Problem with horizontal submenu display (they don't) in IE 6, 7 & 8
Jun 6, 2012 4:18 AM
Tags: none (add) #submenus #spry_menuGreetings:
I'll recite the oft-repeated mantra: My Spry menu, developed using 1.6.1, performs properly as desired in Safari and FF (on both Mac and PC platforms), but fails to display submenus in all versions of IE in which code was tested. I would welcome someone having a look, if possible. It would not offend if the advice were to "start over from scratch, and don't...."
Gratefully,
Quichotte2
My offending page example: http://www.asthma.partners.org/newfiles/fellowship/NewFiles/FacultyFra meset.html
Associated SpryMenuBarHorizontal.css:
@charset "UTF-8";
/* SpryMenuBarHorizontal.css - version 0.6 - Spry Pre-Release 1.6.1 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, an auto width box with no margin or padding */
ul.MenuBarHorizontal
margin: 0;
padding: 0;
list-style-type: none;
font-size: 90%;
cursor: default;
width: auto;
background-image: url(../Images/ParchmentBckgrndButton.jpg);
background-repeat: repeat-x;
color: #FFF;
font-weight: bold;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are a fixed width */
ul.MenuBarHorizontal li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 17.36em;
float: left;
/* Submenus should appear below their parent (top: 0) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarHorizontal ul
margin: 2% -95% 0 -80%;
padding: 0;
font-size: 100%;
z-index: 1020;
cursor: default;
width: 8em;
position: absolute;
left: -1000em;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to auto so it comes onto the screen below its parent menu item */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible
left: auto;
/* Menu item containers are same fixed width as parent */
ul.MenuBarHorizontal ul li
width: 17em;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) */
ul.MenuBarHorizontal ul ul
position: absolute;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarHorizontal ul.MenuBarSubmenuVisible ul.MenuBarSubmenuVisible
left: auto;
top: 0;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Submenu containers have borders on all sides */
border: 1px solid #CCC;
width: 17em;
color: #FFC;
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarHorizontal a
display: block;
cursor: pointer;
background-color: #EEE;
padding: 0.5em 0.75em;
color: #FFF;
text-decoration: none;
font-weight: bold;
font-size: 80%;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarHorizontal a:hover, ul.MenuBarHorizontal a:focus
background-color: #33C;
color: #FFF;
background-image: url(../Images/ParchmentBckgrndButtonRO.jpg);
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarHorizontal a.MenuBarItemHover, ul.MenuBarHorizontal a.MenuBarItemSubmenuHover, ul.MenuBarHorizontal a.MenuBarSubmenuVisible
color: #FFF;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
ul.MenuBarHorizontal ul a.MenuBarItemSubmenu
background-position: 95% 50%;
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
ul.MenuBarHorizontal ul a.MenuBarItemSubmenuHover
BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarHorizontal iframe
position: absolute;
z-index: 1010;
filter:alpha(opacity:0.1);
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarHorizontal li.MenuBarItemIE
display: inline;
f\loat: left;
background-color: #FFF;
