jperl
Export Book to PDF does nothing
Jun 4, 2012 11:22 AM
As does Export to JPEG and Send Book to Blurb.  No dialog box, no error message, no crash.  When I click the button with any of the export options, absolutely nothing happens.  This is with a 6-page sample spread.  I am using the 4.1 trial version on Snow Leopard.
Any ideas or anything I might be missing?
    Jul 2, 2012 1:41 PM   in reply to jperl
    I too have that problem. After reading several other posts, I tried creating a new book, and the "export" to buttons work for that new book. But not for my "old" 461 image, 100 page book that I had previously exported to Blurb and had printed. I wanted to make some changes so I deleted the original book from Blurb (lesson: NEVER DO THAT!) and was attempting to upload the newest version. It was not my few picture background changes that caused the issue, a copy that I did not touch does not work either. This happened after I updated to 4.1. So it seems like the 4.1 book module does not like books saved in the 4 version?
    Jul 2, 2012 1:56 PM   in reply to danvsjr
    The next-to-last reply of the feedback thread Dorin linked to, above, tells of one possible thing that someone fixed and got things to work afterwards:
    “I just found the solution to my problem: I had used 1 Picture that was not part of the Books-Compilation as a Background Picture - after deleting it from the Book and using a Background-Picture from the Collection the Export to Blurb went fine.”
    Jul 2, 2012 2:09 PM   in reply to ssprengel
    Thanks for the reply. I did see that part and have looked for any obvious broken links and so far have not found any. Is there a graphic indication that there is indeed a broken link, like what you see in folders if a file is missing?
    Jul 2, 2012 2:29 PM   in reply to danvsjr
    There may be but I am not experienced in the book module or collections in general, only reading posts about such, and am not at the right computer to experiment at this point in the day.
    It seems like a way to tell if the book has an errant page or image that is preventing the Export would be to create two temporary copies of the book (or of the entire catalog if that makes more sense).  In one copy remove the first half of the pages, and in the second copy remove the second half of the pages.  If an Export works for one of these temporary copies with half the pages deleted, then the issue must be within those pages that were deleted.  If this initial delete-half experiment works, then make another temporary copy and try deleting a few pages at a time (5 or 10) from the half with the problem until the Export works, then you’ll know the problem is within those few pages, and you can do one more page-by-page deletion in a new temporary copy to see which page has the problem.
    It would probably be wise to make a backup of your entire catalog before starting any such diagnostic procedure and do the experiments on that copy.
    Jul 2, 2012 2:49 PM   in reply to danvsjr
    OK,, here is my latest. I simply selected all 98 or so pages, went to the Background tab, unclicked "Graphic", re clicked "Graphic" and now it all works. Don't know why, but it did.
    Jul 2, 2012 3:01 PM   in reply to danvsjr
    Great.  That’s easier than searching for a broken image.  Did disabling Graphic unlink something that wasn’t relinked when you re-enabled Graphic?  In other words, did the book change in some subtle way?
    If things indeed are ok, you might add the description of your original situation and the magic incantation that apparently fixed it to the Feedback discussion Dorin linked, because the Feedback area is what Adobe pays attention to more, so if there’s a bug maybe Adobe can figure it out.
    Aug 6, 2012 8:00 AM   in reply to ssprengel
    Well... not so great for me. I tried the same 'trick'. NaDa! There seems to be a lot of work-arounds but all depending on a specific situation. Haven't found my workaround yet
    Meanwhile my project got stuck !
