Mariano_1979
Make dot matrix icons (pure svg)
May 22, 2012 8:52 PM
Tags: #background #front #icons #cut #shape #matrix #svg #dot #minus
I want to make dot matrix icons (a lot). I have the shapes but i need to convert them to dot matrix.
I was thinking to put the shape in front of a dot matrix background and delete dot by dot to form the dot matrix shape.
But anybody know a way to automate that?
I tried with swatches and with pathfinder but dots result are cut in the corners
1 - This is the shape with the dot matrix background
http://img593.imageshack.us/img593/7528/qgnmenuphobcxt3.png
2 - And here i delete al visible dots around
http://img232.imageshack.us/img232/705/qgnmenuphobcxt32.png
3 - So this the result (the expected)
http://img3.imageshack.us/img3/3222/qgnmenuphobcxt33.png
And here i tried with swatches and this is the result (very easy and useful for large icons quantity but i don't like the cutted dots)
http://img43.imageshack.us/img43/7133/qgnmenuphobcxt34.png
So if anyone knows how to delete the dots that not touch the front shape, that would solve my problem
Thank you
    May 22, 2012 9:59 PM   in reply to Mariano_1979
    Object --> Path --> Split into Grid
    Object --> Transform --> Transform Each
    Mylenium
  • Mathias17
    Feb 20, 2012
    May 22, 2012 10:44 PM   in reply to Mylenium
    Hmmm, I don't see how this helps at all, Mylenium . . .
    May 23, 2012 1:28 AM   in reply to Mariano_1979
  • Mathias17
    Feb 20, 2012
    May 23, 2012 5:32 AM   in reply to Monika Gause
    Ah, there we go, Monika. That's exactly the method I was trying to come up with, mentally.
    Get your icon, and knockout a large square with it (so that the icon's outlines create negative space in the square).
    Create your dot array.
    Put that knocked-out square above the dot array.
    Select both knocked-out square and dots, then Pathfinder Panel > Unite.
    Use Direct Selection Tool to select the knockout, which is now adjoined with the dots it even slightly overlapped. Delete.
    You just culled all unwanted dots.
  • Mathias17
    Feb 20, 2012
    May 23, 2012 7:05 AM   in reply to Mariano_1979
    GO FORTH AND CONQUER!
    Jun 5, 2012 10:17 AM   in reply to Mariano_1979
    1. Draw the graphic.
    2. Object>Rasterize.
    3. Object>Create Object Mosaic. Ungroup.
    4. Effect>Convert To Shape:Ellipse Absolute size. Expand Appearance.
    JET
