interval Since Last Report:  40 sec
    Per-App Crashes Since Last Report:   9
    Anonymous UUID:                      3B096531-A2B8-45CB-A4D3-404EC4816C0E
    Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
    0   com.adobe.CoolType             0x0272ad1b CTInit + 105967
    1   com.adobe.CoolType             0x0287f588 CTCleanup + 902698
    2   com.adobe.CoolType             0x02720073 CTInit + 61767
    3   com.adobe.CoolType             0x0286c72e CTCleanup + 825296
    4   com.adobe.CoolType             0x0285449e CTCleanup + 726336
    5   com.adobe.CoolType             0x027fe4e0 CTCleanup + 374146
    6   com.adobe.CoolType             0x027fe33d CTCleanup + 373727
    7   com.adobe.CoolType             0x02852272 CTCleanup + 717588
    8   com.adobe.CoolType             0x0279ee34 CTInit + 581384
    9   com.adobe.Acrobat.framework    0x003bda14 RunAcrobatInBrowser + 136189
    10  com.adobe.Acrobat.framework    0x003bdaed RunAcrobatInBrowser + 136406
    11  com.adobe.Acrobat.framework    0x00e713c8 AcroSecurityBailOutImpl + 11051704
    12  com.adobe.Acrobat.framework    0x0002f877 RunAcrobat + 135164
    13  com.adobe.Acrobat.framework    0x0002f631 RunAcrobat + 134582
    14  com.adobe.Acrobat.framework    0x0001864e RunAcrobat + 40403
    15  com.adobe.Acrobat.framework    0x000129ff RunAcrobat + 16772
    16  com.adobe.Acrobat.framework    0x0001205b RunAcrobat + 14304
    17  com.adobe.Acrobat.framework    0x000119f3 RunAcrobat + 12664
    18  com.apple.Foundation           0x98f9cdb3 _nsnote_callback + 176
    19  com.apple.CoreFoundation       0x99947763 __CFXNotificationPost + 947
    20  com.apple.CoreFoundation       0x9994716a _CFXNotificationPostNotification + 186
    21  com.apple.Foundation           0x98f91c50 -[NSNotificationCenter postNotificationName:object:userInfo:] + 128
    22  com.apple.Foundation           0x98f9f05d -[NSNotificationCenter postNotificationName:object:] + 56
    23  com.apple.AppKit               0x93420216 -[NSApplication _postDidFinishNotification] + 125
    24  com.apple.AppKit               0x93420126 -[NSApplication _sendFinishLaunchingNotification] + 74
    25  com.apple.AppKit               0x93577339 -[NSApplication(NSAppleEventHandling) _handleAEOpen:] + 274
    26  com.apple.AppKit               0x93576f59 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 101
    27  com.apple.Foundation           0x98fd21f8 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 511
    28  com.apple.Foundation           0x98fd1fbc _NSAppleEventManagerGenericHandler + 228
    29  com.apple.AE                   0x92ec4f5c aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned long, unsigned char*) + 166
    30  com.apple.AE                   0x92ec4e5b dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 43
    31  com.apple.AE                   0x92ec4d65 aeProcessAppleEvent + 197
    32  com.apple.HIToolbox            0x9a160197 AEProcessAppleEvent + 50
    33  com.apple.AppKit               0x933f07d2 _DPSNextEvent + 1420
    34  com.apple.AppKit               0x933efdd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
    35  com.apple.AppKit               0x933b21f3 -[NSApplication run] + 821
    36  com.adobe.Acrobat.framework    0x0001033d RunAcrobat + 6850
    37  com.adobe.Acrobat.framework    0x0000e9b7 RunAcrobat + 316
    38  com.adobe.Acrobat.Pro          0x00001e92 main + 94
    39  com.adobe.Acrobat.Pro          0x00001e16 start + 54
    Thread 1:  Dispatch queue: com.apple.libdispatch-manager
    0   libSystem.B.dylib              0x9654f382 kevent + 10
    1   libSystem.B.dylib              0x9654fa9c _dispatch_mgr_invoke + 215
    2   libSystem.B.dylib              0x9654ef59 _dispatch_queue_invoke + 163
    3   libSystem.B.dylib              0x9654ecfe _dispatch_worker_thread2 + 240
    4   libSystem.B.dylib              0x9654e781 _pthread_wqthread + 390
    5   libSystem.B.dylib              0x9654e5c6 start_wqthread + 30
    Thread 2:
    0   libSystem.B.dylib              0x9654e412 __workq_kernreturn + 10
    1   libSystem.B.dylib              0x9654e9a8 _pthread_wqthread + 941
    2   libSystem.B.dylib              0x9654e5c6 start_wqthread + 30
    Thread 3:
    Thread 4:
    Thread 5:
    0   libSystem.B.dylib              0x96556aa2 __semwait_signal + 10
    1   libSystem.B.dylib              0x9655675e _pthread_cond_wait + 1191
    2   libSystem.B.dylib              0x965583f8 pthread_cond_wait$UNIX2003 + 73
    3   ...ple.CoreServices.CarbonCore 0x90db521e TSWaitOnCondition + 126
    4   ...ple.CoreServices.CarbonCore 0x90da0b68 TSWaitOnConditionTimedRelative + 202
    5   ...ple.CoreServices.CarbonCore 0x90d9c533 MPWaitOnQueue + 250
    6   AdobeACE                       0x01f30737 ACEInitialize + 3741
    7   AdobeACE                       0x01f306ad ACEInitialize + 3603
    8   ...ple.CoreServices.CarbonCore 0x90d8054a PrivateMPEntryPoint + 68
    9   libSystem.B.dylib              0x96556259 _pthread_start + 345
    10  libSystem.B.dylib              0x965560de thread_start + 34
    Thread 6:
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    3   AdobeAGM                       0x0207d79c AGMInitialize + 33770
    4   AdobeAGM                       0x0207d6d6 AGMInitialize + 33572
    5   AdobeAGM                       0x0207d231 AGMInitialize + 32383
    6   libSystem.B.dylib              0x96556259 _pthread_start + 345
    7   libSystem.B.dylib              0x965560de thread_start + 34
    Thread 21:
    Thread 22:
    Thread 0 crashed with X86 Thread State (32-bit):
      eax: 0x00000000  ebx: 0x0272a3ef  ecx: 0xa06f14c0  edx: 0x00000000
      edi: 0x00000000  esi: 0xbfffcad0  ebp: 0xbfffd0f8  esp: 0xbfffca50
       ss: 0x00000023  efl: 0x00010246  eip: 0x0272ad1b   cs: 0x0000001b
       ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
      cr2: 0x00000000
    Binary Images:
        0x1000 -     0x1fff +com.adobe.Acrobat.Pro 10.1.1 (10.1.1) <61906DC1-C159-80E3-9766-24C695ABC5D7> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
        0x6000 -  0x1ca6fff +com.adobe.Acrobat.framework 10.1.1 (10.1.1) <E9429303-C3CA-30F8-2B76-9A36F5018CCE> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
    0x1f2e000 -  0x204ffff +AdobeACE ??? (???) <42337EF5-3ED6-C0E7-5EB0-2354755A95FD> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
    0x2072000 -  0x2637feb +AdobeAGM ??? (???) <2C3603CA-70D1-BBF4-57C2-E40222ABDC3B> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
    0x26ea000 -  0x2707ff7 +AdobeBIB ??? (???) <2FE90606-2817-28E6-3D64-533895E6400F> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
    0x270e000 -  0x2a32fe3 +com.adobe.CoolType AdobeCoolType 5.08.109.1 (5.08.109.1) <9BE5826D-CE25-57C1-48CA-4A6B01B1B566> /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
    0x2f40000 -  0x2f41ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    0x26282000 - 0x26294ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <3057675E-16A3-EC0C-A764-5CADB6C5ECD2> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
    0x263dc000 - 0x263eafe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <1825F5DF-491F-FDD5-3ABB-3FAC1EDC4357> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
    0x29815000 - 0x2981aff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <31610F71-4447-CC8F-2859-4B881BB48F9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libFontStreams.A .dylib
    0x8fe00000 - 0x8fe4163b  dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
    0x90003000 - 0x900cefef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x900cf000 - 0x9017cfe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
    0x9022e000 - 0x902c0fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x90325000 - 0x90367ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x90368000 - 0x903b8ff7  com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
    0x903b9000 - 0x903cdfe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
    0x9044c000 - 0x90486ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <A6C207E3-7B42-926D-9C93-BE3F50B92496> /usr/lib/libcups.2.dylib
    0x90487000 - 0x90561fff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x9056a000 - 0x90d59557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x90d5a000 - 0x9107aff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x9107b000 - 0x91089fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
    0x913f2000 - 0x9152ffe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x91565000 - 0x915e7ffb  SecurityFoundation ??? (???) <C4506287-1AE2-5380-675D-95B0291AA425> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
    0x915e8000 - 0x915e8ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x915e9000 - 0x91658ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x91659000 - 0x91665ff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
    0x916d5000 - 0x916dffe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x916e0000 - 0x91733ff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x91734000 - 0x91758ff7  libJPEG.dylib ??? (???) <C43FD809-08B6-629D-8980-D7B0ECEA20A9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x918ff000 - 0x91d34ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x91d35000 - 0x91d43ff7  com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x91df5000 - 0x91e05ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
    0x91e06000 - 0x91e37ff7  libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x91e38000 - 0x91e49ff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x92024000 - 0x9214cfe7  com.apple.WebKit 6534.57 (6534.57.2) <4CB86278-4657-3503-8042-074628222DF3> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x924e9000 - 0x924e9ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x92b83000 - 0x92ba5fef  com.apple.DirectoryService.Framework 3.6 (621.15) <F38894EA-2C13-7FC5-C084-94DA0B5B6B68> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
    0x92ba6000 - 0x92bceff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <E761F29A-328B-29D9-3DF0-023F2C21E500> /usr/lib/libxslt.1.dylib
    0x92c00000 - 0x92c06fe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x92c07000 - 0x92c45ff7  com.apple.QuickLookFramework 2.3 (327.7) <6387A103-C7EF-D56B-10EF-5ED5FC7F33A5> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x92ced000 - 0x92d31fe7  com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x92d32000 - 0x92d3cffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x92d3d000 - 0x92ebffe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <50A70082-F800-93D8-1A7C-C95AAB1F352C> /usr/lib/libicucore.A.dylib
    0x92ec0000 - 0x92ec0ff7  com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x92ec1000 - 0x92ef4ff7  com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x93389000 - 0x93392ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x93393000 - 0x933a7ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x933a8000 - 0x93c8bff7  com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x93c8c000 - 0x93ccfff7  libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x93daf000 - 0x93dcdfe7  libPng.dylib ??? (???) <5B979A83-8CE7-6BD7-B84C-A2D1119B378D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x93f31000 - 0x93f35ff7  libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
    0x93f36000 - 0x9419cff7  com.apple.security 6.1.2 (55002) <3FA54D69-5476-78DD-0AFC-D6697263890E> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x94243000 - 0x94286ff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x9428a000 - 0x9436afe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x94827000 - 0x9482bff7  IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x948bc000 - 0x948bcff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x948bd000 - 0x94901ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x9497d000 - 0x94a15fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x94a16000 - 0x94a35ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x94a7a000 - 0x94a7dff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
    0x94b5c000 - 0x94b6eff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
    0x94b6f000 - 0x94b74ff7  com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
    0x94bab000 - 0x94bafff7  libGIF.dylib ??? (???) <9E51F8ED-83B4-DA41-1E2F-CFA726936A30> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x94bb0000 - 0x94bccfe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x94bcd000 - 0x94bd4ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x94bd5000 - 0x94febff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x95020000 - 0x9508afe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
    0x9508e000 - 0x950d4ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
    0x950e8000 - 0x950e9ff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x950ea000 - 0x95218fe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x95219000 - 0x95319fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <BE7FCD73-03B5-25A4-FCA4-D4980F1488D6> /usr/lib/libxml2.2.dylib
    0x95355000 - 0x95355ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
    0x95356000 - 0x960cefe7  com.apple.WebCore 6534.57 (6534.57.2) <6AF29D9A-F549-5BE7-3842-CFF75FC46360> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/Web Core.framework/Versions/A/WebCore
    0x960cf000 - 0x96292feb  com.apple.ImageIO.framework 3.0.6 (3.0.6) <5BF202E9-730A-3675-4374-E5300BC8ED10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x962b2000 - 0x96332feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x96333000 - 0x96333ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x96477000 - 0x96479ff7  libRadiance.dylib ??? (???) <5F803B4A-B294-BA94-FB68-E8756EE41B20> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x96488000 - 0x9648aff7  com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x964d3000 - 0x964d6ff7  libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
    0x96528000 - 0x966cfff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
    0x9683f000 - 0x96865ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x96866000 - 0x968c7fe7  com.apple.CoreText 151.13 (???) <23F359DA-D845-5C50-4DF3-19E858CF2B2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x96929000 - 0x9693efff  com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x9693f000 - 0x969ebfe7  com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x96ae1000 - 0x96b99feb  libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x96b9a000 - 0x96c48ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x96c49000 - 0x96c96feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
    0x96e71000 - 0x96eebfff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x96eec000 - 0x96f50ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x970fe000 - 0x97101ffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x97102000 - 0x97108fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x9714f000 - 0x971eafe7  com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x971eb000 - 0x97293ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x972ca000 - 0x97307ff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x97308000 - 0x97313ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x97314000 - 0x97335fe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x98dce000 - 0x98edafe7  libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
    0x98ede000 - 0x98f7bfe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x98f87000 - 0x991f8fef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x991f9000 - 0x992b2fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
    0x996ba000 - 0x9970afe7  libTIFF.dylib ??? (???) <E8B31850-BFD4-48E6-B264-A4340CD19929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x99751000 - 0x997aeff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x997ba000 - 0x997baff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x997bb000 - 0x998bdfe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
    0x998e0000 - 0x998e3fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
    0x998ec000 - 0x99a67fe7  com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x99a79000 - 0x99de4ff7  com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x9a124000 - 0x9a448fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x9a449000 - 0x9a484ffb  libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x9a485000 - 0x9a492ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x9a493000 - 0x9a494ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
    0x9a495000 - 0x9a743fe7  com.apple.JavaScriptCore 6534.57 (6534.57.3) <5B18B308-DBB2-7133-DE56-494C2FA1848B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
    0x9a744000 - 0x9a764fe7  libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
    0x9a7be000 - 0x9a87afff  com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x9a87b000 - 0x9a886ff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x9a8ba000 - 0x9a8baff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x9a8bb000 - 0x9a8d3ff7  com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <49C72FD1-891C-23C4-40E7-63DE3368C306> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <B7E8B785-D05F-F89B-5E18-EF854555926C> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
    0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
    Model: MacPro5,1, BootROM MP51.007F.B03, 8 processors, Quad-Core Intel Xeon, 2.4 GHz, 6 GB, SMC 1.39f11
    Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
    Memory Module: global_name
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.10.131.42.4)
    Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
    Network Service: Ethernet 2, Ethernet, en1
    PCI Card: ATI Radeon HD 5770, sppci_displaycontroller, Slot-1
    Serial ATA Device: HL-DT-ST DVD-RW GH41N
    Serial ATA Device: WDC WD1001FALS-41Y6A0, 931,51 GB
    Serial ATA Device: WDC WD2500JS-55NCB1, 232,89 GB
    USB Device: Hub, 0x05ac  (Apple Inc.), 0x9130, 0xfa200000 / 2
    USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0xfa230000 / 4
    USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0221, 0xfa232000 / 5
    USB Device: Apple Cinema Display, 0x05ac  (Apple Inc.), 0x9222, 0xfa220000 / 3
    USB Device: Hub, 0x05ac  (Apple Inc.), 0x9130, 0xfd100000 / 2
    USB Device: Apple Cinema Display, 0x05ac  (Apple Inc.), 0x9222, 0xfd120000 / 3
    USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000 / 2
    USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0x5a110000 / 4
    FireWire Device: built-in_hub, Up to 800 Mb/sec
    Mar 26, 2013 1:48 AM   in reply to bsnebold
    In my case this had to do with my license for CS6 (erroneously) expiring after 30 days. Here is the fix provided by Adobe staff:
    I applied the fix and it worked.
Bookmarked By (1)
